And now... the Zoom F6!
Re: And now... the Zoom F6!
Postby IronFilm » Thu Apr 18, 2019 6:38 am
The Elf wrote:Clever stuff! Really hope this idea drops down to an H4/5 format.
I'd imagine that Zoom will update their H series eventually. As their F series pre amps are MUCH better than in the H series.
IronFilm
http://IronFilm.co.nz/Sound/
https://www.youtube.com/SoundSpeeding
Postby Mike Stranks » Mon May 27, 2019 10:37 am
A good first-look review. Worth viewing for it's explanation of gain-staging and the demo of the incredible dynamic range that the F6 can handle with ease.
https://www.youtube.com/watch?v=y4oNd1RgGL0
Mike Stranks
Postby Hugh Robjohns » Mon May 27, 2019 11:05 am
It's an ugly brick of a thing isn't it? And that power button looks both awkwardly and vulnerably placed -- although that's a complaint that's often levied at manufacturers and usually turns out to be unfounded... so I'll wait til I get my hands on a real one before forming a proper view.
The recording tech is clever, and will make life much easier -- and deliver more usable recordings -- for amateurs who don't understand gain staging. But it does make a lot more more work in post-production of course to wrangle sensible levels out of the 32-bit float file.
So in the pro-world it will be a great thing for assistant producers doing single-camera fly-on-the-wall doco-shoots without a proper crew....and it's another nail in the coffin of professional sound recordists. :-( Just have to hope they point the mic the right way...
Clearly very feature-rich, which is good, but it's tiny... tiny... tiny.... and looks pretty fiddly to use.
Postby The Elf » Mon May 27, 2019 1:39 pm
I'm blown away by the A/D technology, but this looks more like a concept design than anything that would make it into production.
Half an hour up on the Yorkshire moors and there's not a set of fingers in the world that will be able to manage those knobs and buttons!
Watching with interest...
Postby Hugh Robjohns » Mon May 27, 2019 2:23 pm
Pretty sure that is as close as makes no difference to the full production unit.
Thankfully, the only buttons and knobs you need to fiddle with are the record and stop buttons. Assuming it's been set up sensibly, everything else will take care of itself.... or so they claim!
And clever though the tech is, I doubt the performance would be significantly different in practice from just recording with a generous headroom margin on a current 24 bit machine. The overwhelming element that defines the recorded noise floor will be the acoustic noise into the mic, not the preamp/converter noise -- and by a massive margin.
When recording live action stuff with very wide and unpredictable dynamic ranges and high peak SPLs, I often just set the preamp gain very low so that the ambient noise level is around -60dBFS or so on my Nagra VI (or even lower if the expected peak noise is nearing painfully loud), and then let whatever happens, happen... Seems to get the job done with no fuss, no overloads, and no noise problems in post-production.
Who needs 32-bit float? :D :wave:
Postby miN2 » Wed May 29, 2019 7:19 am
I'm still impressed by this thing, maybe that's down to my ignorance and lack of experience of hardware mind.
Would it be possible to isolate each converter individually to a seperate audio file? This would allow capturing the quiet sounds in a loud environment?
miN2
Postby Hugh Robjohns » Wed May 29, 2019 8:04 am
No.
Users browsing this forum: Scouser
