Help (AT2020 making a hissing noise)
PostPosted: Wed Sep 11, 2019 9:26 pm
by callumbull3636
Please can someone help me I recently bought a used at2020 and audio interface and it is making a really loud hissing noise and very very quite mic sound pretty much un able to hear,I don’t think there is a fix to this but if so can any tell me what or is it the mic or interface?
Edit: Subject changed to be more meaningful - James Perrett
Re: Help (AT2020 making a hissing noise)
PostPosted: Wed Sep 11, 2019 9:48 pm
by blinddrew
A recording of the noise would help but it's possible that if it's not been stored correctly it may be affected by condensation.
Put it somewhere warm and dry for a couple of days and see if it improves.
PostPosted: Wed Sep 11, 2019 9:53 pm
by Wonks
Have you got another mic to rule out the interface itself being faulty? If the other mic is quiet and normal sounding, then it will be the AT2020.
by James Perrett
Does the hissing noise go away when the mic is unplugged (turn the volume down when plugging or unplugging though). Do you have phantom power switched on?
If the hissing goes away when the mic is unplugged I would suspect moisture or contamination in the microphone. It would be worth leaving it in a warm and dry place (like an airing cupboard) for a few days to let it dry out. Some people suggest putting mics in a bag of dry rice or silica gel to remove the moisture. If that doesn't work then the mic probably needs to be repaired by an experienced technician. In that case it may be worth contacting Audio Technica to see what they would charge for a repair.
PostPosted: Wed Sep 11, 2019 9:55 pm
by Wonks
As much as a new 2020 I'd imagine!
PostPosted: Wed Sep 11, 2019 10:07 pm
by callumbull3636
blinddrew wrote:A recording of the noise would help but it's possible that if it's not been stored correctly it may be affected by condensation.
Yes I will send one tommorow
by callumbull3636
No it gets louder when I unplug the mic
PostPosted: Wed Sep 11, 2019 11:31 pm
by James Perrett
What is the make and model of the audio interface?
PostPosted: Thu Sep 12, 2019 7:12 am
by callumbull3636
The audio interface is a M-Audio Fast Track USB Audio Interface - Audio Interface
PostPosted: Thu Sep 12, 2019 9:28 am
by CS70
callumbull3636 wrote:No it gets louder when I unplug the mic
If you have the same noise (or more) without mic, it's unlikely to be the mic?
You do have phantom power on, right? (and turn it off when plugging/unplugging the mic?)
And when you "unplug" the mic - does that mean unplugging the cable from the FastTrack preamp, right (after having switched off phantom power)?
If the answer is yes to both, looks like the interface preamp may be faulty.
