Looking for reasons to keep my Focusrite 18i20...
PostPosted: Thu May 30, 2019 12:07 pm
by spittinpigeon
I chose the 18i20 over the 18i8 solely for the word clock so I could use it with my old D8b and HDR2496. Now it's looking like I might not be doing that.
The unit is still in the box, so I could exchange it for the 18i8 but before I do, what might I need word clock for in the future?
I'm just getting back into recording after almost 15 years out, I'll admit I'm overwhelmed by all that has happened in my absence.
I'm running a one man show in my home with guitar, keys and vocals, everything else will be done in the box, don't really need all those in and outs but part of me is thinking: "better to have it and not need it than to need it and not have it", particularly because I love toys and I'll certainly be expanding my setup as time goes on.
So will I be ok giving up the word clock or is there something I'm not thinking of?
Thanks for your help!
Re: Looking for reasons to keep my Focusrite 18i20...
PostPosted: Thu May 30, 2019 1:10 pm
by Dave B
You've basically answered your own question here. You made a good choice - I wouldn't go for a main interface that lacked wordclock as you never know when you might need to interface with additional gear. As you say "better to have and not need". I'd say plug it in and just start using it - it's a great bit of gear and you will find the simplicity of the modern approach quite liberating!
PostPosted: Thu May 30, 2019 1:43 pm
by Dr Huge Longjohns
I have one and use wordclock to run it alongside (on top of, actually) a Berhinger Ultragain Pro-8 Digital to give me 8 more input channels. Both great pieces of kit.
PostPosted: Thu May 30, 2019 1:46 pm
by blinddrew
And those extra line outputs give you more space to add future hardware options if that's the route you take. :)
PostPosted: Thu May 30, 2019 2:22 pm
+1...... Ask yourself if you desperately need the £80 refund for something else, if not keep it.
PostPosted: Thu May 30, 2019 2:41 pm
by Watchmaker
If you ever plan to use another interface, you'll need the wordclock. Keep it.
PostPosted: Thu May 30, 2019 4:23 pm
by ConcertinaChap
Wordclock's simple enough even I got a handle on it. I'd say keep it too.
PostPosted: Fri May 31, 2019 12:45 am
by Ramirez
As above.
Also, the 18i20 makes for a fabulous ADAT expander if you ever get another interface, giving you 8 mic pres, two assignable headphone outputs as well as line outputs.
PostPosted: Sat Jun 01, 2019 9:28 pm
by Ben Asaro
Dr Huge Longjohns wrote:I have one and use wordclock to run it alongside (on top of, actually) a Berhinger Ultragain Pro-8 Digital to give me 8 more input channels. Both great pieces of kit.
I use an OctoPre going ADAT in for 16 channels of input (perfect for recording lots of synths live) and ADAT out to a Behringer ADA8000 for 16 channels of output.
I love the 18i20!
PostPosted: Mon Jun 10, 2019 2:01 pm
by kingmoot
I've just bought one of those - whilst you might think it's a bit overkill for your needs, what sold it for me was not the number of channels, but unlike a lot of interfaces, it also gives you MIDI IN and OUT which I require, as I have some outboard gear.
You'll need a seperate MIDI interface, if you use MIDI and opt to change interface.
