-Passive NHT SuperOne 2.1 2-Way Bookshelf Speaker Monitors x2
-Passive DIY Auratone for Mono Mids
Here's my question. Can I use a cheap Amazon amp to power these? Something like https://www.amazon.com/Amplifier-DROK-Dual-Channel-Subwoofer-Adjustment/dp/B01N1UHTU1/ref=sr_1_3?ie=UTF8&qid=1548261955&sr=8-3&keywords=amplifier+board Will those amps color the EQ or keep the signal flat? Is there any other reason not to use a barebones amp board? Any specific chips I should look for? I don't have any old hifi amps around. If I did, I'd probably need one with a flat EQ setting right? Any other ideas? Requests are sealed monitors that are passive or active. $200 for the NHT monitors and $18 for the amp. I have an old Amazon amp laying around from Christmas I could use. Thanks all.
NHT Monitors https://www.amazon.com/NHT-SuperOne-2-1-Bookshelf-Speaker/dp/B00LJX4HCY/ref=sr_1_29_sspa?ie=UTF8&qid=1548258810&sr=8-29-spons&keywords=sealed+bookshelf+speakers&psc=1#customerReviews
Auratone DIY https://groupdiy.com/index.php?topic=43086.0
