Rockwool distribution- corners vs walls?
Postby Nyiregyhazi » Tue Apr 02, 2019 4:36 pm
Having been getting way too much boominess in my tiny room (with a 6ft grand piano taking up well over half of both the length and width of the room) I've bought a whole load of rock wool to start putting around. I've got four slabs of the 4 inch thickness at 45kg/m3. So far I've tried putting one slab in a duvet cover and propping it up on the corner which the piano goes in, from the lid to ceiling. I presume this would be my most important corner of all? Just one slab already seems to clean up the lowest octave plenty, although not so much the octave below middle C (which seemed the worst register in recordings).
Having read loads of different threads, I'm wondering now about the best distribution. To be honest, the room actually sounded fine to me from my playing position although the boom was severe when recording, even inside the piano lid. In a sense I don't necessarily want to make the room overly dead (full on dead clarity isn't the most satisfying thing for everyday practise), but just do what I can to avoid really ugly distortions. Anyway, the consensus seems to be that corners are the way to go for bass accumulations, but I've also read threads like this where they are just hung from walls.
https://www.gearslutz.com/board/bass-tr ... piano.html
I'm probably in a position now where anything I did would be significantly better than nothing, but I'd like to get some idea of where my main focus should be. The room is small enough that there's no way I can stack triangles up in corners, so I'm looking at either positioning four whole slabs, or potentially breaking them into something the size of a pillow or so- in which case I could take every upper and lower corner and potentially even double up to an 8 inch thickness. I've seen a lot of pictures where people just hang a slab in the middle of corner walls, but surely it's better to have a smaller slab in each three way corner, than a longer slab running in the middle of where the two walls meet? Either way, I couldn't run a single slab in the middle of the corner with the piano, as it's right against the wall, but I could go with a pillow sized amount in both upper and lower ends of the corner.
I've also got a hard tiled floor and was wondering both about putting one whole slab directly under the piano (vs leaving an old duvet underneath, at the moment) or whether I should also run big slabs on the wall in addition to/ instead of taking out all corners? As I say, I don't need to kill the reverb outright, so maybe I'm better off sticking to the corners but having some additional shaped foam elsewhere?
Nyiregyhazi
Re: Rockwool distribution- corners vs walls?
Postby Sam Spoons » Tue Apr 02, 2019 4:59 pm
Any you put in will help improve the sound, corners mean the slabs are spaced off the wall an attenuate/absorb to lower frequencies. As you rightly say you don't want the room too dead so as many corners as it practical first (and they don't just need to be vertical corners, between the floor and wall and wall and ceiling where possible is effective too). Then, if you are listening/mixing on speakers setting some at the 'mirror points' is good, if it's just for playing/recording then the points where the first reflections of the piano come from are good, over the piano, on the wall facing etc help to tame flutter echoes and such like.
Postby Nyiregyhazi » Tue Apr 02, 2019 5:14 pm
Thanks, yeah, it's largely for the recording. I'm not so worried about optimising the play back (as I listen on headphones for editing). I'll probably just start with the corners then and see if I need an extra slab for the wall opposite the lid.
Any thoughts on the walls adjacent to the piano? I know people say you shouldn't have the piano right against them, so I'm not sure if deadening around the piano is notably useful in relation to this problem, or if it's better to just concentrate on where the sound is pointed out from the lid?
Nyiregyhazi
Postby Sam Spoons » Tue Apr 02, 2019 5:22 pm
The sound of the piano doesn't come only from under the raised the lid, the whole instrument radiates sound, but the open lid does give some directionality to the higher frequencies/overtones. Mic position and some sound absorbing around/behind the mics can help clean up the recorded sound. If you make the panels moveable initially you can experiment to find the best places before fixing them into place, a small room is always going to be a little bit 'suck it and see'.
