1st EQ recommendation
Re: 1st EQ recommendation
Postby jodaki » Thu Nov 28, 2019 10:42 am
James Perrett wrote: I took the bottom off and traced the circuit through.
In my world (software) we call that reverse engineering. Very similar exercise I imagine - except (and this is a big contrast between software and hardware) that doing that with commercial software is either sadly illegal in most cases, or impractical (by design).
jodaki
Postby Hugh Robjohns » Thu Nov 28, 2019 11:00 am
Ah... the 741. Classic... When I was at uni I could draw its complete schematic and describe the function of every transistor in the thing... :geek:
The first IC-based mixer I built used 741s. It actually worked tolerably well for my early amateur requirements, with an acceptable noise floor for analogue tape-based applications. And it's restricted gain-bandwidth was probably helpful in keeping out nasty RF interference!
PW's schematic of the mixer channel is a bit odd to follow with the -ve power rail at the top, but it's an interesting and unusual EQ design all right. Like to see some plots from that.
And placing the channel fader in the output driver's negative feedback loop is rather unusual too. Clearly MM weren't afraid of some bold engineering designs! :-)
Postby James Perrett » Thu Nov 28, 2019 10:22 pm
Hugh Robjohns wrote:...it's an interesting and unusual EQ design all right. Like to see some plots from that.
Once I've got the house move out of the way I'll see what I can do.
Postby Hugh Robjohns » Thu Nov 28, 2019 10:34 pm
Postby Arpangel » Fri Nov 29, 2019 9:40 am
A friend gave me my MM 16-2, it had a bag of concrete dropped on it. I cleaned it, replaced all the wiring and sockets, repaired the VU meters, and all was fine.
The track "Who's Gettin it" was recorded entirely using the MM.
https://anthonyflynn.bandcamp.com/track/whos-gettin-it
Postby jodaki » Fri Dec 06, 2019 2:44 pm
Jack Ruston wrote:You could use Acustica Pink 3, Magenta, or the new version of the Sontec, name escapes me. They're sampled hardware. Or you can go with algorithmic options as you are doing, but dig around for something a bit more Gucci.
J
Jack thanks for the tip re: Acustica. Their stuff has been a revelation to me. Ive read a few reviews by Sam Inglis and see you have been using Acustica for a while.
After reading sam's reviews I was concerned about CPU resources but I had a wavelab stereo session with trial versions of Magenta St EQ, Coral Bax, Azure, Scarlet 4ct, El Rey, Magenta Comp, Ultramarine and Tan loaded simultaneously (to test loading not for artistic reasons) with barely a pop to be heard anywhere. Sure it will be different in logic with a heavier session but I didnt think performance was too bad.
Anyway they are on a massive discount at the moment so I have just bought a few that I really loved.
So thanks for that tip! I will probably take a look at the N4 stuff too once I've got my head around this little lot.
PS. After deciding to follow my head rather than my heart on the subject of hardware eq, I immediately bumped into a second hand G14 for £2K!!
jodaki
Users browsing this forum: MOF
