If you could only have one compressor plugin to use for everything, what would it be?
Page 1 of 5
PostPosted: Sun May 12, 2019 10:05 am
by Dr Huge Longjohns
I'm sure many of us get bogged down with too-much-choice-paralysis from time to time, I certainly do. I have more compressors than you can shake a stick at, both bought and free, and included in Logic Pro X. So what if the People's Democratic Committee for Plugins dictated that you could only use one compressor plugin for everything...drums, drum buss, loud rock vocals, soft folk vocals, acoustic guitars, bass, strings etc etc etc...which one would it be? And why.
No cheating by suggesting switchable modelling as per the Scheps Channel etc. Ten years in the Gulag for anyone who tries.
Re: If you could only have one compressor plugin to use for everything, what would it be?
PostPosted: Sun May 12, 2019 10:30 am
by blinddrew
I also have a fair number of compressors, but i only tend to use a couple on a regular basis. My standard channel strip has ReaComp on it and my master bus has a Focusrite Scarlett compressor on (because I prefer the interface).
If i had to choose one it would be Reacomp because of the additional features (e.g. side-chaining).
As you can probably tell, i don't tend to try and use compression for character.
PostPosted: Sun May 12, 2019 10:45 am
by Guest
The Sonalksis SV-315Mk2 Compressor - it is just perfect.
It is transparent and unbelievable on spoken voice.
PostPosted: Sun May 12, 2019 10:56 am
by ConcertinaChap
Almost always use an LA-2A clone on vocals, violin and concertina, so easy and sounds good. I'm also partial to LA-3A on acoustic guitar. That covers most of my use.
PostPosted: Sun May 12, 2019 11:06 am
Excellent, keep em coming. Incidentally, I have consulted with the Glorious Leader of the Committee and he will allow a second choice if used exclusively for your stereo buss as per BD's post.
PostPosted: Sun May 12, 2019 11:09 am
Which one? Does it have the the simple two control (gain and peak reduction) as per the hardware original?
PostPosted: Sun May 12, 2019 11:12 am
by Luke W
Fabfilter Pro C2 for me. Useful set of controls, decent metering and just generally does exactly what it needs to do.
PostPosted: Sun May 12, 2019 11:42 am
by Humble Bee
DC1A from Klanghelm tends to get a lot of use. East to use. Sounds great. And is free.
I am in the process of quitting the UAD platform and go native but their LA2A and Fairchild renderings are fantastic and I have used them a lot in the past.
When I don’t need ‘character’ I tend to use the standard ones that come with Logic and Reaper.
PostPosted: Sun May 12, 2019 12:32 pm
by Bob Bickerton
Silly question unless you’re only using compression for one task.
For me LA2A for vocals, LA3A for something more aggressive and the Fairchild 670 for subtle buss compression - all UAD.
PostPosted: Sun May 12, 2019 12:39 pm
Sorry, I do apologise. I hadn't realised that the forum now had a rule that only Very Sensible Questions were allowed. Do forgive me. I will go out and whip myself with spiky birch twigs immediately.
PostPosted: Sun May 12, 2019 1:08 pm
by Bob Bickerton
Merely pointing out that different types of compressors are used for different tasks........ thus there is no one answer to your question - even though you prescribed a one answer response........
Have fun with the birch twigs........
PostPosted: Sun May 12, 2019 1:26 pm
by Guest
Dr Huge Longjohns wrote:Do forgive me. I will go out and whip myself with spiky birch twigs immediately.
You don't have to do it yourself. Many years ago in Swiss Cottage underground station there was a postcard that read:
"Naughty boys report to Miss Fiona"
followed by a telephone number.
PostPosted: Sun May 12, 2019 2:15 pm
Yes, Fiona and I have been happily married for many years now.
PostPosted: Sun May 12, 2019 2:26 pm
by CS70
I just need two. Maybe three if u want to be picky. A 1176 style, an optical L2A2 style and possibly a as-clean-as-possible one. My choices are the UAD for the 76 and the A2 (when I'm not using the outboard ones I have) and the FABFilter C for the clean one.
PostPosted: Sun May 12, 2019 5:15 pm
by ConcertinaChap
Dr Huge Longjohns wrote:Which one? Does it have the the simple two control (gain and peak reduction) as per the hardware original?
First the White 2A from IK Multimedia and later the various LA-2As from UAD. Both reproduce the interfaces right down to the tobacco smoke stains and there's not a great deal to choose between them other than the UAD ones integrate with Console 1, meaning you really do have just two hardware knobs to twiddle.