Postby Hugh Robjohns » Wed Apr 03, 2019 10:38 am
Nyiregyhazi wrote:Having read loads of different threads, I'm wondering now about the best distribution. To be honest, the room actually sounded fine to me from my playing position although the boom was severe when recording
You'll probably find that your head, when playing, happens to sit in a standing wave node so doesn't receive the bloated bass that occurs elsewhere in the room due to the standing waves. But the microphones end up in an antinode... Also, you ears/brain are much better at compensating for or ignoring uneven room responses, but mics can't.
This is a very common problem, though, especially in small rooms.
I'd start by putting your rockwool in the four room corners... but this kind of problem is notoriously difficult to treat well and considerable experimentation may be required. After the corners, it may be worth putting panels on the long wall opposite the piano, and possible on the ceiling.
Also, avoid placing too much absorption near (or under) the piano. It can quickly dull the sound.
Postby Nyiregyhazi » Wed Apr 24, 2019 11:46 pm
Thanks for all the thoughts. I've made a total of 9 pillow sized lumps now, some in material but most of them still just in clingfilm. I haven't mounted any to the ceiling corners yet, but even just getting the floor corners is making a sizeable difference.
Any thoughts on the results here? I used the very cheap Neewer omni mikes inside the piano lid, with some editing with stereo butterfly to narrow the stereo image a little.
https://drive.google.com/file/d/1znVwmS ... p=drivesdk
https://drive.google.com/file/d/1YpUxdp ... p=drivesdk
The first is with a medium room fake reverb and the second the unedited dry results (which I hate but may be more useful to judge from) Please excuse the shoddy playing (complete with a stop, where my page turning pedal skills let me down).
I've never used EQ, but it's very clear at the start that the A flat below middle C has quite some boom to it. It particularly seems to be the octave or so below middle C that swells up in general. Do you think the sound is close enough now to do a little fine tuning via EQ, or should I concentrate more on the room first? I've got one large slab left still, so I'll probably figure out a way to mount it opposite the piano lid in future.
Also, here's a recording that I did before the rockwool and a brief clip of the same following treatment.
https://drive.google.com/file/d/1F2EtYY ... p=drivesdk
https://drive.google.com/file/d/1kpz5-Q ... p=drivesdk
It's come on a long way, but the remaining boom is still pretty annoying where it remains.
Nyiregyhazi
Postby Ariosto » Thu Apr 25, 2019 9:41 am
My quick listen made me think that I prefer the Mahler (last two recordings) which has no rock-wool treatment! However, even then the lower octaves are very muddy and dim so that is where the treatment needs to work. I'm afraid I did not like the sound at all where you had treated the room! But the use of the sustain pedal has a big bearing on the overall sound so maybe you should bear that in mind, although I'm not a pianist myself, so maybe I'm talking rubbish. In the room treatment examples I thought the mid and upper ranges sounded rather hard in texture, so maybe the top octaves in that treated acoustic are too dry?
Ariosto
Postby Nyiregyhazi » Thu Apr 25, 2019 11:08 am
Interesting. If anything I think it way be too little treble damping causing an overload. The room is tiny (probably about 9 foot by 9). At the moment most of the rockwool is in cellophane which should theoretically bounce the treble back rather than absorb much. I didn't hang a duvet in the wall for this, so I'll have to try it both ways and check.
The thing I've found is that it's usually easy to get a clear treble and much harder to get clarity on lower registers. For that reason I was miking much further away from the highest strings for a while, but finding the sound very murky. I think I may have overdone it in response to that and put the microphone a little too near the upper strings.
Are there any suggestions for good reverb plugins? My ideal is to get a clear sound in the room but then put some life back into it. I get what you mean about liking the original recording more, but I do find the boominess of the small room very annoying. It's still there at times in the treated recording but it's not swallowing so many details. With the stock audacity reverb it hits a point where things sound extremely fake, by the time I go past medium room settings. I think I'll have to see if I can find a better one, to put some more ambience back into a dryer source recording.
