Soundcraft SiExpression mix bus stereo recording
Postby bill_505 » Thu Feb 21, 2019 3:30 pm
I'm using the SiExpression mixboard in the theater i'm working and i want to record the show in stereo because i also use playback audio. I took two output mix buses (mix 1, mix 2), i connected them to my two inputs of my presonus sound board, i panned them left-right, but i still record in mono. Of course i use stereo track in garage band. What i'm i doing wrong?
bill_505
Re: Soundcraft SiExpression mix bus stereo recording
Postby Hugh Robjohns » Thu Feb 21, 2019 5:46 pm
Have you made sure that you really are sending stereo out across the Soundcraft Mix1/2 buses?
Postby Wonks » Thu Feb 21, 2019 6:17 pm
Can you test it with something really obvious like only L channel then only R on the send? If you get a dual mono recording with either of those scenarios, then somethng's gone wrong with the patching.
Postby Bob Bickerton » Thu Feb 21, 2019 9:10 pm
Without referencing the desk or manual (therefore buyer beware) the easiest way to do this is select the main output fader and then select outputs in the menu and the assign the duplicate outputs option to two Mix outputs (1&2 if you prefer, though I’ll often have those assigned to monitors).
This will give you a second set of Left and Right outputs.
Bob Bickerton
http://www.bickerton.co.nz
Postby djangodeadman » Sat Feb 23, 2019 12:22 pm
Or you can use a Matrix and route that to any available pair of outputs.
djangodeadman
Postby bill_505 » Sat Feb 23, 2019 7:32 pm
Bob Bickerton wrote:Without referencing the desk or manual (therefore buyer beware) the easiest way to do this is select the main output fader and then select outputs in the menu and the assign the duplicate outputs option to two Mix outputs (1&2 if you prefer, though I’ll often have those assigned to monitors).
You mean i choose the main LR fader from the menu and i patch the "Patch 02" to mix 1 and mix 2 if i understand?
bill_505
Postby bill_505 » Sat Feb 23, 2019 7:42 pm
If i take the outputs of my stereo channel, the result is to record in dual mono. I have to patch my stereo input in two mono channels, pan them L and R and then i record in stereo. What i don't get is, why from the stereo channel i don't get a stereo recording? Is there something else i have to do with my outputs mix 1 and mix 2?
Thank you for your answers.
bill_505
Postby djangodeadman » Sun Feb 24, 2019 10:07 am
I've edited this to remove a suggestion which, on reflection,, was not relevant.
djangodeadman
Users browsing this forum: Hugh Robjohns, ManFromGlass
