RichardT wrote:Tomster wrote:blinddrew wrote:Depends if you stuff the closet with rockwool first. ;)
It's basically eaves space that contains boiler and tank. It's pretty deep. I could put fluffy insulation behind the tank and probably put a decent size bass trap in front of the tank and behind /around the subwoofer.
I’m no expert, and I’m sure others will weigh in if I’m wrong, but I have though you would want as little sound as possible to get into that side space. It will only cause you problems. Some kind of door seals would help, keep the door shut, and put the subwoofer away from the door.
I have no idea if you are right or wrong but why do you think that?
I was planning to seal it actually - I even have the seals here :-)