I'll try backing off a little with the treble Mike for now and check whether a duvet helps to take the edge off the treble.
Nyiregyhazi
Postby blinddrew » Thu Apr 25, 2019 1:09 pm
Nyiregyhazi wrote:Are there any suggestions for good reverb plugins?
Have a shufti at this thread: https://www.soundonsound.com/forum/view ... 15&t=65465
Postby Nyiregyhazi » Thu Apr 25, 2019 11:58 pm
Cheers, looks handy. Am I right in thinking that most paid plugins come with a free trial, by the way? I remember trying something before, where I was hoping for a kind of magic that didn't transpire and the trial was really helpful. I wouldn't want to spend big bucks on reverb but, while free is always nice, I'd happily drop a tenner or two for a notable step up (if I could check the result first).
Nyiregyhazi
Postby blinddrew » Fri Apr 26, 2019 10:42 am
It really varies by manufacturer, the thing to do is (and this is just my personal approach with pretty much all plug-ins) try and figure out what kind of reverb you're after before you start disappearing down the rabbit hole of demos, trial versions and everything else. Otherwise you can spend a loooong time going round in circles and end up back where you started. :)
Postby Nyiregyhazi » Mon May 06, 2019 2:52 am
Are there any good threads on checking out the frequencies of a room, with a view to finding an EQ to try soften the remaining boomy frequencies? I've read a little about monitor microphones, as well as playing pink noise. At first I was thinking I couldn't really do this, seeing as I don't have a flat mike. But then it occurred to me that I'd be doing the EQ on recordings with the mikes I have rather than flat ones. So, presumably it's more useful to know the specific imbalance caused by the blend of the room and my mikes, rather than to get a flat mike and isolate the exact room imbalance? I think this makes sense, although I can't rule out a logical misstep.
Nyiregyhazi
Postby blinddrew » Mon May 06, 2019 9:38 am
The logical misstep is that you're treating the room for play back as well as recording, so unless your speakers have exactly the same frequency response as your mic... ;)
If you can find the response of your mic published somewhere you can use that as a rough guide though.
Say it's a fairly typical LDC with a broadly flat response from 50Hz to 17kHz other than a gentle presence boost in the upper mids, you can factor that boost back into your measurements fairly easily.
Chances are the areas you most need to be focusing on are lower down the range and, if your room is a typical average-size, untreated, domestic room, then you'll be seeing some big old variances in the lows and low-mids as the room modes dominate.
There was a good article on diy room treatment in last month's magazine. Worth £1 for the pdf if you haven't seen it. :)
Postby Nyiregyhazi » Mon May 06, 2019 12:36 pm
Do you mean for general listening playback on speakers, or that speakers tend to imbalance the pink noise output plenty for themselves? I can use headphones for editing, so I'm not really concerned by getting a good room sound for playing back through speakers. If I do use a speaker, my priorities would just be about assessing my playing at that point, rather than to assess the sound quality.
I've already got a lot of rockwool around the room, so I'm not necessarily concerned about knowing the room's natural state. The idea now is simply to try to isolate which frequencies are still picking up the remaining boom on recordings and see whether I can fix what's left with EQ- to avoid having to add any further treatment.
Basically, I largely just need to know whether running a spectrum test through my normal mike (in the room as currently treated) would give me what I need to figure out a decent EQ adjustement on the recordings. I don't necessarily need to know how the room would be without a microphone bias- unless this screws up the previous goal.
Nyiregyhazi
Postby blinddrew » Mon May 06, 2019 12:43 pm
ah right, if you're just interested in the audio capture side of things that's a different ball game. The first thing to do is try different places in the room for the mic and the instrument (or source if you have a speaker you can move around for pink noise). You'll need to experiment really though.
Once you've got the sound as good as you can through instrument and mic positioning you'll probably find that EQing will be much less problematic and largely a matter of taste rather than correction. Though you might still find resonant frequencies that are distorting things heavily at the low end - these should be fairly easy to identify sonically and visually on the EQ display though.
