Yamaha P125 Recording ???
Page 1 of 2
PostPosted: Tue Oct 22, 2019 2:33 am
by pianoworldstage
Hi
Regarding the Yamaha P125 digital piano, would it be possible to record the sound from the piano through an audio interface to a mobile device, and still recieve a equality recording?
This would be an audio recording using (Wave Lab audio editor) installed on the mobile.
Re: Yamaha P125 Recording ???
PostPosted: Wed Oct 23, 2019 1:05 am
by pianoworldstage
Ok, thanks anyway..
PostPosted: Wed Oct 23, 2019 8:31 am
by Wonks
The simple answer is yes.
Wavelab isn't really the best program for recording, but it will work.
Pg 23 of the manual shows that you can record directly using a USB connection (once you've dowloaded the appropriate Yamaha app).
Or you can use the two unbalanced aux connections to record into an audio interface with two line inputs.
But I'd try the USB method first, as you should be recording the digital sound the piano engine is creating, without it passing through D/A and then A/D converters (which is what will happen if you use the Aux outputs).
PostPosted: Wed Oct 23, 2019 4:33 pm
by pianoworldstage
You quote Pg 23 of the manual shows that you can record directly using a USB connection (once you've dowloaded the appropriate Yamaha app)
Would this mean without the use of an external audio interface? hence it being a direct recording to the audio app on the mobile?
I assumed the USB to Host was MIDI only, not MIDI and audio, but pg 23 states it can. In essence am i right in saying all i need is a USB to host cable from the P125 directly to the mobile to record audio? I believe I'll need some kind of splitter to connect to the mobile..
What best audio app would you recommend?
Sorry I'm new to music production..
PostPosted: Wed Oct 23, 2019 4:49 pm
You'll need some kind of "On The Go" cable which allows a tablet/phone to act as a USB host. The default is for phones and tablets to be slave devices. In the case of an iPad/iPhone the 'camera connection kit' does the job fine with various recording apps (including, IIRC, Garage Band).
PostPosted: Wed Oct 23, 2019 4:50 pm
by Wonks
If the manual is correct, then yes, that should be all you need, plus the Yamaha app. It may be capable of both MIDI and audio.
When you say 'mobile', is this a mobile phone, tablet or a laptop computer (and which make/type do you have)?
Wavelab is really designed as an audio file editor and mastering program. Though I've got a the essentials version of it, I'm not sure if it can record more than a stereo file at once.
If you want you put together something more complicated than a single piano piece, and want to add other instruments, then you'll want o be looking at more of a full-fledged workstation program. And that really depends on the platform you want to use.
PostPosted: Sat Oct 26, 2019 3:57 am
by pianoworldstage
Thanks for your responses on this topic.. if the USB to Host cable from the digital piano to the audio interface doesn't work in recording audio? Then for sure the audio line out cables will.. the only question now is working out what cable is needed from the audio interface to the mobile. Sorry for complexity of the question, but should it be..
USB male adaptor to 2x 3.5mm female ports on the back end.. then connect 2 audio cables from the female ports in to a 3.5mm Stereo Splitter Adapter in to the mobile?
PostPosted: Sat Oct 26, 2019 11:26 am
Have you tried the direct USB connection yet? If it works it removes the need for audio interfaces and analogue cables.
If you do need an AI the wiring would be :- Piano analogue outs > AI inputs - AI USB > OTG cable > Mobile device.
You would not use the 3.5mm connector(s) on the mobile device.
PostPosted: Sat Oct 26, 2019 6:44 pm
by pianoworldstage
That's clearly understud.. but opting for the USB connection without the use of an AI, would that suffice for a quality sound recording? As there is no AI involved.. or does a digital recording not need an AI ?
PostPosted: Sat Oct 26, 2019 6:54 pm
by Wonks
It is a digital sound that's created within the P125. The USB connection should just transfer the sound in a pristine digital format straight to your 'device' (which you still haven't said exactly what it is). You won't get better than that.
Otherwise the digital sound has to get converted to analogue sound by an D/A converter in the P125, which then gets cabled to an AI, which then re-digitised by an A/D converter in the AI. The electronics in the D/A and A/D will add a modicum of added noise and slight distortion (though not that much), but the recording still won't be as good as a direct digital transfer.
PostPosted: Sat Oct 26, 2019 8:24 pm
Yup, Wot the Wabbit sez :thumbup:
PostPosted: Sun Oct 27, 2019 4:20 am
by pianoworldstage
Unfortunately the USB cable didn't work in recording audio.. so it seems the analogue approach is the only option.. i just realised its not Wavelab but Wavepad I'll be recording in to on the mobile.. could anyone recommend any better free audio recording apps for android mobile?
PostPosted: Sun Oct 27, 2019 2:56 pm
by James Perrett
PostPosted: Tue Oct 29, 2019 2:38 am
by pianoworldstage
Yes it looks like a great app, and I'd luv to use it.. but I'm still having issues recording audio from the P125 to the mobile device due to cable and adapter connections.. I'm now trying to establish a digital connection via the USB to Host from the P125 to an OTG cable in to the mobile.. will be buying the cable soon.. could you advise if that cable pattern would work?
PostPosted: Tue Oct 29, 2019 10:02 am
by Moroccomoose
I was able to connect my (Yamaha as it happens) USB mixer to my Android (Galaxy 9 Plus) mobile phone with perfect results using a Microsoft Display Dock HD-500 (Which I had left over from when I had a windows phone.) They are a bit obsolete now Microsoft no longer do phones, but there are specific android docks available, it does not have to be the Microsoft version.
The display dock basically can turn your phone into a mini lite PC, running under 'Android DEX' and allows you to connect your phone to USB compliant peripherals - such as mouse and keyboard but also including audio gear. There is also an HDMI connection so you can work on a TV.
Once connected, I could record anything I could feed my mixer with via USB to any audio app on the phone.
Stu.
