And now... the Zoom F6!
Re: And now... the Zoom F6!
Postby The Elf » Wed Apr 10, 2019 8:55 pm
Postby Hugh Robjohns » Wed Apr 10, 2019 9:06 pm
wireman wrote: I presume that Zoom are aware of Zaxconn patents ...
I presume Zaxcom are aware of Neumann's patents... ;-)
https://patents.justia.com/patent/6707402
Method for converting an analog signal to a digital signal
Patent number: 6707402
Abstract: With a method for converting an analog input signal (S1) to a digital output signal (S7), the analog input signal (S1) is amplified in a first signal path (2, 3, 5) and is subjected to an analog-to-digital conversion (5). In a second signal path (4, 6), another analog signal (S4) is obtained for transmitting larger signal amplitudes and is subjected to an analog-to-digital conversion (6). The signal (S5) digitized in the first signal path (2, 3, 5) and the signal (S6) that is digitized in the second signal path (4, 6) are fed to a digital signal processor (7), which generates the digital output signal (S7). To avoid an abrupt reduction in the signal resolution and achieve the highest possible dynamic scope, it is suggested that the analog signal fed to the second signal path (4, 5) be distorted non-linear and counter to the amplified analog signal (S2) in the first signal path (2, 3, 5).
Type: Grant
Filed: August 6, 2002
Date of Patent: March 16, 2004
Assignee: Georg Neumann GmbH
Inventor: Otmar Kern
Postby Mike Stranks » Wed Apr 10, 2019 9:24 pm
As you know, the Chinese are aware of everybody's patents... and couldn't care less!
Postby Mike Stranks » Wed Apr 10, 2019 9:31 pm
... back to the F6...
I did have a mental question mark about what's obviously a mock-up in a glass case at NAB, but with more info due in May and product launch in June. I would have thought that at least some pre-production prototypes should have been available for 'show and tell' at something as prestigious as NAB.
I recall the significant 'oops' that Zoom had with the original H2. All the prepub said that it would be a 5.1 recorder, but the execution proved more difficult than the aspiration. In the end, after a few months of delay, it hit the streets in a simplified form. 5.1 recording had to wait a year or so for the Mk2... Let us hope that Zoom have not hit similar issues with the tech in the F6...
[fingers-crossed]
Postby Hugh Robjohns » Wed Apr 10, 2019 9:39 pm
Mike Stranks wrote:I would have thought that at least some pre-production prototypes should have been available for 'show and tell' at something as prestigious as NAB.
It might have been the marketing/manufacturing target, but R&D can be a fickle thing, and maybe they just couldn't reach a pre-production working prototype In time. It happens.
But NAB is such an important show in that market sector that they would definitely have felt the need to announce the product there, even if it takes another year to bring the thing to market.
I've just reviewed the Radial kL-8 keyboard mixer which was announced and shown as an empty case at NAMM 2018, but didn't fall off the production line as a working it until January 2019 a whole year later!
Postby awjoe » Sat Apr 13, 2019 5:16 am
"If you're recording in 32-bit, you don't need to set gain at all."
My experience until now has been that Zoom satisfy. Now Zoom amaze.
awjoe
Music production is like finding a good hair dresser
Postby wireman » Sat Apr 13, 2019 9:01 am
awjoe wrote:"If you're recording in 32-bit, you don't need to set gain at all."
I couldn't resist a segue to Fat Larry on Youtuble...
wireman
Postby Hugh Robjohns » Sat Apr 13, 2019 11:15 am
The whole reason that modern, stock, digital audio interfaces operate at 24 bit was for the exact same reason. A 24 bit digital system has a theoretical dynamic range of 141dB which is more than the human ear. In other words the dither noise floor can be set below the threshold of hearing, with the clipping level still well above the pain threshold. So it should be possible to have replay systems that don't need a volume control, and just reproduce everything at the same SPL as the original source.
In practice this is, of course, completely unworkable in a domestic context, but the idea is still valid for situations where an accurate calibrated replay level is desirable.
For high-end post-production it is necessary to have a wider dynamic range to allow some wriggle room -- in the same way that pro studios in the 70s and 80s used half-inch master tapes while the consumer used cassettes... Hence the attractiveness of a 32-bit float format in next-generation recorders.
Postby Jadoube » Wed Apr 17, 2019 5:19 pm
Good Thread! I learned a few interesting bits. Bravo :clap:
Jadoube
_________
David
Postby wireman » Wed Apr 17, 2019 7:40 pm
Hugh Robjohns wrote:Hence the attractiveness of a 32-bit float format in next-generation recorders.
I always assumed (no evidence) that audio software would be using 32-bit types to hold the 24 bit samples in any case so not much of a step to go to a 32-bit float. This should be faster as well.
wireman
Postby IronFilm » Thu Apr 18, 2019 6:38 am
The Elf wrote:Clever stuff! Really hope this idea drops down to an H4/5 format.
I'd imagine that Zoom will update their H series eventually. As their F series pre amps are MUCH better than in the H series.
IronFilm
http://IronFilm.co.nz/Sound/
https://www.youtube.com/SoundSpeeding
Postby Mike Stranks » Mon May 27, 2019 10:37 am
A good first-look review. Worth viewing for it's explanation of gain-staging and the demo of the incredible dynamic range that the F6 can handle with ease.
https://www.youtube.com/watch?v=y4oNd1RgGL0
Postby Hugh Robjohns » Mon May 27, 2019 11:05 am
It's an ugly brick of a thing isn't it? And that power button looks both awkwardly and vulnerably placed -- although that's a complaint that's often levied at manufacturers and usually turns out to be unfounded... so I'll wait til I get my hands on a real one before forming a proper view.
The recording tech is clever, and will make life much easier -- and deliver more usable recordings -- for amateurs who don't understand gain staging. But it does make a lot more more work in post-production of course to wrangle sensible levels out of the 32-bit float file.
So in the pro-world it will be a great thing for assistant producers doing single-camera fly-on-the-wall doco-shoots without a proper crew....and it's another nail in the coffin of professional sound recordists. :-( Just have to hope they point the mic the right way...
Clearly very feature-rich, which is good, but it's tiny... tiny... tiny.... and looks pretty fiddly to use.
Postby The Elf » Mon May 27, 2019 1:39 pm
I'm blown away by the A/D technology, but this looks more like a concept design than anything that would make it into production.
Half an hour up on the Yorkshire moors and there's not a set of fingers in the world that will be able to manage those knobs and buttons!
Watching with interest...
Postby Hugh Robjohns » Mon May 27, 2019 2:23 pm
Pretty sure that is as close as makes no difference to the full production unit.
Thankfully, the only buttons and knobs you need to fiddle with are the record and stop buttons. Assuming it's been set up sensibly, everything else will take care of itself.... or so they claim!
And clever though the tech is, I doubt the performance would be significantly different in practice from just recording with a generous headroom margin on a current 24 bit machine. The overwhelming element that defines the recorded noise floor will be the acoustic noise into the mic, not the preamp/converter noise -- and by a massive margin.
When recording live action stuff with very wide and unpredictable dynamic ranges and high peak SPLs, I often just set the preamp gain very low so that the ambient noise level is around -60dBFS or so on my Nagra VI (or even lower if the expected peak noise is nearing painfully loud), and then let whatever happens, happen... Seems to get the job done with no fuss, no overloads, and no noise problems in post-production.
Who needs 32-bit float? :D :wave:
