First post (Hi), and vocal recording
Re: First post (Hi), and vocal recording
Postby Guest » Sun Aug 04, 2019 2:04 pm
Mike Stranks wrote:
If you don't own a mixer then stick with the audio interface approach... don't adopt the mixer one.
How is he going to amplify his dynamic mic with an audio interface?
Guest
Postby Kwackman » Sun Aug 04, 2019 2:33 pm
Most interfaces have mic preamps built in. You can get ones with a single mic-amp as well as ones with multiple mic preamps.
Kwackman
Postby Mike Stranks » Sun Aug 04, 2019 3:48 pm
The same way as you'd 'amplify' any other mic in an audio interface.
Eg:
And BTW... with the name 'Amber' this could well not be a 'he'.
Postby ef37a » Sun Aug 04, 2019 4:04 pm
Aw Mike!
Did you HAVE to put up the cheapest, one lunged interface, bog standard interface there is?
Them's for podders only.
Postby blinddrew » Sun Aug 04, 2019 4:33 pm
ef37a wrote:Aw Mike!
Think we might be missing the point there Dave! :D
Postby Guest » Sun Aug 04, 2019 4:50 pm
How much is one of those then?
I would not mind getting something like that myself so I can record in areas where I have no electric, dose it require an external power source or dose it have a battery inside of it, or dose it power its self from the USB hub from the computer?
Guest
Postby Sam Spoons » Sun Aug 04, 2019 5:40 pm
The UM22 is £36 and buss powered, the Behringer UMC-202 which has two mic preamps, costs just £60 and is also buss powered and would be a better choice IMHO.
Postby Guest » Sun Aug 04, 2019 5:56 pm
Sam Spoons wrote:The UM22 is £36 and buss powered, the Behringer UMC-202 which has two mic preamps, costs just £60 and is also buss powered and would be a better choice IMHO.
depends on if you need 2 mics or not
Guest
Postby ef37a » Mon Aug 05, 2019 6:18 am
Well, what IS The Point then Drew? MY point is that newbs can be very influenced by what the knowledgeable folk of this forum say and show? That single mic input AI has its uses but is not a good choice for someone started down the road of music recording, especially since in this instance said newb owns TWO microphones!
Postby blinddrew » Mon Aug 05, 2019 8:42 am
The point is that the discussion had moved on and it was an example of an interface with a mic pre-amp. But you know this already.
Postby Mike Stranks » Mon Aug 05, 2019 10:13 am
Dave: I am in awe of your electronics knowledge and the way that you share it here.
But you're making a mountain of a molehill.
I was seeking to steer the OP away from buying a mixer... IMO the wrong route to pursue if starting out with no gear.
Someone joined in who, seemingly, had no concept of an audio interface, what it is and how it works.
I found the first picture I could of a simple interface - the simplest I could find quickly - which clearly showed the mic input and didn't show loads of other stuff that might take away from the basic point.
My pic was clearly prefaced with a comment about audio interfaces in general and the specific 'For Example' (E.g)
At no point did I suggest or imply that the poster asking about audio interfaces should 'buy one of these'. As Drew says, I was explaining a specific point to someone who joined the thread and asked a tangential question.
In friendship. Mike
Amber: if you're still here, ignore this diversion. It's irrelevant to your original question which has already been well-answered. :)
Postby ef37a » Mon Aug 05, 2019 11:37 am
Friends always Mike.
Yes, sorry about the outburst. If I might just move a little more soil to explain?
I see shedloads of noob questions about interfaces and it is very common for them to just buy the cheapest unit they can find. The problem is not so much about Behringer (though I do not like them ripping off "our" amp designs!) but the single mic input, it will surely only be a matter of weeks before such a newb realises they cannot record voice and guitar say?
These bargain basement AIs also tend to have limited outputs on RCA and are generally not suited as the starter base for music creation.
I also have a "thing" about MIDI ports (not that anyone here will have noticed!) . I consider them essential and surely add little to the cost. MIDI has beed seriously upgraded and will I am sure become even more popular?
Yes Amber, ignore this old valve jockey.
Once again Mike, sorry for the rant.
Postby blinddrew » Mon Aug 05, 2019 2:22 pm
My apologies also Dave, and for what it's worth, I agree with all your points about mic inputs and midi. :)
Postby Guest » Mon Aug 05, 2019 7:17 pm
The opening post said he had 2 dynamic microphones (not condensers) So I presumed he was doing live performances so therefore would have a mixer
Guest
Postby mb_r » Thu Aug 15, 2019 3:10 pm
I have to tell you guys, it hasn’t been easy to choose among all the available products on the market. But now I know a bit about audio and recording, which is helpful.
The audio interface I ended up buying is a Shure Motiv MVI. Can’t wait to test it, and hopefully I made the right choice :D
Your advices have been precious!
mb_r
