Recording Help!
Page 1 of 4
Recording Help!
PostPosted: Mon Jul 22, 2019 3:37 pm
by G18ALG
Hello,
I have a Behringer Xenyx 1222USB mixer that I use for podcasting with my five friends (there’s six of us in total). We each use a condenser microphone, which is used with an XLR cable and we record using Audacity as we only have a PC. When we do mic checks prior to recording, the first one or two mics sound great but mic three or five, for example, sound like they lack power and the gain has to get to almost max before the clipping light shows. This obviously sounds terrible when we listen back to edit. We’ve resorted to the six of us huddled around an iPhone to record but given how much we’ve spent on equipment, we’d quite like to use it!
The mics are all the same and the mixer has phantom power built in.
Not sure if anyone has any ideas but we are open to them all! :headbang:
Thanks,
G18ALG
Re: Recording Help!
PostPosted: Mon Jul 22, 2019 5:08 pm
by The Elf
Welcome!
Before anyone else asks... make/model of mic's?
Re: Recording Help!
PostPosted: Mon Jul 22, 2019 5:19 pm
by Ariosto
Is the phantom power up to running 6 mics? (Might be a daft question ...)
Re: Recording Help!
PostPosted: Mon Jul 22, 2019 5:26 pm
by Wonks
My thoughts as well, especially if the mics used take a lot of current.
Have you tried seeing how many mics you can plug in before you start having gain issues? And what happens if you start doing the same thing, but plugging in from channel 6 backwards instead of from channel 1? (i.e. does it matter about the channel of does it just rely on the number of mics).
Re: Recording Help!
PostPosted: Mon Jul 22, 2019 5:27 pm
Two obvious differences between channels 1-4 and 5-6, 1-4 have a compressor and +60dB gain available, 5 & 6 have no compressor and only +40dB max gain.
The other thought is can the phantom power supply provide enough juice for all 6 mics? I've heard of budget mixers with under specced spook power on the basis that few people would use a capacitor in every channel (though I'd expect that to affect all channels the same).
Ariosto wrote:Is the phantom power up to running 6 mics? (Might be a daft question ...)
According to the manual it is available on all 6 mic inputs.
edit :- my thoughts too Wonky :thumbup:
Re: Recording Help!
PostPosted: Mon Jul 22, 2019 5:35 pm
by The Elf
I know nothing of that mixer, but as soon as the 'B' name is involved then such thoughts as 'can it deliver to spec?' do enter the mind...
When we know which mic's are involved then maybe the maths will tell us what we need to know?
Re: Recording Help!
PostPosted: Mon Jul 22, 2019 6:23 pm
The manual doesn't seem to say how much spook juice it can supply......
Re: Recording Help!
PostPosted: Mon Jul 22, 2019 8:14 pm
by G18ALG
The Elf wrote:Welcome!
Errr, good question! They’re not branded and were purchased off eBay so probably on par with the mixer for quality :lol: That said, if they work OK on two of the channels then they should, in theory, be good for all six.
Re: Recording Help!
PostPosted: Mon Jul 22, 2019 8:15 pm
by G18ALG
Wonks wrote:My thoughts as well, especially if the mics used take a lot of current.
It’s usually about 2-3 mics before the issues happen but I’ve not tried the 6 backwards theory so will try it out.
Re: Recording Help!
PostPosted: Mon Jul 22, 2019 8:17 pm
by G18ALG
Sam Spoons wrote:Two obvious differences between channels 1-4 and 5-6, 1-4 have a compressor and +60dB gain available, 5 & 6 have no compressor and only +40dB max gain.
I did consider ditching the condenser mics and getting dynamics instead, therefore not requiring the phantom power at all. Anyone ever used both and if so, would you recommend the switch? It’s only for podcasting after all so all we want is a clear and crisp vocal
Re: Recording Help!
PostPosted: Mon Jul 22, 2019 8:43 pm
by blinddrew
I've got a couple of x-series berry mixers and I'm wracking my brain to try and remember if I've ever used phantom on more than a couple of inputs at once. According to my session plan I used phantom on 4 channels of my X2222 but I recall making some changes during the session so that might not be accurate. :(
Re: Recording Help!
PostPosted: Mon Jul 22, 2019 10:31 pm
by hobbyist
Behringer is not as bad as the internet claims.
Chinese mikes can be good or bad but rarely just so so.
Do all of the mikes work when used separately by itself?
The Amazon specs says the 1222 has FOUR phantom powered inputs.
What does your manual say? Can you measure the voltage on each of the 6 inputs to verify you have phantom power?
If something is bad I suggest you might want to swap out two or more of them for cheap SM58 knockoffs from orange county speaker repair now GLS audio. They may be selling on amazon in UK as well as USA. Typically 40usd each.
Re: Recording Help!
PostPosted: Mon Jul 22, 2019 10:36 pm
The manual says all 6 mic inputs have spook but 1-4 have compressors and +60dB gain while 5&6 have no comp and +40dB.
Re: Recording Help!
PostPosted: Mon Jul 22, 2019 10:55 pm
by Mike Stranks
Just checked with the Behringer site and the quick-start guide.
Says that phantom is available on all 6 mic inputs.
Are the mics either BM-800s or Neewer NW800s?
Quality control on those is very unreliable; seems something like a 50% failure rate.
To be sure of what's going on I'd try each mic individually on the same channel with no other mics connected. Do all the mics perform the same on the same channel? If so your mics are OK and your mixer isn't delivering sufficient phantom. If you get different results with different mics then you have some faulty mics.
As has been said, you could try dynamic mics, but if it's spoken word you may struggle to get enough gain.
If mic replacements are on the cards I'd go for Rode M3s. Good mics and if phantom's not up to snuff you can battery-power them.
Re: Recording Help!
PostPosted: Mon Jul 22, 2019 11:54 pm
by hobbyist
Mike Stranks wrote:Just checked with the Behringer site and the quick-start guide.
Available at 6 mikes does not mean enough voltage/current for all 6 at the same time?
QC is iffy but nearly that bad. I guess closer to 10% DOA.
Definitely try one mike at a time to make sure they are okay and rule them out.
