Why is this?
Why is this?
Postby Howdy Doody Time » Wed Dec 04, 2019 12:05 am
Why is it not possible to insert a USB plug into its socket the right way up, at least half of the time, in the dark, or restricted view, according to statistics?
Howdy Doody Time
The only excuse we have for making music in the first place is to make it differently..vis-a-vis our own difference (Glenn Gould)
Re: Why is this?
Postby Watchmaker » Wed Dec 04, 2019 12:28 am
For the same reason toast falls butter side down
Watchmaker
Re: Why is this?
Postby blinddrew » Wed Dec 04, 2019 8:52 am
Because they exist in 4 dimensional space: https://www.smbc-comics.com/comic/2011-10-04
Re: Why is this?
Postby The Elf » Wed Dec 04, 2019 9:32 am
When I'm trying to plug in any cable that's in an awkward, difficult situation I ask myself one question: which way does the cable naturally make the plug want to settle, and which would be the simplest, easiest way for it to fit? And it's always exactly the opposite.
Re: Why is this?
Postby Arpangel » Wed Dec 04, 2019 9:45 am
This law also applies to HDMI cables.
Re: Why is this?
Postby John Willett » Wed Dec 04, 2019 9:51 am
Howdy Doody Time wrote:Why is it not possible to insert a USB plug into its socket the right way up, at least half of the time, in the dark, or restricted view, according to statistics?
Murphy's Law :mrgreen:
John Willett
Re: Why is this?
Postby Martin Walker » Wed Dec 04, 2019 11:37 am
The Elf wrote:When I'm trying to plug in any cable that's in an awkward, difficult situation I ask myself one question: which way does the cable naturally make the plug want to settle, and which would be the simplest, easiest way for it to fit? And it's always exactly the opposite.
Exactly - this is ALWAYS the case :headbang: :headbang: :headbang:
Re: Why is this?
Postby BJG145 » Wed Dec 04, 2019 11:56 am
It's the worst connector ever invented. Whoever is responsible ought to have it inserted in the dark the wrong way up into themselves.
Re: Why is this?
Postby Arpangel » Wed Dec 04, 2019 12:10 pm
SCART leads have to be the worst.
Re: Why is this?
Postby ef37a » Wed Dec 04, 2019 12:51 pm
Arpangel wrote:SCART leads have to be the worst.
Yes! Now, for the USB problem: We, son and I, had two desktop PCs side by side on a plinth some 100mm off the floor and of course the ports were at the back. I bought some 0.5mtr extension cables and using adhesive pads and cable ties ran two of the extensions along the top of the case to the front thus allowing AIs and sticks to be easily used.
I have done the same with my living room computer. The USB 3.0 port comes up on a 200mm 3.0 extension and the USB 2.0 on a powered hub. The front ports are USB 1.1 (yes! V old PC)
But, I now only have one PC in the 'studio' and so I have turned it around so that it is parallel to the wall and I can acess front and back with ease (saw this setup at my hospital)
Love 'em or hate 'em at least you canot get USBs in the wrong way! That caused some blue air for the Fussy wire peeps!
Just like to add..IMHO folks do not think/make use of 'sacrificial' cables on their gear nearly as much as they should.
Re: Why is this?
Postby N i g e l » Wed Dec 04, 2019 2:22 pm
Its easy, just follow the instructions .....
Re: Why is this?
Postby CS70 » Wed Dec 04, 2019 3:46 pm
Nigel has it spot on, it's a quantum thing.
Re: Why is this?
Postby John Willett » Wed Dec 04, 2019 5:44 pm
Just move over to USB-C - no wrong way. :thumbup: :bouncy:
John Willett
Re: Why is this?
Postby pa28 » Wed Dec 04, 2019 11:51 pm
Watchmaker wrote:For the same reason toast falls butter side down
Just buttered on wrong side.
pa28
Capitalisation is the difference between helping your uncle jack off a horse  & helping your Uncle Jack off a horse.
Re: Why is this?
Postby ConcertinaChap » Thu Dec 05, 2019 8:36 am
The Elf wrote:which way does the cable naturally make the plug want to settle, and which would be the simplest, easiest way for it to fit? And it's always exactly the opposite.
Ward's Law! It's always exciting to be present at the discovery of a new natural law.
ConcertinaChap
Re: Why is this?
Postby Folderol » Thu Dec 05, 2019 9:18 am
The only time I have a problem is when some idiot manufacturer mounts the sockets upside down (or sideways) in the computer. However, I do cheat. I look at the end of the lead before plugging it in :lol:
As for USB C, no thanks. it's far too fragile for the real world.
Re: Why is this?
Postby ef37a » Thu Dec 05, 2019 9:27 am
Folderol wrote:The only time I have a problem is when some idiot manufacturer mounts the sockets upside down (or sideways) in the computer. However, I do cheat. I look at the end of the lead before plugging it in :lol:
The only thing I have USB C 24 pin on is my not-ever-so smart Sony phone and that seems quite robust. Far tougher than micro USB that is increasingly used, even on kit that is easily big enough to take a type B such as amps and snyths.
And, WHY did we need that wide. flat thing with a kink in it? I have them on two external drives. ANOTHER bloody cable to find!
Re: Why is this?
Postby PKRain » Thu Dec 05, 2019 10:50 am
Center yourself. You must think like the plug, be as one with the cable.
PKRain
Re: Why is this?
Postby wireman » Sat Dec 07, 2019 6:01 pm
I can't decide between SCART and the AUI connector (with the locking catch that never worked reliably) as the most annoying.
wireman
Re: Why is this?
Postby ef37a » Sat Dec 07, 2019 6:11 pm
wireman wrote:I can't decide between SCART and the AUI connector (with the locking catch that never worked reliably) as the most annoying.
To be slightly fairer to the SCART connector it was never intended for constant pluggerating and was made very cheaply for a consumer market.
