Small format digital mixer?
Postby Arpangel » Sun Sep 08, 2019 8:53 am
I've decided this is the way to go after much experimentation and posts here.
It'll enable me to consolidate a lot of space hungry hardware, it'll be my interface, effects etc, and also, maybe a recorder. It just makes so much sense to me. This has nothing to do with with uncertainty about actually making music, it's a basic streamlining and making things more compact, therefore a quicker, more immediate workflow owing to templates etc.
There are certain things I'm sure about, about my choice, I don't want an i Pad controlled ultra compact mixer, it's not appealing, I need a traditional style desktop mixer with all controls, but I need the smallest one I can find, I haven't done a lot of reasearch, up to now, but maybe some folks could point me in the right direction.
This has been on the cards for a long time, and I've actually got to do something about it.
Re: Small format digital mixer?
Postby Sam Spoons » Sun Sep 08, 2019 9:31 am
Behringer X32 Producer or A&H Qu16.
Postby Arpangel » Sun Sep 08, 2019 10:29 am
Sam Spoons wrote:Behringer X32 Producer or A&H Qu16.
Ha Ha! Like......you've just confirmed the first SOS rule, and confirmed my choices, I guess that's that then!
Postby Sam Spoons » Sun Sep 08, 2019 11:06 am
I can't think of anything smaller that has faders, pretty sure Presonus do one that is the same size and Yamaha do a couple of rack mountable (01V96i and DM1000) mixers but I don't know much about those.
Postby The Elf » Sun Sep 08, 2019 11:07 am
With the guys' help here I opted for an RME MADIFace XT and a pair of Ferrofish A32s. 64 inputs from 3U of rack space, with the option to go up to 196 inputs - and the fabulous TotalMix to route anything to anywhere. Who needs faders?
Postby Mike Stranks » Sun Sep 08, 2019 11:24 am
Well if you want small as possible, there's always this:
https://www.thomann.de/gb/the_t.mix_dm_20.htm also known as the Studiomaster Digilive 16
Extended video review here: https://www.youtube.com/watch?v=NL6CPL8atK4
Postby Sam Spoons » Sun Sep 08, 2019 11:50 am
That looks like it could possibly be a replacement for my DL1608 at some point. There's a review of the Studiomaster in the May 2017 edition of the Mag https://www.soundonsound.com/reviews/studiomaster-digilive-16
The Thomann version doesn't appear to have physical gain controls which the Studiomaster does, a bad move on Studiomaster's part IMHO which would lean me towards the T-Mix (which presumable has recallable gains).
Postby Zukan » Sun Sep 08, 2019 11:53 am
The Elf wrote:With the guys' help here I opted for an RME MADIFace XT and a pair of Ferrofish A32s. 64 inputs from 3U of rack space, with the option to go up to 196 inputs - and the fabulous TotalMix to route anything to anywhere. Who needs faders?
Good Lord, you recording a country?
Actually, almost all jests aside, how are you getting on with this combo P?
Zukan
Postby Arpangel » Sun Sep 08, 2019 11:55 am
Mike Stranks wrote:Well if you want small as possible, there's always this:
Looks good initially, but it's not an interface, I was hoping to incorporate that in my mixer, and have multitrack access.
It's a good compromise I think, but maybe a bit limited digitally. I think Paul White said it was rather complicated, and cheaper easier to use alternatives could be considered.
But there's no doubt, it's compact! and it would do all I need, shame it hasn't got a multitrack interface.
Postby The Elf » Sun Sep 08, 2019 1:58 pm
Think of those 64 mono inputs as 32 stereo inputs, then imagine a few synths, modules and external effects processors, and... it's surprising how quickly those 64 inputs disappear!
Zukan wrote:Actually, almost all jests aside, how are you getting on with this combo?
Abolutely rock solid - set it all up and then forget it exists - that's my kind of gear!
I perhaps pulled the trigger slightly too early, and if was taking another run at it I'd probably go Dante. RME's Dante interface was announced about a week after I'd set my MADI system up - sometimes it just goes that way. For me it's all about TotalMix - never want to work with an interface now that doesn't have that!
Postby Mike Stranks » Sun Sep 08, 2019 2:02 pm
I wasn't going to mention Paul White...
I read his review carefully. His criticism seemed to be that it was different to his Mackie. Other reviewers have commented how easy it is to use.
I think for all of us if we're used to how software works then a change to a different product can leave us finding it difficult to determine between different/better/worse.
The key thing for you would be functionality. You could order from Thomann and send it back if it doesn't suit.
Postby Arpangel » Mon Sep 09, 2019 9:54 am
Mike, correct me if I'm wrong, but it doesn't have an interface....right?
It'll solve my mixer/effects situation, and I take it you can save scenes and templates? which I definitely need. But I'll still have to use a seperate interface, which I was hoping not to do.
Postby Mike Stranks » Mon Sep 09, 2019 3:06 pm
I don't have a clue! The only way I could answer your question would be to read the specs or look at that comprehensive video overview... but you can do that as easily as me. Cut-out the middle-man! :)
Postby Arpangel » Tue Sep 10, 2019 7:11 am
Mike, it isn't an interface, it only supports recording to a memory stick.
The Behringer Producer is a bit smaller than the A&H, but I'm going to mount it vertically, so may be able to go a bit larger/deeper.
