Mic Cable recommendations
Re: Mic Cable recommendations
Postby Wonks » Tue Oct 01, 2019 3:24 pm
Arpangel wrote:
Exalted Wombat wrote:
Hugh Robjohns wrote:... especially in an unbalanced interconnect.
'Interconnect' is a perfectly good word with a perfectly good meaning. But it's been so hi-jacked by the audiophool community that it makes me flinch whenever I hear it!
Which flings (brings?) me neatly to my belief that black Klotz sounds better than green.....
The pigments used in the outer sheath can have a significant effect on the overall cable capacitance. Maybe not noticeable for short lengths of balanced cables, but the effect can be noticeable for guitar leads, especially for longer ones.
Postby innerchord » Tue Oct 01, 2019 10:37 pm
One of my favourite cables is bright green. I have to paint it black to be able to use it on stage without it causing lighting problems!
innerchord
Postby Sam Spoons » Tue Oct 01, 2019 10:48 pm
I have a number of brightly coloured mic cables, very useful for identification but somebody once suggested that maybe they don't look as professional as plain black. :headbang:
Postby ConcertinaChap » Tue Oct 01, 2019 10:56 pm
Blow 'em, say I. Coloured not only makes it lot easier to remember what's connected to what it looks pretty too!
ConcertinaChap
Postby Hugh Robjohns » Tue Oct 01, 2019 11:04 pm
Split the difference! :-)
All my longer mic cables are black, but the XLRs have coloured collars or cable grips to aid Identification!
Postby Dan LB » Tue Oct 01, 2019 11:24 pm
Hugh Robjohns wrote:Split the difference! :-)
+1
And you can go a step further and use black female XLRs which makes things a little less visually obtrusive for film / TV work.
Dan LB
Postby drashkum » Wed Oct 02, 2019 8:01 am
On neutrik connectors?
drashkum
Postby Wonks » Wed Oct 02, 2019 8:11 am
Neutriks are certainly very good and most of my cables (mic and guitar) have neutrik connectors.
Postby Aural Reject » Wed Oct 02, 2019 8:15 am
+1
Yep....along with all sorts of various things like modular systems for, for example, stereo and 4 mic arrays that minimise visual cable runs...all wondrous things to fund from the money pit :bouncy:
Aural Reject
Postby shufflebeat » Sat Oct 05, 2019 12:25 am
Hugh Robjohns wrote: Out-of-band interference can very easily cause in-band side-effects!
Sounds like the drummer's been up to his old tricks again.
shufflebeat
Apple Watch - the slowest of all the nature programmes.
Postby Wonks » Sat Oct 05, 2019 8:01 am
Postby James Lehmann » Wed Oct 09, 2019 6:13 pm
I roll my own cables and over the years I've used drums of Sommer, Belden and Klotz (single and multicore) all of which I've found to be easy to work with and adequate for my needs.
In terms of total cost for your build, the actual cable you use is going to be small beans compared to the cost of the connectors. All Neutrik parts seem to have increased markedly in the last 20 years - I shudder to think what a full set of lines for, say, a 24-channel mixer & patchbay will set you back these days. :shock:
James Lehmann
I used to be a rocker, but now I've gone off it and just sit in one. (JL)
