Mic stand for recording acoustic
Postby Scouser » Sun Oct 06, 2019 11:19 am
Recently purchased a Neumann km184 to start some serious recording and need a suggestion for a mic stand, ideally small footprint but safe ! Doesn’t need to be a tall one as I will only be using it to record acoustic.
Scouser
Re: Mic stand for recording acoustic
Postby John Willett » Sun Oct 06, 2019 2:02 pm
Look at the K&M pro range - high quality and good value.
Do NOT get the cheapo cheapo stands that you often see.
John Willett
Postby Dan LB » Sun Oct 06, 2019 3:11 pm
Dan LB
Postby Wonks » Sun Oct 06, 2019 4:00 pm
Whilst I use K&M stands, you can get decent stands for less that won't slip or move if tightened properly. Especially for light home use. But once you have a decent stand I'd suggest that a decent shock mount will be of the biggest benefit.
The KM184 normally only comes with a clip mount, so I'd suggest looking at one of Rycote's excellent offerings. Don't forget to use an anti-vibration loop of mic cable between the stand and the mic itself.
Postby Kwackman » Sun Oct 06, 2019 5:52 pm
For a smaller footprint consider one with a heavy round base.
Kwackman
Postby John Willett » Mon Oct 07, 2019 10:00 am
I agree with all that has been said above.
The K&M floor stands are HERE
If you want a small stand which does not take up much floor space then THIS ONE is a new one that may fit the bill. :thumbup:
But all the K&M stands are good ones. :thumbup:
John Willett
Postby Wonks » Mon Oct 07, 2019 10:06 am
However, a taller stand that you can use to try micing from over your shoulder might be more versatile.
Postby John Willett » Mon Oct 07, 2019 10:12 am
Wonks wrote:However, a taller stand that you can use to try micing from over your shoulder might be more versatile.
Agreed - just look at all the mic. stands and accessories on the K&M website and then choose what best suits your needs. :thumbup:
John Willett
Postby Mike Stranks » Mon Oct 07, 2019 10:51 am
Scouser wrote:Recently purchased a Neumann km184 to start some serious recording and need a suggestion for a mic stand, ideally small footprint but safe ! Doesn’t need to be a tall one as I will only be using it to record acoustic.
Do you want a boom or just straight up/down?
Mike Stranks
Postby Hugh Robjohns » Mon Oct 07, 2019 2:06 pm
I'm sure a lady of dubious reputation made the same enquiry of me once... :blush:
:lolno:
Postby James Perrett » Mon Oct 07, 2019 2:07 pm
The closest that I could find to what I use is a combination of this stand
https://www.k-m.de/en/products/mic-stan ... 0-55?c=178
with this boom arm
https://www.k-m.de/en/products/mic-stan ... 0-55?c=180
Having both the stand and boom arm extendable makes it very versatile but that versatility doesn't come cheap. I've had mine for something like 35 years and they were secondhand when I bought them so they're certainly well built.
Postby Wonks » Mon Oct 07, 2019 2:07 pm
:bouncy: :D
Postby John Willett » Mon Oct 07, 2019 2:19 pm
James Perrett wrote:The closest that I could find to what I use is a combination of this stand
with this boom arm
That looks like a very nice combination JKames. :thumbup:
John Willett
Postby shmuelyosef » Sun Oct 13, 2019 8:00 pm
I have had very good results with the Ultimate line of stands.
The "Ulti-Boom Pro-TB - Telescoping" is a great value to provide flexibility on any size stand...contrary to intuition, a boom on a tallish stand uses a small space more effectively than something tiny as you can push the stand against the wall partially under a desk or table and have the microphone 'lean' towards you. I think that I paid $60 for my combination with the boom listed above on a telescoping stand with a weighted base (more compact than tripod bases).
I easily hang heavy large diaphragm mikes off this as well as X-Y small condensor pairs (for stereo on guitars or woodwinds.
Just to be specific, I am referring to THIS BOOM on THIS STAND
B&H always has the best prices
shmuelyosef
