recording an old piano with only an aux out (mono or stereo?)
Re: recording an old piano with only an aux out (mono or stereo?)
Postby Sam Spoons » Fri Mar 15, 2019 10:57 am
99% certain a phono/RCA 'jack' that you need, see above for pic.
Postby alexhedleymusic » Fri Mar 15, 2019 10:58 am
https://www.google.co.uk/search?q=yamah ... nFrKOrDAtM:
they look almost identical to this. i know this is a bit different to the original post i posted but i just checked again and they have that silver bit on them like the ones in this. they look very similar if not identical to this
alexhedleymusic
Postby alexhedleymusic » Fri Mar 15, 2019 11:11 am
Sam Spoons wrote:99% certain a phono/RCA 'jack' that you need, see above for pic.
https://www.gear4music.com/G4M/Jack-Pho ... DMQAvD_BwE
so one of these?
also dont know if this helps but the mini jack from my headphones doesnt fit in the aux out so that means it will be one of these right? as a normal aux cable for like ipods etc is the same as mini headphone jack?
alexhedleymusic
Postby Wonks » Fri Mar 15, 2019 11:14 am
I'm finding it impossible to find a single male RCA to 1/4" TS jack, but this has two of them for a low price.
https://www.stagedepot.co.uk/essentials/signal-data-cable/line-cable-audio-adapter/stagg-high-quality-line-cable-2-x-14-mono-jack?sku=ST-STC060PCM&gclid=CjwKCAjwmq3kBRB_EiwAJkNDp0zIP0HpLe17mEDq0NhZuwBWjBD9nTMLQ9KvlV_3zKIES3wgzfIEnhoC_tMQAvD_BwE
You'll probably want to pick the 3m or 6m option from the selection box.
Postby alexhedleymusic » Fri Mar 15, 2019 11:19 am
Wonks wrote:I'm finding it impossible to find a single male RCA to 1/4" TS jack, but this has two of them for a low price.
thank you!. would this one be the same also? only i know from gear for music i should be able to get it tomorrow. was planning on starting tomorrow :)
alexhedleymusic
Postby Hugh Robjohns » Fri Mar 15, 2019 11:19 am
Something like this:
https://www.amazon.co.uk/Twin-Phono-6-35mm-Jacks-Cable/dp/B005JKYI86/ref=sr_1_3?s=electronics&ie=UTF8&qid=1552644837&sr=1-3&keywords=RCA-phono+to+quarter-inch+jack
Obviously, you'll need to buy something of an appropriate length. And, as I said before, all the cables of this type will be supplied in pairs. Some will be two physically separate cables, and some will have the cables fixed to each other (as the example above is -- although it's usually quite simple to split them if that's what you need).
There are many different brands and suppliers -- the above is just an example, not a specific recommendation (although I'm sure it would be fine).
The only thing to beware is that a lot use RCA-Phono plugs with bulky bodies that may not fit nicely onto the keyboard socket if it is recessed. The ones shown above have a long outer metal sleeve which should fit nicely on a recessed socket.
Postby alexhedleymusic » Fri Mar 15, 2019 11:20 am
forgot the link
alexhedleymusic
Postby Hugh Robjohns » Fri Mar 15, 2019 11:22 am
alexhedleymusic wrote:Image
Yep. Definitely RCA-Phono sockets.
Postby Hugh Robjohns » Fri Mar 15, 2019 11:25 am
Yes. That would be ideal -- and you'll be able to peel the two sides apart easily so you have two separate cables if that's more convenient.
Yes. Definitely not a 3.5mm mini-jack socket. Definitely an RCA-phono socket.
Postby alexhedleymusic » Fri Mar 15, 2019 11:27 am
Hugh Robjohns wrote:Something like this:
https://www.gear4music.com/G4M/Stagg-2- ... ad-3m/1W4G
would this one be ok. i can get it tomorrow if i do it from gear for music :)
alexhedleymusic
Postby alexhedleymusic » Fri Mar 15, 2019 11:31 am
awesome thanks so much for your help! final question i thnk ha ha
alexhedleymusic
Postby Hugh Robjohns » Fri Mar 15, 2019 11:32 am
YES! :D
Postby blinddrew » Fri Mar 15, 2019 3:51 pm
Postby Hugh Robjohns » Fri Mar 15, 2019 4:10 pm
:lol:
Postby jimjazzdad » Sat Mar 16, 2019 11:53 am
I have to say that there probably isn't another place on the 'net where a 'noob' can get such excellent help from knowledgeable and patient mentors...good on ya Hugh, Sam, Drew, Wonks et al!
jimjazzdad
Halifax, NS, CANADA
Postby alexhedleymusic » Sat Mar 16, 2019 3:24 pm
jimjazzdad wrote:I have to say that there probably isn't another place on the 'net where a 'noob' can get such excellent help from knowledgeable and patient mentors...good on ya Hugh, Sam, Drew, Wonks et al!
:geek:
alexhedleymusic
