Oktava mod
Oktava mod
Postby joaofernandesuk » Fri Oct 11, 2019 1:11 pm
Hi Guys
I want to mod my oktava mk319, I've been told by someone that there is a member of this forums that use to do mods to oktavas, I think is name is Simon, does any one know how to contact him?
Thanks in advance.
joaofernandesuk
Re: Oktava mod
Postby CS70 » Fri Oct 11, 2019 1:22 pm
The search system of the forum is.. ahem.. limited, but Google's your friend. Search
simon forum oktava site:soundonsound.com
and you get here
Re: Oktava mod
Postby joaofernandesuk » Fri Oct 11, 2019 4:08 pm
Thanks for your reply, I've done the search and I have found that same post, but for some reason the system doesn't allow me to do PM. That why I created this post.
joaofernandesuk
Re: Oktava mod
Postby CS70 » Fri Oct 11, 2019 4:16 pm
Not sure about forum rules, but it could be because you're a brand new user
Re: Oktava mod
Postby joaofernandesuk » Fri Oct 11, 2019 4:23 pm
Can anyone PM Simon for me, please?
joaofernandesuk
Re: Oktava mod
Postby Wonks » Fri Oct 11, 2019 4:25 pm
You can PM 'after' 3 posts, but I'm not sure if that's on 3 posts or with your 4th post. Try again, and if you cant, just post something else here and you then should be able to.
Edit: You've got 4 posts, so you should find PMing now unlocked.
PMs aren't that easy to find with this forum software/ You need to go to 'my control panel', hit the 'overview' tab then select 'private messages' and then the 'compose message' tab to select inbox, outbox etc.
Re: Oktava mod
Postby blinddrew » Fri Oct 11, 2019 4:26 pm
Hi joaofernandesuk
in order to stop spammers contacting forum members the PM function is turned off until you've got three posts registered.
You should now be able to PM Simon. :thumbup:
[EDIT] Wonks beat me to it.
Re: Oktava mod
Postby CS70 » Fri Oct 11, 2019 4:26 pm
Simon last posted on Oct 2nd in the Cable Labeling thread so he's still around. Post something with a subject "Need help from SimonZ" :-D
Re: Oktava mod
Postby James Perrett » Fri Oct 11, 2019 5:12 pm
CS70 wrote:Simon last posted on Oct 2nd in the Cable Labeling thread so he's still around. Post something with a subject "Need help from SimonZ" :-D
PM's are likely to be more effective but I'll let him know we're talking about him anyway.
Re: Oktava mod
Postby joaofernandesuk » Fri Oct 11, 2019 6:16 pm
Thanks Guys!! Very appreciated!
joaofernandesuk
Re: Oktava mod
Postby shmuelyosef » Sun Oct 13, 2019 7:41 pm
Bill Sitler does pretty good work on Octava microphones as well. Also supplies 'mod kits'
HERE is his MK-319 page
shmuelyosef
