Recoding quality sound mic-mixer-pc
Re: Recoding quality sound mic-mixer-pc
Postby Guest » Mon Mar 11, 2019 12:17 am
ef37a wrote:Possibly but those speakers are rated at 114dB SPL max presumably at the "peak" power input of 600 watts? The mixer is rated at only 150W per channel but even worse, that is into 4 Ohms and the speakers are 8 Ohms and so you can expect a maximum power delivery of 80W, 100W at best.
I did not realize that mixers had anything to do with the out put amplification
This could now cause more problems no when selecting my mixer
But anyway so as not to confuse. Hear is a diagram of the plan again
https://ebayphotos.webs.com/IMG_20190303_234053.jpg
Ps. I should of written on the diagram that the speakers are somewhere around 500/600 watt
Guest
Postby ef37a » Mon Mar 11, 2019 7:39 am
I am not sure I understand your confusion? The mixer is a self contained "mixer/amplifier" aka "powered mixer" and your diagram shows that you get that?
My point was that the maximum SPL given for those speakers might be fine in a rehearsal room but not in a large, absorbent, noisy wedding venue. The other factor is that the speakers will not, it seems to me, be driven to that max SPL because the amplifiers in the mixer are not powerful enough.
Most PA rigs these days AFAICT use mixers with just a line out signal and active speakers with power amplifiers built in. Such speakers are moreover capable of much higher sound levels than 114dB at a mtr.
Postby Mike Stranks » Mon Mar 11, 2019 9:55 am
music master: A bit more on mixer-amps and speakers may help....
You are contemplating buying a set of kit that Thomann has put together to make into a package.
The mixer-amp is capable of delivering a certain output and the speakers are capable of handling a certain output.
The speaker capability is, in your context, irrelevant. It's merely stating how much power that they can handle before they fail. (And I'll return to that in a moment)
What you're interested in - and what people are expressing concerns about - is how much power the mixer-amp is actually generating. Their concern is whether/not the system will be loud enough for the contexts in which you wish to use it. You'll note that the power output stated for the mixer-amp is much lower than that for the speakers. It's the mixer-amp you have to worry about.
The other problem that people are seeking to highlight is that in this context the term 'watts' can be (and is) stated in several different ways. We aren't getting much clue as to what the term relates to here.
A general benchmark (though not without issues) term is 'RMS watts' - let's use the figure of 100.
Then there's 'music-power-watts' which is usually double the RMS, so 200.
Then there's 'peak-music-power-watts'' which is usually four times the RMS, so 400.
We don't know what is actually being quoted so it's hard to establish 'loudness'.
And if that weren't confusing enough there's the efficiency of the speakers themselves that has to be factored in. An inefficient speaker needs far more input power to produce a given loudness than does an efficient one. It doesn't mean that the speaker is 'better' or 'worse' - simply that it's been designed that way. (As an aside. I've used a range of JBL speakers over the years. Lovely sound, but very inefficient so need lots of amplifier power to make them sound loud enough.)
The Phonic mixer-amp looks good in terms of the facilities it offers - especially the onboard recorder. One solution for you might be to build your own system using slightly 'better' speakers and a bigger/more-powerful version if the Phonic mixer-amp - Thomann do sell them.
Postby ef37a » Mon Mar 11, 2019 10:33 am
Mike, I will grant you qualified *&^%$! rms watts but it still grates! (wish I could come up with a snappier alternative to "continuous sine wave power"!)
However I still think the SPL capability of the speakers needs consideration? Quoted as 114dB max and, in the absence of any other information, can we assume that is "peak" (whatever tf that is!) output for the "peak" input of 600 watts?
If so that means the continuous "working" SPL is likely only a bit over 100dB and well below the capability needed in most "party" situations.
Postby Wonks » Mon Mar 11, 2019 10:33 am
Mike Stranks wrote:We don't know what is actually being quoted so it's hard to establish 'loudness'.
For the Phonic Powerpod I'd assume that the 150W pc is RMS or close to it. Anything less would be pretty useless for PA. Phonic quote 100W pc into 8 ohms.
The speakers are 8 ohm rated and have a peak output of 114dB and a 600W peak rating, which normally equates to 150W RMS. Working back, that equates to a basic efficiency of 92dB @ 1W @ 1m. Sounds about right for a cheap PA speaker (£56 each when bought separately)
With 100W input (20dB gain), the speaker will produce a peak SPL of 112dB.
Now that is going to be fine for a quiet acoustic rehearsal session, but isn't enough for any band with drums. A long time ago I did once try to use a Spirit Powerpad (30W pc) with two passive JBL EON 10" speakers for our rehearsal PA (trying not to take the 15" Eons and the Spirit Powerstation 600 for ease of packing and carrying) but it simply wasn't loud enough. That (by calculation) would have produced around 110dB per speaker. 2dB on top of that simply won't cut it once you get drums and electric instruments involved.
Remember that that's at full volume, by which time most PAs don't sound very nice so you'd want to run with some headroom, which makes it even quieter.
