Run out of IEC leads.
Re: Run out of IEC leads.
Postby Rich Hanson » Tue Nov 26, 2019 1:56 pm
The Elf wrote:Last studio re-jig 2 years ago I threw away at least 50 IEC leads, and still had them coming out of my ears. Two weeks ago I was scratching round for one. Quite clearly there's something metaphysical going on!
They've been taking lessons from the biros. I thought I had more than I can find.
Rich Hanson
Postby Wonks » Tue Nov 26, 2019 1:57 pm
ef37a wrote:Jusfort: You can run 'MIDI over Ethernet'? I actually got it working with a time limited freebie some years ago. Could that share the same cable as Dante?
It could, but you'd need the I/O device to add the MIDI over Ethernet into the data stream for the Ethernet port(s). Probably not a trivial firmware change. But until MIDI 2.0 is finalised, then I doubt you'll see MIDI on Dante AIs, and even then, MIDI may well end up as a separate interface. And maybe another at the other end. Can't find any Dante interfaces fitted with with MIDI in a quick (not exhaustive) search.
Postby blinddrew » Tue Nov 26, 2019 2:06 pm
ken long wrote:
ef37a wrote:skipped the Jewsen lot!
What does this mean?
Threw them all away. :)
Postby Eddy Deegan » Tue Nov 26, 2019 2:08 pm
"The Jewson lot" is a (British) figure of speech that means "all of them". It came from a number of adverts on TV years back for a building/DIY supply company called Jewson's. Their catchphrase was "We've got the Jewson lot".
https://www.youtube.com/results?search_ ... wson+tv+ad
Please consider supporting the SOS Forum Album project, helping charities via music created by forum members.
Postby ken long » Tue Nov 26, 2019 2:12 pm
Eddy Deegan wrote:It's a (British) figure of speech that means "all of them". It came from a number of adverts on TV for a DIY chain called Jewson's. Their catchphrase was "We've got the Jewson lot".
https://www.youtube.com/results?search_ ... wson+tv+ad" target="phpbbpopup
Ah OK - it was your typo that threw me. I often see expressions and phrases in your posts that I've never seen elsewhere. This one yielded 0 google search results. Wasn't aware of this advert, either.
[edit] thought I was replying to Dave! [/edit]
ken long
I'm All Ears.
Postby Wonks » Tue Nov 26, 2019 2:15 pm
They're common expressions and phrases on Dave's home planet.
Postby Sam Spoons » Tue Nov 26, 2019 2:31 pm
Where, I believe, he worked, for a while, as a chauffeur for a family of cheap green retractables.....
Postby Wonks » Tue Nov 26, 2019 2:35 pm
:clap:
Postby ef37a » Tue Nov 26, 2019 3:05 pm
Whippersnapper!
Postby The Elf » Tue Nov 26, 2019 5:01 pm
Next SOSMeet - 'bring and take' cable table... :?:
Postby Wonks » Tue Nov 26, 2019 5:35 pm
The Elf wrote:Next SOSMeet - 'bring and take' cable table... :?:
Trouble is, you'll put them down before lunch, then after lunch they've either all disappeared (apart from one with a Euro 2-prong plug on the end), or else you'll have 10x the original amount.
Postby The Elf » Tue Nov 26, 2019 5:50 pm
Anything remaining I'll take to recycling. :thumbup:
Postby Sam Spoons » Tue Nov 26, 2019 6:04 pm
A bit like leaving a banjo on the back seat of the car......
Postby MOF » Tue Nov 26, 2019 6:11 pm
St Albans
I presume the electronics shop in London Road is no longer there then?
I used to live there until my parents retired and moved to Lincolnshire in the 90s.
I have a similar problem finding one of my three tape measures but not cables, there’s always a surplus in my loft.
MOF
Postby The Elf » Tue Nov 26, 2019 6:24 pm
I'm sure that all of us are regularly binning bits and pieces that others would love to have. I make it a point to try to home everything I no longer need, and I'd encourage others to do the same. At the very least make a noise about it so folks have a chance to jump at it.
Postby Eddy Deegan » Tue Nov 26, 2019 9:13 pm
The Elf wrote:I'm sure that all of us are regularly binning bits and pieces that others would love to have. I make it a point to try to home everything I no longer need, and I'd encourage others to do the same. At the very least make a noise about it so folks have a chance to jump at it.
+1 :clap:
Despite regularly intending to, I haven't sold any gear since 1994. If unused/un-needed it's usually passed on to a friend who can use it, or one of their kids. I'm a big believer in helping youngsters to get started with something useful, and although lots of gear is cheap these days many of them genuinely struggle to find the means to pay for it.
Postby shufflebeat » Tue Nov 26, 2019 9:41 pm
Eddy Deegan wrote:Judging by the bulging plastic container tucked under my table I think someone else's may have migrated to mine at the moment :lol:
I've cleverly gathered many spare leads into a safe place for when I need them.
Now... mmm.
shufflebeat
Apple Watch - the slowest of all the nature programmes.
Postby Folderol » Tue Nov 26, 2019 10:09 pm
shufflebeat has just discovered it's so safe he can't remember where it is :bouncy:
Postby shufflebeat » Tue Nov 26, 2019 11:09 pm
Folderol wrote:shufflebeat has just discovered it's so safe he can't remember where it is :bouncy:
That might be true but having followed this thread I'm considering the possibility they have emigrated, which makes me feel a whole lot better.
shufflebeat
Postby John Willett » Tue Nov 26, 2019 11:29 pm
Sounds like me :bouncy:
So I buy new and discover the old ones as soon as the new one arrives :mrgreen: :oops:
John Willett
Users browsing this forum: Brian M Rose, GilesAnt, The Elf
