Cable labelling?
Re: Cable labelling?
Postby Arpangel » Fri Oct 04, 2019 11:02 am
baward wrote:
SimonZ wrote:Finally I found these, self laminating cables for inkjet printer on A4 sheets, 280 labels for £6.99...........
https://www.amazon.co.uk/Mr-Label-Self-Laminating-Around-Cable-Labels/dp/B07HGWQPTN/ref=pd_lpo_sbs_229_t_0?_encoding=UTF8&refRID=2NFGPDRVD60T9AHVS1AN&th=1
I have an Excel template if anyone needs one :thumbup:
Yes please!
Thanks, but don't have a laser printer!
Postby baward » Fri Oct 04, 2019 11:06 am
Ooh, yes please!!!
Me too please!
baward
Postby baward » Fri Oct 04, 2019 11:09 am
Sorry, a bit of finger trouble there!
baward
Postby SimonZ » Fri Oct 04, 2019 1:45 pm
OK, here's a link to the spread sheet.
In the first sheet simply type in your cable ID's down the frist column, just once for each cable. (I've put in a few to show how it works).
These will appear in the subsequent sheets in pairs for up to 10 sheets worth.
The only difference with laser vs ink jet is how easilly it smudges, just keep your fingers off the inky bits, once the clear part is wrapped around it will be fine.
https://www.dropbox.com/s/b3nt8zmsxn3bdcj/CABLE%20ID%20LABELS%20TEMPLATE.xlsx?dl=0
Let me know if there is any trouble with the link.
:bouncy:
SimonZ
Postby DGL. » Sat Oct 05, 2019 6:24 am
Also if you have a Brother P-Touch labeler that can take the 24mm tape then they do printable heatshrink, plus if using normal P-Touch labels (very cheap if you buy compatible ones) they have a cable labelling wizard in the PC software which works out the bend point in relation to cable size and aligns the printable areas accordingly.
DGL.
Postby Arpangel » Thu Oct 10, 2019 1:03 pm
Amazon Mr Labels look good, I'll get some of those.
Postby Martin Walker » Fri Oct 11, 2019 10:21 am
Arpangel wrote:Amazon Mr Labels look good, I'll get some of those.
Mine should be delivered some time today 8-)
So, I should finally be able to plug in those occasional cables lying underneath my desk without tracing the other ends back to their source to find out which is which ;)
Postby Dr Huge Longjohns » Sat Oct 12, 2019 10:38 am
Full review please!
Dr Huge Longjohns
Postby Arpangel » Sat Oct 12, 2019 10:53 am
Would that be occasional tables? In which case I can sympathise, my partner is always seeing a pair of legs sticking out from under the furniture in my studio...
Postby Martin Walker » Sun Oct 13, 2019 12:32 pm
Haha! :D
No, it's definitely occasional cables, as in three or four cables that only rarely get plugged in to my system.
So, since I'm routing direct into a multi-channel audio interface instead of a mixing desk, and have already maxed out its inputs, I occasionally have to unplug something else to plug one of these extras in, so the free ends are lying neatly underneath the desk (inside a small bag to keep dust off them).
So every dew months I find myself on hands and knees with a torch trying to identify which cable is which.
Hence the interest in these labels ;)
Postby shmuelyosef » Sun Oct 13, 2019 7:47 pm
I use 1/2" Pro Artist tape...same stuff that I use on:
Mixers - put a strip under the faders and label channels
Cables - write the label twice while still on the roll with a gap, then cut it off the roll, place the gap on the cable and stick them together.
Synths/keyboards - put a strip on top near the back and label all the connection points so I can plug and unplug things without having to get my face back there
DAW interface - same as mixers
etc...
shmuelyosef
