Oktava mod
Posted:
Fri Oct 11, 2019 1:11 pm
by joaofernandesuk
Hi Guys
I want to mod my oktava mk319, I've been told by someone that there is a member of this forums that use to do mods to oktavas, I think is name is Simon, does any one know how to contact him?
Thanks in advance.
Re: Oktava mod
Posted:
Fri Oct 11, 2019 1:22 pm
by CS70
The search system of the forum is.. ahem.. limited, but Google's your friend. Search
simon forum oktava site:soundonsound.com
and you get
here
Re: Oktava mod
Posted:
Fri Oct 11, 2019 4:08 pm
by joaofernandesuk
Thanks for your reply, I've done the search and I have found that same post, but for some reason the system doesn't allow me to do PM. That why I created this post.
Re: Oktava mod
Posted:
Fri Oct 11, 2019 4:16 pm
by CS70
Not sure about forum rules, but it could be because you're a brand new user
Re: Oktava mod
Posted:
Fri Oct 11, 2019 4:23 pm
by joaofernandesuk
Can anyone PM Simon for me, please?
Re: Oktava mod
Posted:
Fri Oct 11, 2019 4:25 pm
by Wonks
You can PM 'after' 3 posts, but I'm not sure if that's on 3 posts or with your 4th post. Try again, and if you cant, just post something else here and you then should be able to.
Edit: You've got 4 posts, so you should find PMing now unlocked.
PMs aren't that easy to find with this forum software/ You need to go to 'my control panel', hit the 'overview' tab then select 'private messages' and then the 'compose message' tab to select inbox, outbox etc.
Re: Oktava mod
Posted:
Fri Oct 11, 2019 4:26 pm
by blinddrew
Hi joaofernandesuk
in order to stop spammers contacting forum members the PM function is turned off until you've got three posts registered.
You should now be able to PM Simon. :thumbup:
[EDIT] Wonks beat me to it.
Re: Oktava mod
Posted:
by CS70
Simon last posted on Oct 2nd in the Cable Labeling thread so he's still around. Post something with a subject "Need help from SimonZ" :-D
Re: Oktava mod
Posted:
Fri Oct 11, 2019 5:12 pm
by James Perrett
CS70 wrote:Simon last posted on Oct 2nd in the Cable Labeling thread so he's still around. Post something with a subject "Need help from SimonZ" :-D
PM's are likely to be more effective but I'll let him know we're talking about him anyway.
Re: Oktava mod
Posted:
Fri Oct 11, 2019 6:16 pm
by joaofernandesuk
Thanks Guys!! Very appreciated!
Re: Oktava mod
Posted:
Sun Oct 13, 2019 7:41 pm
by shmuelyosef
Bill Sitler does pretty good work on Octava microphones as well. Also supplies 'mod kits'
HERE is his MK-319 page
