Track/Channel layout for recording, mixing and live?
Page 1 of 2
PostPosted: Tue Feb 05, 2019 2:29 pm
This is just a curiosity post but I always set my desks up the same way, live or in the studio and the track layout on in Reaper usually matches too.
What do you do, and do you change it around or is it always the same?
FWIW I start with drums on Ch1 (kick, snare, hats, toms low to high, overheads) then Bass, Electric Guitar/s, Acoustic Guitars, Keys, Brass (when present) and Vocals (L-R across the stage then any behind). If I have the channels I'll leave a spare between the backline and Vox. Any media players usually at the far right (Ch 15-16)
Re: Track/Channel layout for recording, mixing and live?
PostPosted: Tue Feb 05, 2019 2:39 pm
by Wonks
Sam Spoons wrote:FWIW I start with drums on Ch1 (kick, snare, hats, toms low to high, overheads)
That's a lot of mic inputs on a single channel! :D
PostPosted: Tue Feb 05, 2019 2:44 pm
by James Perrett
I'm the same as you Sam - it is just an old habit that still works for me.
PostPosted: Tue Feb 05, 2019 2:45 pm
You just can't get the staff these days :headbang:
PostPosted: Tue Feb 05, 2019 2:47 pm
by Wonks
PostPosted: Tue Feb 05, 2019 2:48 pm
James Perrett wrote:I'm the same as you Sam - it is just an old habit that still works for me.
Another odd thing I've noticed, while I have the toms corresponding to how I see them, sound guys who play drums have them laid out as if they were sitting behind the kit. Seems logical I guess but leads to confusion if we're sharing a desk........
PostPosted: Tue Feb 05, 2019 2:55 pm
by CS70
Drum tracks, bass, guitar tracks, vox, double vox, other stuff. Vox are generally "right" in the mixer or "down" on the DAW busses, just a habit but I tend to end up with that schema pretty much all the times.
PostPosted: Tue Feb 05, 2019 3:07 pm
by Dave B
My usual one is : Kick, Snare, OH L, OH R, Bass, Guitar, (spare), (spare), Vox1, vox 2, vox3, vox4, keys L, keys R, (spare), click.
This is based on the idea of having 2 8-way stage boxes - front and back. The backline goes into one 'block' and the rest at the front. This is so that if we play a small place and don't need to mic up, we can just use the front box - everything that will always be mic'd up (regardless of venue) goes to the main block.
I tend to work this way with DAW / studio mixers as well. (ok .. keys may come before vox there). It just seems a logical layout to me.
Saying that, at the last live sound gig I did, I found that I'd set up DCA faders and they seemed to be a bit random - I think I went guitars, vox, bvs, keys, (rest) which kind of made sense for the band I was mixing .. but I'm not sure I'd do it like that again.
PostPosted: Tue Feb 05, 2019 10:43 pm
by blinddrew
Hmmm. For the DAW I have templates for each instrument, so vocals, for example, have a main channel, a de-esser channel, a parallel compression channel, two-channels of vca shenanigans to do fader rides from my control surface (see Mike Senior's article here: https://www.soundonsound.com/techniques ... tting-trim), and then a bit of vocal reverb. These all load in together with all the respective sends and plug-ins loaded. Similarly I have drum, bass and reverb templates with various degrees of complexity. These all feed a bus template that always sits on channels 33-40 and goes Vox, Drums, Bass, Guitar 1, Guitar 2, Keys, Candy, Dummy Master. Obviously stuff is only used where necessary but that covers most of my regular bases.
In terms of the templates I tend to be fairly consistent on Vox, Drums, then Bass, but after that it varies. And stuff does get moved around if I've got more than 32 tracks going on and want to be using the control surface as a channel strip.
Live is much simpler as we're playing much smaller venues, so that's Vox 1, 2 and 3, Acoustic, Organ, Kick - and that generally does the trick. On a couple of larger occasions I've added Snare, Bass, electric G1 and G2 as well just to give whoever's on the desk a little bit of control.
PostPosted: Tue Feb 05, 2019 10:47 pm
by blinddrew
Sam Spoons wrote:Another odd thing I've noticed, while I have the toms corresponding to how I see them, sound guys who play drums have them laid out as if they were sitting behind the kit. Seems logical I guess but leads to confusion if we're sharing a desk........
I've seen a few drummer sound guys do this live and recorded and it drives me nuts because it messes with my image in my head of how the music is being played.
I think the argument is that drummers are the only ones who notice this stuff and therefore it makes sense to lay them out like that, but I think that's insulting the musical knowledge of your audience a bit.
Hmmm, it's a long way down from this high horse, mayhap I should dismount.
#firstworldproblems
PostPosted: Tue Feb 05, 2019 11:10 pm
by James Perrett
Maybe I know too many drummer sound people but just about everyone I know (even those who don't play anything) has the smallest tom on the left and the floor tom on the rightmost tom channel. In fact, I can't remember ever walking up to a desk in a venue that was set up in the way you describe. On the other hand, most engineers seem to set up the vocals how they see them.
PostPosted: Tue Feb 05, 2019 11:28 pm
by blinddrew
::: shakes puny fist in impotent rage :::
PostPosted: Wed Feb 06, 2019 12:16 am
Given that we mostly run PA systems in mono having the toms 'back to front' doesn't matter from an audience perspective (if it was stereo it would, obviously) but, if you are setting the vox up 'as seen from the desk' why would you do the drums differently unless you are a drummer and automatically see them from a drummers POV?
PostPosted: Wed Feb 06, 2019 9:43 am
by Bob Bickerton
For live sound I generally have kick/snare/toms L to R as I see them/HH/OH L-R/Bass/Keys/Gats/Horns/Voxes - all left to right as I see them. I do work in stereo depending on the venue (and I do mainly concert work) as I like to create a sense of spaciousness for most people, knowing the balance may be compromised a little for some people.
There is no logic to my mind in assigning tracks from a drummer perspective but then not being a drummer, I have the where-with-all to think logically........... :o :o :o :beamup:
Recording has a similar track setup on the rare occasion I record bands.
PostPosted: Wed Feb 06, 2019 2:18 pm
by Dave B
I've just realised that I'd never considered the drum facing issue before! I tend to work in smaller venues so I only have a stereo overhead pair usually, but even then, I should really make sure that the sound matches the audience or it will be weird...
For recording, I always have drums panned as per the drummer. I've discussed it before with another engineer and I always see a recording as being from the band's perspective.
