Which LUFS meter to trust: Logic, Metric AB or Ozone?
Postby Dr Huge Longjohns » Thu Oct 31, 2019 12:49 pm
So, Logic's loudness meter tells me a track has an integrated LUFS value of -19.0 with a true peak of -3.5, Metric AB says it's -18.9 and -3.5, so close enough for rock n roll.
But Ozone says it's -13.8 with a TP of -2.8.
So why is the Ozone LUFS meter reading so wildly different? I thought LUFS were LUFS, there aren't difference ways to measure them are there? Or am I missing something here?
Dr Huge Longjohns
Re: Which LUFS meter to trust: Logic, Metric AB or Ozone?
Postby desmond » Thu Oct 31, 2019 12:57 pm
How are you setting up the metering?
For instance, if you had a Logic meter on the master bus, then after that, you have Ozone, but Ozone is doing some additional compression/limiting, then the figures will (of course) differ...
Also, there are a lot of metering options, scales and settings in Ozone - what are you using?
Postby Dr Huge Longjohns » Thu Oct 31, 2019 1:12 pm
I'm using the LUFS Integrated setting on the Ozone output. I have Ozone on the track and the meters on Logic's output master.
Dr Huge Longjohns
Postby desmond » Thu Oct 31, 2019 1:19 pm
So you're metering two different signals?
Are you doing any processing with Ozone?
I quickly tested a bunch of meters (on the master output channel of a test project), including iZotope stuff and got readings within .1dB across them all, so there's something weird going on there for you...
Postby Hugh Robjohns » Thu Oct 31, 2019 1:20 pm
That's a big error... and, like Desmond, my first thought is that you have a level offset somewhere between the Ozone plugin and your other meter. Faders not at unity? Odd panning issue?
What do the true peak meters show if you run a standard line up tone through the signal path?
There is a comprehensive set of test files on the EBU Tech website which can be used to evaluate the accuracy of LUFS metering:
https://tech.ebu.ch/publications/ebu_loudness_test_set
Postby Dr Huge Longjohns » Thu Oct 31, 2019 1:23 pm
Well, as I say, Ozone's on the track, the meters are on the stereo buss.
I'll try the test tracks.
Dr Huge Longjohns
Postby desmond » Thu Oct 31, 2019 1:26 pm
I'd recommend putting another Ozone on the master, after Logic's loudness meter, make sure all the processing is turned off, and check the LUFS again...
Postby Dr Huge Longjohns » Thu Oct 31, 2019 1:45 pm
Good plan, cheers.
Dr Huge Longjohns
Postby CS70 » Thu Oct 31, 2019 1:56 pm
Don't have it with me right now but I vaguely recall Ozone having three different modes of BS.1770 loudness, could it be that you have inadvertently selected the 3-seconds one?
Users browsing this forum: Ramirez
