RIAA Preamps still needed?
Page 1 of 2
PostPosted: Wed Feb 06, 2019 8:51 pm
by twotoedsloth
Hello,
Sorry for my inexperience, but at work a visiting scholar is requesting a turntable for his guest lecture, so I'm going to have to rent one.
Can anyone please tell me if we will still need an RIAA preamp? I know this was critical in the past, but I honestly have not used a turntable.
Your advice is greatly appreciated.
Peter
Re: RIAA Preamps still needed?
PostPosted: Wed Feb 06, 2019 9:04 pm
by Wonks
Normally, yes. A cheap turntable with a USB output won't, but anything of any reasonabke quality will almost always expect to be used with an amp either with an internal RIAA preamp, or an external unit. And it will also need to match the cartridge type; moving magnet or moving coil.
PostPosted: Wed Feb 06, 2019 9:41 pm
by twotoedsloth
Thanks Wonks.
So a USB output usually won't need an RIAA preamp?
I'm hesitant to invest too much time and money into what is essentially going to be show and tell for stuffy academics and musicologists.
PostPosted: Wed Feb 06, 2019 9:53 pm
by Sam Spoons
I hate to say it but the most likely 'professional' solution is a DJ turntable and mixer. It won't satisfy a 'HiFi' buff but has a decent chance of being reliable and interfacing appropriately with the PA system (I know that's not a given but talk to the hire company techies and they should steer you safely through).
PostPosted: Wed Feb 06, 2019 9:54 pm
by Tim Gillett
twotoedsloth wrote:Thanks Wonks.
Correct, it should already do the RIAA EQ itself.
PostPosted: Wed Feb 06, 2019 10:05 pm
by Sam Spoons
You could probably buy a USB deck for what it would cost to hire a small DJ rig but they are not built for a real live environment. If it's as you describe though it may well be a practical option. I guess it's a judgment call based on the nature of the event........
PostPosted: Wed Feb 06, 2019 10:32 pm
by DGL.
I suppose the other option is to find an old Hi-Fi cheap either via ebay or charity shops, something lower end from one of the Japanese manufacturers should be good enough for most uses, esp. in a less then ideal listening environment, and should be fairly kind on the records (in comparison to most cheap modern turntables).
In theory so long as it's got a magnetic cartridge, it's a decent brand and it some way of adjusting the speed (to ensure it's running at the right speed in each speed setting) it should be fine.
Also get a system with either a tape or aux out (or even at a pinch use the H/P out) and an extra RIAA pre-amp is not needed as there will be one already in the Hi-Fi system.
Even one of the "fake separates" systems should be acceptable for most uses.
Plus when you are done with it you can either keep it just in case or sell it on.
PostPosted: Thu Feb 07, 2019 9:25 am
by ef37a
Yes, go for a "DJ" rig with a fairly rugged magnetic cartridge of medium compliance or one of the USB units.
I have just acquired a Rega Planar turntable and arm with an Ortofon cartridge. I had forgotten how very delicate these things are!
Why couldn't the guy have got his stuff duped onto cassette, MDisc or 'puter?!
PostPosted: Thu Feb 07, 2019 11:12 am
by Mike Stranks
Many turntables these days - irrespective of USB connectivity - have a built-in RIAA preamp so you can connect direct to a standard line input.
But as Dave says, it does seem a strange request. Not sure that I'd want my vinyl tracked by any old stylus at any old tracking-weight. Each to their own...
PostPosted: Thu Feb 07, 2019 11:39 am
by Sam Spoons
Just what I was thinking, I assumed the 'client' was not precious of his vinyl and was using it more for effect than reproduction.
PostPosted: Thu Feb 07, 2019 11:52 am
by Humble Bee
I would need one of those... Can somebody recommend one not too expensive?
Cheers! :thumbup:
PostPosted: Thu Feb 07, 2019 12:43 pm
by Sam Spoons
I'm amazed there isn't an RIAA eq plug-in available (or is there)?
PostPosted: Thu Feb 07, 2019 1:00 pm
by Wonks
There are, but if it's going straight into a PA or mixer, then a plug-in won't be much use.
PostPosted: Thu Feb 07, 2019 1:06 pm
by Sam Spoons
True, I was assuming HB wanted it for transfer or sampling.
PostPosted: Thu Feb 07, 2019 1:12 pm
by Wonks
I was thinking of the OP. But software could be viable for HB.
PostPosted: Thu Feb 07, 2019 1:18 pm
by Humble Bee
Thanks folks.
Just one that outputs line level on jacks or rcf...
Ive seen some cheap ones (£30 ish) but im not sure its worth it.
Local hifi shop prices start at about £150 and thats too much at the moment...
I am landing a pro-ject turntable on sunday...
PostPosted: Thu Feb 07, 2019 1:29 pm
by Wonks
The RIAA circuitry is fairly simple, so it's more down to the pre-amp bit, and it's not that hard to make a good clean pre-amp these days.
Project do their own pre-amp for MM cartridges for about £50 (they also do more expensive ones that also work with MC cartridges).
https://www.amazon.co.uk/Pro-Ject-Audio-Systems-Phono-Preamplifier/dp/B01NCVTR7V/ref=pd_sbs_23_6?_encoding=UTF8&pd_rd_i=B01NCVTR7V&pd_rd_r=597533e6-2ad3-11e9-a1a1-4f2cd90424c2&pd_rd_w=ritng&pd_rd_wg=KND5G&pf_rd_p=18edf98b-139a-41ee-bb40-d725dd59d1d3&pf_rd_r=A4CZF2CYMGP5Z4NSEQF1&psc=1&refRID=A4CZF2CYMGP5Z4NSEQF1
PostPosted: Thu Feb 07, 2019 1:32 pm
by Wonks
ART also make a pre-amp with more controls that can be obtained for a similar price.
http://www.artproaudio.com/product/djpre-ii-phono-preamplifier/
PostPosted: Thu Feb 07, 2019 1:33 pm
by Mike Stranks
This https://www.richersounds.com/hi-fi/audio-technica-lp60usb-silver.html any good?
Has USB and direct to line (on-board RIAA) outputs...
Also available in black...
PostPosted: Thu Feb 07, 2019 1:51 pm
by Wonks
I think TTS needs to tell us more about the type of lecture and as to why a turntable is needed. If it's some old and rare pressing that needs to be played on the highest quality/least damaging player, or just to show the problems associated with vinyl for those who've never heard it e.g. rumble, hiss, pops, scratches and jumping?
If it's for a DJ type demonstration, then they'll need a direct drive, not belt drive, turntable.
