Komplete Audio 6 output problem
Postby matt222 » Wed Oct 02, 2019 8:49 pm
I've been learning to embrace Reaper and my Audio 6 interface but have suddenly become unable to get my Reaper output to feed through outputs 3/4 on the interface.
When I adjust my PC output settings to do so it has no effect, yet with any other audio from the PC ie YouTube, Soundcloud etc does and the output lights on the interface illuminate accordingly as normal - but not when the signal comes from Reaper?
I don't recall changing any settings in Reaper and am struggling to find where the answer lies
Any help for a floundering beginner would be most appreciated
matt222
Re: Komplete Audio 6 output problem
Postby James Perrett » Wed Oct 02, 2019 9:35 pm
Have you used Reaper with the KA6 disconnected so that it has to use the computer's internal audio interface? Sometimes Reaper forgets that you have 4 outputs if you do this and so you have to go to its audio interface settings and tell it how many outputs that you actually have. Look for the first and last output box.
Postby blinddrew » Wed Oct 02, 2019 11:13 pm
Yep, what James said. Preferences > Devices > check you're using the right audio driver > check you've got the number of input and output channels correctly set.
