Recording an Orchestra - Cold
Page 2 of 5
Re: Recording an Orchestra - Cold
PostPosted: Fri Sep 20, 2019 10:42 am
Arpangel wrote:
Hugh Robjohns wrote:The four-mic array is basically a pair of cardioids (or hypo-cardioids) spaced at about 47cm, with a pair of omni outriggers spaced at 67cm, all four being angled outwards at 45 degrees from the centre line.
The cardioid/hypo-cardioid spacing can be adjusted to suit the acoustics, source width, and required stereo recording angle, but the omnis should always be 10cm further out to each side.... according to Tony, anyway. :-)
Balance the directional and omni pairs to taste...
That's interesting, I take it the two outer most mic's are Omni's? and the two in the centre are cardioids?
Highlighted...
PostPosted: Fri Sep 20, 2019 11:17 am
by ConcertinaChap
Lovely. Thanks, Hugh. I've got the mics for that and I'll give it a whirl sometime.
PostPosted: Fri Sep 20, 2019 11:21 am
by Mike Stranks
I'm only half-remembering this, but I recall TF stating that Andre Previn in particular was very averse to multi-mic/stand/cable setups when there was an audience present. Hence this array...
PostPosted: Fri Sep 20, 2019 12:02 pm
Hypo-cardioids at 47cm spacing and 90 degree mutual angle provide a stereo recording angle of about 70 degrees (+/-35 degrees), while spaced omnis at 67cm is about 99 degrees (+/-49.5 degrees).
Cardioids with the same 47cm spacing and angle gives an SRA of about 61 degrees (+/-30.5 degrees).
So it requires the width of the orchestra to be reasonably narrow and compact, especially if the array has to be placed fairly close.
Narrower spacings of the directional mics will give wider SRAs -- for example, a 22cm spacing of hypo-cardioids (with 90 degree mutual angle) gives a 120 degree SRA, or 33cm is a 90 degree SRA.
For Cardioids the equivalent spacings are 14 (SRA=120) and 24cm (SRA=90).
PostPosted: Fri Sep 20, 2019 12:54 pm
by jimh76
Hi Peeps,,
Fist of all a big thank you to everyone for their insightful input.
I'm in Stockport near Manchester (UK).
I feel I should explain that I kind of ambushed the people doing the concert, as the concert was taking place already, and I rang the person who organised it and said I would come down and record for free. I love recording, but don't get much action......I also don't claim to be an expert, but feel things like this are a really good way of learning (mostly by making the mistakes)
I obviously understand that to them, it's a performance and not a recording session, and I have kind of hijacked them.
I stated to them that for the performance, the limitations as to the mic stands etc might not get the best recording for them, and my hope is that they'll let me do an actual recording session proper after they have done this one.
I'll possibly be doing a rehearsal session first in which case, anything goes with regards to mic stands. I think I will keep it simple though ( although I don't want to go the mono route really). Like Hugh says, possibly the Rode NT1s left & right (high as they can go) and the SE X1A central, with possibly the SDC spot mics on the piano in stereo.
I'm looking forward to it, and if it sounds pants, then no one has really lost anything.
Thanks,
Jim.
PostPosted: Fri Sep 20, 2019 2:26 pm
by Aural Reject
When is it?
PostPosted: Fri Sep 20, 2019 3:07 pm
by Mike Stranks
jimh76 wrote:Hi Peeps,,
Sorry! Too far off my patch, otherwise I'd have been pleased to help.
PostPosted: Fri Sep 20, 2019 3:16 pm
by Aural Reject
It’s a way away from home for me...but if it can be tied in with a visit to the kids in Woodford and I’m not working...then I might be able to do something.
PostPosted: Fri Sep 20, 2019 3:33 pm
by jimh76
Hi peeps
It's on Saturday 28 September. I'd be recording the rehearsal in the afternoon and depending on how that goes record the concert in the evening. I've not got final confirmation yet so I may be told that it's a no go and to do the next 1 so don't do any planning for me Aural.
As I say I think it's a casual for me and as long as I don't completely muck it up could be something I regularly do for them.
Cheers for everyone's input.
Jim
PostPosted: Fri Sep 20, 2019 7:51 pm
by Aural Reject
jimh76 wrote:Hi peeps
Jim
I’m in Morocco atm but back by then.
In theory I’m only scheduled for edits that weekend - though I’m waiting for some dates off a band for some in-rehearsal recording before the 12th October which I’ll get after their gig tomorrow evening.
If you come up with an alternative mic plan or approach that you think would benefit from access to better mics just prod...I can cover most eventualities barring a filmic in shot balance.
PostPosted: Sat Sep 21, 2019 7:30 am
by Arpangel
Highlighted...
That diagram is very confusing, it gives the impression that one colour is cardioid, and the other colour is omni, but that doesn't make sense,
PostPosted: Sat Sep 21, 2019 7:31 am
by hooty2
Pitching in here with possible loan of panamic cathedral stand if gig not too far away
PostPosted: Sat Sep 21, 2019 8:58 am
by Wonks
hooty2 wrote:Pitching in here with possible loan of panamic cathedral stand if gig not too far away
It's in Stockport.
PostPosted: Sat Sep 21, 2019 9:14 am
by jimh76
Thanks for everyone's help on this.
I'll update on how it went. Thanks for the offer of equipment, but I'll see how I get on with my stuff
Jim
PostPosted: Sat Sep 21, 2019 11:26 am
Arpangel wrote:That diagram is very confusing, it gives the impression that one colour is cardioid, and the other colour is omni, but that doesn't make sense,
I didn't draw it - -I didn't have the time -- I just borrowed it. The colours indicate the channels and the illustrated polar patterns indicate the, er, mic polar patterns! ;)
