How to record from mixer to computer
Page 1 of 2
PostPosted: Thu Mar 07, 2019 11:31 pm
by Hugostar
Hello everyone, I am happy to be here.
Please how can I record a good quality sound from my Allen&health gl2400?
Re: How to record from mixer to computer
PostPosted: Fri Mar 08, 2019 5:45 am
by Guest
I have a similar thread to this myself. An easy answer would be to run usb from mixer to pc
PostPosted: Fri Mar 08, 2019 8:23 am
by The Elf
You will need an audio interface. The AI will need sufficient inputs to accommodate the number of separate signals you would like to record. After that you can connect the mixer in a number of ways, so we will need a bit more information on what you're hoping to achieve.
But then you have to ask yourself, if you need the audio interface anyway, to which you can connect instruments and microphones directly, do you need to go via the mixer?
PostPosted: Fri Mar 08, 2019 8:58 am
by ef37a
That is quite a sophisticated mixer and as Elf say, any recommendations depend upon the precise use you intend for the recordings. A stereo mix or do you want to record each channel to a separate track?
Did you get the mixer from new? That could be important because it has a multitude of internal jumper routing options and if another party has been frigging around in there you will go loopy chasing signals!
If you don't already have it, download the manual from A&H and spend an evening on some intense reading.
PostPosted: Fri Mar 08, 2019 10:14 am
by Janneman
Recording via direct-out to a interface with enough inputs.
PostPosted: Fri Mar 08, 2019 10:28 am
by ef37a
Janneman wrote:Recording via direct-out to a interface with enough inputs.
I suppose the logical answer is the ICE-16?
PostPosted: Fri Mar 08, 2019 11:22 am
by Mike Stranks
That's making an assumption that we know exactly what the O/P wants to do... he may just want a simple stereo mix; he may want to record off the back of a live performance etc.
So O/P... and welcome by the way! What exactly is it you want to do?
PostPosted: Fri Mar 08, 2019 12:31 pm
by Hugostar
Hello friends, I am so happy with this forum, as so many are giving their solution to he'll me out.
I think I need to make it clear here of what I really want.
I connected my audio cable from my Allen&Health GL2400 "monitor output" to my PC "audio input"...
After capturing the audio with my "Adobe Audition"...the play back does not carry the keyboard, drums etc...all I can hear is the only the mics "voice".
So my problem here is how will get all the sound into my "PC"? That having a complete stereo sound.
Meanwhile, my audio line is only from 1 monitor line, could it be the problem?
PostPosted: Fri Mar 08, 2019 12:42 pm
by Hugostar
Yes my brother, I guess you are right.
What I need is a simple stereo mix...just to record all that comes into the mixer to my PC.
Note: Amy using ADOBE AUDITION as my capturing software.
Thanks alot for your response.
PostPosted: Fri Mar 08, 2019 1:05 pm
by ef37a
"What I need is a simple stereo mix...just to record all that comes into the mixer to my PC."
Right! Super cheap but actually passing decent, Behringer UCA 202, after that the sky's the limit depending on the level of quality you want.
Do be aware that at approximately the £100 point for a 2 in 2 out interface they are of incredible good audio quality and you would have to spend ten time that to get a paper spec that was significantly better and even then, depending on the source material and monitoring quality, you would likely never hear a difference.
PostPosted: Fri Mar 08, 2019 1:13 pm
by The Elf
+1
And I would suggest using the 2-track ('2TRK OUT') outputs from your mixer to connect to the audio interface, rather than the monitor outputs. That should simplify things for you, but read the manual to make sure you are sending the right signals to the output.
PostPosted: Fri Mar 08, 2019 4:07 pm
by Hugostar
Someone is suggesting that I should buy an external sound card.
Is it necessary to buy an external sound card before I could record from my mixer to my PC, considering my HP ENVY came with a good strong inbuilt sound card?
Honestly am getting confused right now...
Why can't I hear the drums, the keyboard, guitar, etc after recording...all I always hear is the voice ( very clear)
PostPosted: Fri Mar 08, 2019 4:50 pm
by Sam Spoons
The GL2400 is a nice mixer but is fairly sophisticated so there are a few ways you could be losing some channels on the recording. It's a while since I used a GL desk (I had a GL2200 for a couple of years) so I'll try to scan the manual later.
Where are you recording from? As Elf says the 'two track' outputs will be best as they always follow the main outs. Can you hear the other instruments on headphones when recording? If you can then recording should also capture them. Is it a balance problem? Are the other instruments there but very quiet? Are they electronic or live instruments captured with microphones? Is this a recording of a live gig or a 'studio' session?
The sound card in your HP Envy will be ok for casual listening and may good enough for your recordings but it will be markedly inferior to even a cheap audio interface like the one Dave suggested. But it should be recording whatever is coming out of your mixer so the problem is with something your are doing on the mixer.
PostPosted: Fri Mar 08, 2019 4:55 pm
by ef37a
Hugostar wrote:Someone is suggesting that I should buy an external sound card.
Yes, you could use the HP laptop's internal card but, although PC cards can be very good for replay (digital to analogue conversion) and this HP g6 i3 upon which I am typing is one such, they can be a right PITA to use for recording, mainly due to the fact that they only accept very low levels and tend to have too much gain and introduce noise.
You could just buy a cable, one end 3.5mm Stereo jack and split out to two 1/4" mono jacks (aka TS, same as on a guitar cable) . Then you need to frigg about with Windows sound settings to crank down the gain. Even so you will probably find the mixer will overload the min jack input. You will do no harm but it will sound bad. The cable will only cost a few quid so worth a try.
Got to go for a mo' I am sure someone will give you a link to that cable.
PostPosted: Fri Mar 08, 2019 5:02 pm
by Sam Spoons
I assume hugostar already has the cable as he is recording to his laptop from the 'monitor' outputs.....
