Sound Devices Scorpio
Postby wireman » Sat Apr 06, 2019 10:56 am
Sound Devices are bringing out a new 32-channel mixer-recorder, now available for pre-order.
  • 16 mic/line imputs (6 on full-sized XLR)
  • Records to SSD and SD cards
  • Timecode
  • Unusual mix of connectors (Hirose 10-pin ?)
wireman
Re: Sound Devices Scorpio
Postby Dan LB » Sat Apr 06, 2019 11:36 am
Nice. Looks expensive. :beamup:
Link: https://www.sounddevices.com/scorpio/
Dan LB
Postby Hugh Robjohns » Sat Apr 06, 2019 11:41 am
That looks like a beast of a machine!
Postby wireman » Sat Apr 06, 2019 12:35 pm
Dan LB wrote:Nice. Looks expensive. :beamup:
Thanks, I was too subtle, I tried to make the picture a link but it has not worked properly.
wireman
Postby Hugh Robjohns » Sat Apr 06, 2019 12:36 pm
You were... especially as the linking doesn't work! :lol:
Postby Wonks » Sat Apr 06, 2019 12:42 pm
Here are some of the other pics.
Postby Kwackman » Sat Apr 06, 2019 12:52 pm
Whats' the antenna for?
The manual says the Antenna " Connects to inducted external antenna for Bluetooth LE."
Is that for remote(App) control?
Kwackman
Postby wireman » Sat Apr 06, 2019 12:59 pm
Kwackman wrote:Whats' the antenna for?
From the FAQ:
What does the antenna connection do?
In the near-future the antenna will be used to connect the Scorpio via Bluetooth to SD-Remote, the companion application for Android and iOS.
wireman
Postby Mike Stranks » Sat Apr 06, 2019 5:34 pm
Ah! So that's it....
I'd heard in the week of something new from SD... again, it's being launched for/at NAB...
Mike Stranks
Postby forumuser840717 » Sun Apr 07, 2019 12:51 pm
Hugh Robjohns wrote:That looks like a beast of a machine!
With a projected (US) price around $9K it would need to be! And the TA5 connectors are a flippin' pain to solder and don't really accommodate any proper two channel cable I can think of. Mini starquad as a compromise maybe.
There again, it's a fair bit cheaper than a Cantar X3 and records more tracks. Though the Cantar is still an amazing bit of kit and beautiful to use.
forumuser840717
Postby audio_fre@k » Tue Apr 16, 2019 10:02 am
we are looking forward here in Germany to test that beast! :bouncy:
have been using 664/633 for years, also got mixpre-3 for the small portable interviews and nothing could possibly beat SD! Those preamps and analog limiter is something that's makes me very horny :oops:
audio_fre@k
maybe you want to check film sound berlin
Postby John Willett » Tue Apr 16, 2019 2:06 pm
audio_fre@k wrote:...nothing could possibly beat SD!
You have never tried a Sonosax then. :thumbup: :bouncy:
John Willett
Postby audio_fre@k » Tue Apr 16, 2019 2:13 pm
..honestly never had one around to play with, maybe one day! Any highlights you could share plz? :thumbup:
audio_fre@k
Postby John Willett » Tue Apr 16, 2019 6:28 pm
Sonosax are simply the very best of the very best - extreme top quality without compromise.
I know somone who is a Nagra extreme fan and is now selling his Nagra and has gone over to Sonosax.
Details HERE
Be prepared to drool :tongue:
John Willett
Postby Bob Bickerton » Tue Apr 16, 2019 9:01 pm
Details HERE
Can’t see they have a 16 channel unit (preamps plus tracking) ........
Bob Bickerton
http://www.bickerton.co.nz
Postby wireman » Tue Apr 16, 2019 9:27 pm
John Willett wrote:Sonosax are simply the very best of the very best - extreme top quality without compromise.
Well, the power adaptor does not look like it was made without compromise to be the best quality for the UK market and you have to use it...
"Connect the SX-R4+ Recorder only to the optional external power supply delivered by SONOSAX"
I would prefer the Dell type with country specific plug to clover on the brick or the Sound Devices ones with IEC.
wireman
Postby John Willett » Wed Apr 17, 2019 11:15 am
It's a battery powered device with the power adaptor used to charge the battery.
It does have country-specific interchangeable plug-heads that lock in place on the "brick" (as you can clearly see in the picture) and the connector to the device is a lockable Hirose connector that won't easily pull out.
A properly engineered solution as I see it.
John Willett
Postby ronmac » Wed Apr 17, 2019 11:51 am
edit to remove pre-coffee post...
ronmac
Turn the knobs 'til the music moves ya.
Postby blinddrew » Wed Apr 17, 2019 12:29 pm
ronmac wrote:edit to remove pre-coffee post...
Should be a standard button for me. :)
Postby IronFilm » Thu Apr 18, 2019 6:41 am
I WANT! So many great things about Scorpio
But outside my price range.
So I'll wait for a mythical "Scorpio Micro" which has all the goodness of Scorpio but with lower track count and lower price?
IronFilm
Next
Users browsing this forum: DC-Choppah
