Lexicon LPX-5 no wet signal
Postby CS70 » Fri Nov 29, 2019 4:52 pm
A couple years ago I picked up an LPX-5 for free. I tried it once and it did not work out of the box - and since I was in a hurry, I put it in a drawer and happily forgot about it. This morning I saw it and thought of checking it out.
There seems to be a strange behavior which I am not sure means the unit is broken or just mis-configured.
In order to test it, I simply picked up the signal from a headphones out and plugged it into one of the Lexicon's inputs and connect headphones to the Lexicon's outputs via a Y cable. According to the manuals ( https://lexiconpro.com/en/products/lxp-5 ) that makes it work in mono mode - just fine for testing purposes. I figured since there's a wet/dry mix knob, I don't need to use an insert but can simply wet an existing signal.
An indeed signal is passing fine - I can hear the test track in the headphones. The gain structure seems fine as the "overload" led is not lighting and the green "signal present" led pulses okay with the signal. The unit seems to be working just fine, the pots aren't even scratchy.
The problem is that there's no effect. Moving the mix knob from 100% dry to 100% wet progressively reduces the volume, until at 100% wet, the signal is muted. I've been using only the "preset" positions, not the user-customizable ones as obviously there could be all sort of odd parameters there.
Checked over the internet, and it seems that over the years a few people have experienced the same issue. Learned that a possible cause is that the "defeat" footswitch was left accidentally in the on positions the last time the unit was used. So I fished out an old VOX dual footswitch (the left button should be latching) , connected a cable, and indeed the footswitch light was on when I connected it! Eureka! Turned it off by pushing the footswitch... and no change. Still no wet signal, in any position. :(
According to the manual, it's possible to control stuff like whether or not the 2 effects are bypassed or defeated by using an appropriate combination of knob positions.
It seems relatively simple - for example for the "Delay/Reverb" effect (which is the 2nd = effect B I guess), move the "preset" knob to "EDIT B" while pushing the "learn button", then move the "select" knob to 12 or more, then move the "adjust" knob to toggle on/off.. but dong so, nothing changes.
I have the feeling I'm missing something. Or maybe the unit is just broken? Seem strange that it passes dry audio just fine.
The unit was new when the only knob of a piece of studio equipment I was familiar with was the door knob of the recording room... is there anyone who used it in its heyday and remembers how it works?
Re: Lexicon LPX-5 no wet signal
Postby James Perrett » Fri Nov 29, 2019 10:12 pm
CS70 wrote:I have the feeling I'm missing something. Or maybe the unit is just broken? Seem strange that it passes dry audio just fine.
The dry signal is likely to go through a very simple all analogue signal chain. It is even possible that there are no IC's in the chain at all. The wet signal goes through a much more complicated digital signal chain with a different power supply.
My first thoughts are;
a) is the display working as expected?
b) do you hear any noise in the 100% wet position?
c) can you check the power supply voltages?
Postby BillB » Fri Nov 29, 2019 11:27 pm
It may not make any difference, but from your description, you’re not really connecting it as intended - line (or instrument) in and line out. If testing, I would be inclined to connect exactly as indicated in the manual. Perhaps a drum machine to the inputs, and output to an Amp or mixer... might prove to be irrelevant, but it is good to rule out the connections and sources before trying to resolve settings etc.
BillB
Postby CS70 » Sat Nov 30, 2019 1:08 am
Thanks James,
a) There is no display, just a couple LED and they seem to be doing their thing
b) No, perfect silence. That's what suggested me somehow the effect is defeated, but as you say, it could simply be that the as I turn the mix towards wet, the signal is progressively diverted to a not-working, perfectly silent path
c) Not with a voltmeter (dont have one) but it's the original power supply - what possibility are you thinking of?
Postby CS70 » Sat Nov 30, 2019 1:12 am
BillB wrote:It may not make any difference, but from your description, you’re not really connecting it as intended - line (or instrument) in and line out. If testing, I would be inclined to connect exactly as indicated in the manual. Perhaps a drum machine to the inputs, and output to an Amp or mixer... might prove to be irrelevant, but it is good to rule out the connections and sources before trying to resolve settings etc.
Hmm... the manual explicitly say that you can connect only one input? (and I tried also connecting the stereo headphone out to the both L and R inputs via another Y cable)
It also explicitly says (I think) that you can connect it either as an insert or direct, and even shows (as expected) that in the former case you should use 100% wet, in the latter the recommended range of mix is between 10 and 14 o'clock.
If you're thinking voltages, the headphone out I use is from the monitor controller, and it has plenty of juice, it can easily overload the input if I raise it. The S/N ratio on 100% dry is very good, so don't really see how could it be a cabling issue?
Thanks anyways :)
Postby CS70 » Sat Nov 30, 2019 1:19 am
I just found the service manual online ! There's a diagnostic mode as well, and schematics (well, can't read them but anyways..)
It's now at my dropbox at https://www.dropbox.com/s/8tkog4ii7ui6jd7/lxp5.pdf?dl=1
Too late to explore now, but tomorrow is another day! :D
Postby CS70 » Sat Nov 30, 2019 1:29 am
..and yeah from what I understand it looks like the signal paths are very distinct and the dry/mix pot simply moves the signal between the two. Probably the chip is gone.
