Good software compressor for tracking?
Re: Good software compressor for tracking?
Postby Arpangel » Wed Sep 11, 2019 10:17 am
James Perrett wrote:
blinddrew wrote:Don't suppose you can remember how to find that setting can you James?
I knew it had something to do with squares so I just did a search in the action list for 'square' and came up with
Peaks: Scale peaks by square root (half of range is 12dB rather than 6dB)
Personally I find Reaper's standard meters are fine - I just aim for nominal levels to be about half way up the meters which gives you at least 18dB of headroom.
You're right, I made the mistake of using the 12dB point as my nominal level.
Postby Martin Walker » Wed Sep 11, 2019 1:58 pm
James Perrett wrote:I knew it had something to do with squares so I just did a search in the action list for 'square' and came up with
Brilliant! - Just changed that setting on my Reaper template, as it makes far more sense from a dynamics/visual point of view.
Thanks James!
Users browsing this forum: Ramirez
