Mic stand for recording acoustic
Page 1 of 2
PostPosted: Sun Oct 06, 2019 11:19 am
by Scouser
Recently purchased a Neumann km184 to start some serious recording and need a suggestion for a mic stand, ideally small footprint but safe ! Doesn’t need to be a tall one as I will only be using it to record acoustic.
Re: Mic stand for recording acoustic
PostPosted: Sun Oct 06, 2019 2:02 pm
by John Willett
Look at the K&M pro range - high quality and good value.
Do NOT get the cheapo cheapo stands that you often see.
PostPosted: Sun Oct 06, 2019 3:11 pm
by Dan LB
PostPosted: Sun Oct 06, 2019 4:00 pm
by Wonks
Whilst I use K&M stands, you can get decent stands for less that won't slip or move if tightened properly. Especially for light home use. But once you have a decent stand I'd suggest that a decent shock mount will be of the biggest benefit.
The KM184 normally only comes with a clip mount, so I'd suggest looking at one of Rycote's excellent offerings. Don't forget to use an anti-vibration loop of mic cable between the stand and the mic itself.
PostPosted: Sun Oct 06, 2019 5:52 pm
by Kwackman
For a smaller footprint consider one with a heavy round base.
PostPosted: Mon Oct 07, 2019 10:00 am
by John Willett
I agree with all that has been said above.
The K&M floor stands are HERE
If you want a small stand which does not take up much floor space then THIS ONE is a new one that may fit the bill. :thumbup:
But all the K&M stands are good ones. :thumbup:
PostPosted: Mon Oct 07, 2019 10:06 am
by Wonks
However, a taller stand that you can use to try micing from over your shoulder might be more versatile.
PostPosted: Mon Oct 07, 2019 10:12 am
by John Willett
Wonks wrote:However, a taller stand that you can use to try micing from over your shoulder might be more versatile.
Agreed - just look at all the mic. stands and accessories on the K&M website and then choose what best suits your needs. :thumbup:
PostPosted: Mon Oct 07, 2019 10:51 am
by Mike Stranks
Scouser wrote:Recently purchased a Neumann km184 to start some serious recording and need a suggestion for a mic stand, ideally small footprint but safe ! Doesn’t need to be a tall one as I will only be using it to record acoustic.
Do you want a boom or just straight up/down?
PostPosted: Mon Oct 07, 2019 2:06 pm
I'm sure a lady of dubious reputation made the same enquiry of me once... :blush:
:lolno:
PostPosted: Mon Oct 07, 2019 2:07 pm
by James Perrett
The closest that I could find to what I use is a combination of this stand
https://www.k-m.de/en/products/mic-stan ... 0-55?c=178
with this boom arm
https://www.k-m.de/en/products/mic-stan ... 0-55?c=180
Having both the stand and boom arm extendable makes it very versatile but that versatility doesn't come cheap. I've had mine for something like 35 years and they were secondhand when I bought them so they're certainly well built.
by Wonks
:bouncy: :D
PostPosted: Mon Oct 07, 2019 2:19 pm
by John Willett
James Perrett wrote:The closest that I could find to what I use is a combination of this stand
with this boom arm
That looks like a very nice combination JKames. :thumbup:
PostPosted: Tue Oct 08, 2019 3:06 pm
by Mike Stranks
PostPosted: Sun Oct 13, 2019 8:00 pm
by shmuelyosef
I have had very good results with the Ultimate line of stands.
The "Ulti-Boom Pro-TB - Telescoping" is a great value to provide flexibility on any size stand...contrary to intuition, a boom on a tallish stand uses a small space more effectively than something tiny as you can push the stand against the wall partially under a desk or table and have the microphone 'lean' towards you. I think that I paid $60 for my combination with the boom listed above on a telescoping stand with a weighted base (more compact than tripod bases).
I easily hang heavy large diaphragm mikes off this as well as X-Y small condensor pairs (for stereo on guitars or woodwinds.
Just to be specific, I am referring to THIS BOOM on THIS STAND
B&H always has the best prices