Postby BillB » Sat Nov 30, 2019 1:33 am
Thanks for sharing the service manual. I was googling for a factory reset but didn’t find anything. The service manual does have a ‘no wet signal troubleshooting’ starting at P2-21.
Also worth noting that you aren’t alone
https://forums.prosoundweb.com/index.php?topic=143160.0
This is for an LXP-1, but there are similar questions for the LXP-5.
But no obvious resolution. Hope you get somewhere with it :thumbup:
BillB
Postby CS70 » Sat Nov 30, 2019 3:04 pm
Been reading the manual and it was like a trip on memory lane, there’s a few z80 inside..
Postby James Perrett » Sat Nov 30, 2019 10:33 pm
CS70 wrote: c) Not with a voltmeter (dont have one) but it's the original power supply - what possibility are you thinking of?
It is well worth getting a multimeter - even the £2.50 cheapie from CPC will do for most things.
https://cpc.farnell.com/duratool/d03046 ... multimeter
I bought one from Maplin when I needed something quickly and I use it quite a bit. I wouldn't use it on high voltages but it seems fine up to 100V or so. The only thing missing is a continuity buzzer.
The first thing to do when faced with a dead piece of gear is to check all the power supply voltages as power supplies are one of the more stressed parts of most circuits. No noise at all on the output makes it more likely that there's a supply missing.
Postby Eddy Deegan » Mon Dec 02, 2019 3:45 pm
CS70 wrote:Been reading the manual and it was like a trip on memory lane, there’s a few z80 inside..
Ahh, charming little beasties. I love the fact that the family is still going strong after over 40 years!
Some of my works.
Postby SomeMidwestDude » Wed Dec 18, 2019 7:00 am
We're talking the Lexicon LXP-5 here, right?
I recently purchased a used LXP-1, LXP-5, and MRC. The LXP-1 and MRC seem to be working fine, but I also get no wet signal on the LXP-5. Turning the mix knob to the right just decreases the volume of the input signal.
The unique thing about my problem is that it sometimes works for 1-3 seconds, and then goes back to 100% dry signal. When this happens I re-transmit the setup change to the LXP-5 one or more times until I hear something that sounds like an effect. But then it stops suddenly. Otherwise the three knobs on the left all work and all LED's function.
I'm guessing that there is a chip that is bad/going bad but I thought I'd jump in on the discussion in case anyone finds success in fixing something like this on their own.
SomeMidwestDude
Postby CS70 » Wed Dec 18, 2019 1:57 pm
SomeMidwestDude wrote:We're talking the Lexicon LXP-5 here, right?
Yes, LXP :D
I reached the same conclusion as you - probably a chip or something else is gone. Looking at the schematics (for the little I can look) it seems that the mix knob is simply dividing the signal between two separate electrical paths - one doing nothing (the dry) and the other applying the processing. My guess is that something in this latter one has broken down.
That would explain why everything seems to be working but doesn't, and why turning the mix we get no sound: we're simply diverting the signal more and more into a path which is effectively dead. A failing component in that might explain yours.
I would open the unit and look, but it seems that opening is not that straightforward. So the LXP has gone back in a drawer, waiting for better times or someone with the interest and will to spend time with it.
PS: I had also read something vague about pots/encoders going bad. If the part of the pot which sends the signal to the processing path was broken, it could also explain things. The processing path never gets any signal to operate on.
Postby CS70 » Wed Dec 18, 2019 2:10 pm
There is also this I found by a user called "subspace" in GS
(https://www.gearslutz.com/board/geekslu ... -pots.html)
Might at least confirm things don't work in any position.
I copy the post for reference:
I've got two LXP-5s and an LXP-1, but I use an MRC for editing them. The encoders went bad ages ago but I used the Lexicon diagnostic routine to find working positions and left them set there. Here's the diagnostic:
The following diag lets you identify "good" settings for your knobs that will let you use your MRC and not have the LXP-5 change stuff on you.
1) Unplug the unit from the wall 2) Plug it back while holding the Learn button in. 3) Release the Learn button (no lights will be on at this point). 4) Turn the Preset knob to "Edit B" 5) Press and Release the Learn button (the LED will be RED now). 6) Set all three rotary switches (Preset, ????, Adjust) to the same * *position. I started from Bypass, Min, Min. 7) If the LED is green, this is a good setting for the LXP-5. * *If the LED is red, this combo of positions is hosed. 8) Move all three rotary switches to the next position and observe the * *color of the LED. Green = Good. Red = Bad. 9) Repeat step 8 until you have checked all 16 positions. Remember, for * *the test to work, all three switches must in the same position
Postby SomeMidwestDude » Tue Dec 24, 2019 3:40 am
Thanks for sharing the diagnostic routine, CS70.
I did find only two positions that gave the green light. Leaving them in position there kept the wet signal going!
It still is very temperamental, seems like I have to re-send a lot of the parameters from the MRC in order to trigger the effect. Also this is such a weird effect I'm not sure how I'm going to use it...
Thanks again!
SomeMidwestDude
Postby SomeMidwestDude » Wed Jan 15, 2020 3:45 am
Well, that didn't last long. It seems like it got worse and worse each time I powered it up. Mine is officially dead too. Oh well.....
SomeMidwestDude
