Any way to bluetooth powered subs and tops?
Page 1 of 1
PostPosted: Mon Oct 21, 2019 8:24 pm
by mikehende
Guys, is there anything available now for this please, to play music directly from your phone to the powered speakers without any equipment in between ?
Re: Any way to bluetooth powered subs and tops?
PostPosted: Mon Oct 21, 2019 8:29 pm
by blinddrew
Quite a lot of active speakers have Bluetooth options. I think it will get more complex with subs.
PostPosted: Mon Oct 21, 2019 8:35 pm
by mikehende
Yes I am aware that there are tops nothing bigger than 12" though which is too small. If a 15" powered speaker can be bluetooth that would at least be an option.
I am wondering if there might be some way to bluetooth a powered 12" top with an 18" sub though.
PostPosted: Mon Oct 21, 2019 9:36 pm
by Sam Spoons
A couple of the Alto BT devices you linked to on he other thread would be ideal.
PostPosted: Mon Oct 21, 2019 10:16 pm
by mikehende
but how would that work only to bluetooth powered subs and tops directly from a phone without any other equipment?
PostPosted: Tue Oct 22, 2019 5:09 am
by Funkyflash5
It looks like the turbosound ix12 or ix15 will do bluetooth in and then pass it along on an xlr daisy chain, so if you had your sub near your main, you could run an xlr between them to get both run off a bluetooth source. The ix's will also do bluetooth in stereo, so 2 ix12s or ix15s could each take a channel, and each could pass that to extra tops or subs
PostPosted: Tue Oct 22, 2019 1:08 pm
by Sam Spoons
Plug the BT receivers into the subs and use the HPF link output to the tops.