So if there's just one or two of you singing with one or two electro-acoustics, then maybe it's OK for a rehearsal, but I doubt it would be any use for gigs unless the audience was very quiet. Trying to get heard in a noisy pub/bar - no way.
Also you are going to need some monitoring when playing live, so you'll probably need at least one monitor, and to save carting a separate amp around, you're best going active. So if you go for at least a basic 12" powered monitor like this T-bone one https://www.thomann.de/gb/the_box_ma120_mk_ii.htm, you'll end up with a monitor that at 120dB peak, is louder than your FOH PA!
The problem with starter kit is that you almost immediately grow out of it. You'll notice its deficiencies within a few weeks, then you'll want something better. And then you find that you've lost at least half the value (if you can sell it).
Postby Guest » Mon Mar 11, 2019 11:35 am
When I went to my local music shop dawsons, I told them the size of venue I had in mind and they said a 500 watt speaker system would do the job
They recommended me the following
Yamaha stagepas 400bt speakers or the 600bt
Yamaha mg06x 2 channel mixer
Guest
Postby Guest » Mon Mar 11, 2019 11:37 am
Hear is the cheapest brand new mixer I could find on eBay
https://www.ebay.co.uk/itm/4-Channels-b ... ect=mobile
The plastic casing makes it look like a 5 year olds toy
Guest
Postby Wonks » Mon Mar 11, 2019 11:44 am
music master wrote:When I went to my local music shop dawsons, I told them the size of venue I had in mind and they said a 500 watt speaker system would do the job
Just reinforces my thoughts regarding Dawsons; trying to sell you an extra mixer when the stagepas system comes with one built-in! :headbang:
Postby Wonks » Mon Mar 11, 2019 11:49 am
music master wrote:Hear is the cheapest brand new mixer I could find on eBay
I agree, and it's probably as useful. However, colour coded knobs and sections do make it easy to find the controls you want more quickly, though this is more beneficial on larger mixers with a lot more controls on.
Postby Mike Stranks » Mon Mar 11, 2019 12:22 pm
StagePAS are good systems and certainly a step up from what you've considered before. Certainly enough for venues where the audience listens and doesn't talk at the same time.
But what would you then do about recording?
Postby Guest » Mon Mar 11, 2019 12:57 pm
Your not telling me that those speakers have a xlr input and a 3.5mm input and will run together are you
Could do with someone selling off a used karaoke set up really
Guest
Postby Sam Spoons » Mon Mar 11, 2019 1:17 pm
The StagePAS 600 mixer is far better equipped than that little Yamaha mixer. You can record from the 'monitor' outputs to your camcorder, a stereo recorder or PC (either the 3.5mm input if quality is not so important or using that cheap AI mentioned earlier for better results). The only downside is if you need a monitor speaker then those outputs are used up (though you could do it with a splitter lead, not ideal but it would work).
The StagePAS600 maxes out at 129dB SPL so not far off the output of a pair of decent powered speakers.
You haven't confirmed a budget for this project yet, only implied from the gear suggestions, nor have you told us what the recordings are to be used for?
Postby Wonks » Mon Mar 11, 2019 1:42 pm
By the time you've bought a Stagepas 600 system, with stands, you won't be far off £800 and you still won't have solved the recording issue.
A pair of Alto TS312 active speakers and stands can be obtained for £573, leaving you a fair amount of money to buy a mixer that can do USB recording and also have some built-in effects (you will want reverb on your vocals). It will be slightly louder than the Stagepas 600 (which does come with some reverb) and be capable of being loud enough for any likely venue.
For a bit less at £515, you could get the TS310s plus stands, which are as loud as the stagepas 600 sysytem, https://www.gear4music.com/PA-DJ-and-Li ... -Pair/2FRU.
You will need some form of basic monitoring on stage. This won't need to be that loud, as you are playing to backing tracks so don't need to overcome drums and backline. You can pay what you want, but something like this should be sufficient. https://www.gear4music.com/PA-DJ-and-Li ... nitor/2IP4
Postby Sam Spoons » Mon Mar 11, 2019 1:52 pm
Good call Wonks, the StagePAS is super simple though and I'm sure that the OP won't mind me saying that he is a bit of a newb WRT this stuff.
Postby Wonks » Mon Mar 11, 2019 2:54 pm
Indeed, though it's not so hot on the monitoring side if you want a different mix to the FOH mix. Also if you use a monitor output for recording, again, you might want a different mix to that out front. Live you'd probably push the vocals up high, which might not sound quite so good when recorded and played back at normal levels.
Adjustable monitoring might not be an issue now, but in two years time it may be, which leaves you at a bit of a dead-end with the Stagepas unless you add a separate mixer and feed that into the Stagepas' mixer, which leaves you with a system that is now functionally similar to what you could have started with but for less money, (albeit slightly more complex than the Stagepas on its own). Why couldn't they have provided even just one proper aux send on the Stagepas? It would make it a lot easier to recommend.
