Qsc touchmix 30 phantom power loss
Postby funkydingo41 » Sun Nov 03, 2019 2:03 pm
We have a touchmix 30 just over year old and this morning lost phantom power on all input channels. Phantom power works on selectable talkback channel.
Down powerdown, reset all phantom powers and tested all leads also used tester direct from rear of desk. Holding short of factory reset. Firmware upto date.
funkydingo41
Re: Qsc touchmix 30 phantom power loss
Postby Hugh Robjohns » Mon Nov 04, 2019 10:14 am
Sounds like a power supply failure, although it's odd that the talkback channel's phantom still works.
I'm not intimately familiar with the desk... is there a global 'phantom-safe' option in a menu somewhere? Unlikely, but worth checking.
Failing that, I suspect you need to investigate a warranty repair with your dealer/manufacturer.
Postby Wonks » Mon Nov 04, 2019 11:16 am
Or it could be a broken wire/bad solder joint/loose ribbon connector. But it does sound more like hardware than software.
Users browsing this forum: Arpangel, The Elf
