Any way to bluetooth powered subs and tops?
Postby mikehende » Mon Oct 21, 2019 8:24 pm
Guys, is there anything available now for this please, to play music directly from your phone to the powered speakers without any equipment in between ?
mikehende
Re: Any way to bluetooth powered subs and tops?
Postby blinddrew » Mon Oct 21, 2019 8:29 pm
Quite a lot of active speakers have Bluetooth options. I think it will get more complex with subs.
Postby mikehende » Mon Oct 21, 2019 8:35 pm
Yes I am aware that there are tops nothing bigger than 12" though which is too small. If a 15" powered speaker can be bluetooth that would at least be an option.
I am wondering if there might be some way to bluetooth a powered 12" top with an 18" sub though.
mikehende
Postby Sam Spoons » Mon Oct 21, 2019 9:36 pm
A couple of the Alto BT devices you linked to on he other thread would be ideal.
Postby mikehende » Mon Oct 21, 2019 10:16 pm
but how would that work only to bluetooth powered subs and tops directly from a phone without any other equipment?
mikehende
Postby Funkyflash5 » Tue Oct 22, 2019 5:09 am
It looks like the turbosound ix12 or ix15 will do bluetooth in and then pass it along on an xlr daisy chain, so if you had your sub near your main, you could run an xlr between them to get both run off a bluetooth source. The ix's will also do bluetooth in stereo, so 2 ix12s or ix15s could each take a channel, and each could pass that to extra tops or subs
Funkyflash5
Postby Sam Spoons » Tue Oct 22, 2019 1:08 pm
Plug the BT receivers into the subs and use the HPF link output to the tops.
Users browsing this forum: Tim Gillett