Unless I'm still misunderstanding your challenge?
Postby miN2 » Mon May 06, 2019 2:11 pm
You can use REW to check the response of your room https://www.roomeqwizard.com/
You can buy something like this for measurement purposes (which is a steal for £28 in my view) https://www.amazon.co.uk/Behringer-ECM8 ... op?ie=UTF8
Then you can shift your treatment around and measure again to find out what each is doing in their current placement.
miN2
Postby Nyiregyhazi » Mon May 06, 2019 3:54 pm
blinddrew wrote:ah right, if you're just interested in the audio capture side of things that's a different ball game. The first thing to do is try different places in the room for the mic and the instrument (or source if you have a speaker you can move around for pink noise). You'll need to experiment really though.
Yeah, it's a particularly small room, so I don't think I'll get much better than by miking pretty close. I put some audio samples earlier in the thread, with a couple before and after treatment.
I'm basically looking to get a head start on figuring out an EQ adjustment to catch the frequencies that are imbalanced in what I'm capturing so I can balance out the recordings (rather than looking to worry about whether a flatter mike would show a slightly different imbalance) Does that seem feasible from the source material?I don't want to cut the wide areas of bass down, so I'm hoping to try and catch a precise sense of what needs toning down on a more detailed graph. I tried a little with trial and error (I can tell that one or two specific notes have notable issues) but I think I'd probably waste a lot of time trying to do it all by ear, without a sense of where to look.
Nyiregyhazi
Postby Nyiregyhazi » Mon May 06, 2019 4:06 pm
miN2 wrote:You can use REW to check the response of your room https://www.roomeqwizard.com/
Thanks, does my theory make sense though- that I'd actually learn more from seeing the imbalance that results after going through the mikes I'll actually be using? It seems to me that I'd be better off bunging all the imbalances in together, than trying to isolate the room alone- given that my recordings will be involve both room and microphone imbalance combined. This makes the most sense to me in theory, although I may be overlooking something.
Nyiregyhazi
Postby miN2 » Tue May 07, 2019 1:04 pm
No, i don't think it makes sense if you're trying to control your room since if you want a reading of your room in an effort to tame it then you need the reading of the room. You don't actually need to measure the room, but you expressed an interest in knowing the frequencies of a room and REW gives you access to this sort of information.
If you don't like the sound of your mic then change it, don't try and acoustically treat your room to offset its tone.
miN2
Postby Nyiregyhazi » Tue May 07, 2019 6:41 pm
miN2 wrote:No, i don't think it makes sense if you're trying to control your room since if you want a reading of your room in an effort to tame it then you need the reading of the room. You don't actually need to measure the room, but you expressed an interest in knowing the frequencies of a room and REW gives you access to this sort of information.
It's all with a view to improving recordings though. I didn't say I need to monitor the room in isolation, but that I need to be able to improve on the imbalances that are in the recording (regardless of how they divide up between room and microphone). I don't follow what the benefit would be of getting an isolated impression of the room, when the imbalances I'll be needing to fix on the recordings will be those of room plus mike combined. If I'm missing something I'm definitely interested in the explanation, but I'm not following any reason to separate these factors out, only to have to combine them once again. Surely the only effect of using a flat monitor mike is that I'll be taking something away, that I need to add back in to the consideration when balancing recordings made with a non-flat mike?
I didn't say anything about disliking the sound of the mike or that I'm trying to change the room instead of the mike. I've simply recognised that there are some remaining imbalances on the recording that likely need EQ. Having already put plenty of treatment in the room, I'm now looking for the quickest and most direct way to get a sense of which frequencies to aim the EQ at. I have no doubt that it's still chiefly a room issue, but I'm not seeing the reasoning for using a method which would factor out any contribution from the very same microphone that I'm going to be recording on anyway. Taking it's effect away and then having to put it back is surely not required?
Nyiregyhazi
