Overdrive unit/pedal for warming digital synths?
Page 1 of 5
PostPosted: Fri Dec 13, 2019 10:13 am
by Arpangel
I've been using mainly analogue synths for awhile now, my Mini Moog, Eurorack, for a bit, and now my Buchla. All I can think of is that I've got used to a ceartin type of sound.
But now I'm revisiting my old digital stuff, my A--Station is fine, that has a sound that's unique, and I don't mind that, but I have an Alesis Micron and a Proteus 2000 that could benefit from a bit of a warm up.
I know there are various ways of doing this, more obvious chorusing or layering, but that's not what I'm after, all I need is a thickening, warming up of the sound, I'm after a stereotypical tube sound, not something subtle, a cliched valve sound, harmonic distortion.
Re: Overdrive unit/pedal for warming digital synths?
PostPosted: Fri Dec 13, 2019 10:39 am
by The Elf
Still can't say I interpret distortion as being 'warmth', but...
https://www.soundonsound.com/forum/viewtopic.php?f=23&t=47153
PostPosted: Fri Dec 13, 2019 10:49 am
by Arpangel
The Elf wrote:Still can't say I interpret distortion as being 'warmth', but...
That thread mentions the ART Tube preamp, I'm thinking along these lines, but I'm also thinking of maybe putting things through an amp, for a more dramatic effect.
Maybe distortion is the wrong word, I can hear in my head what I want, it's just bigger, warmer, I can cut the top,end and hoist the bass and lower mid, but that's not it, I think it may be the harmonic distortion of valves, they seem to do everything but don't rob the sound of clarity, it's like something nice has been added.
PostPosted: Fri Dec 13, 2019 10:50 am
by The Elf
dbx386? At some point you're likely to need stereo.
PostPosted: Fri Dec 13, 2019 10:58 am
by Arpangel
The Elf wrote:dbx386? At some point you're likely to need stereo.
Elf, I definitely need stereo, from the beginning.
This is a "saturated" market..... :blush: sorry!
The first thing that comes to my mind is the Culture Vulture, but that's stupid money, but this is like buying a suit, and just as personal, a fifty quid pedal might do it, ad we are talking about a little hundred quid synth, its not worth spending too much.
PostPosted: Fri Dec 13, 2019 11:42 am
by The Elf
Arpangel wrote:Elf, I definitely need stereo, from the beginning.
Then I'd definitely put the dbx386 on your check-list. I thought those ART Tube boxes were all mono?
I'd recommend my beloved VKP-1, but I have only seen one other in many years of searches.
PostPosted: Fri Dec 13, 2019 12:41 pm
by ef37a
They have been around for over ten years now and are seen as a bit 'Marmite', mainly because of size and power requirement but the Blackstar HT pedal range are noted for a good OD sounds and are very controllable. Might picjk one up cheaply second hand.
The 'warmf' is generated by a double triode and unlike most other 'toob' pre amps, these run at the right, ouchy, 300V HT.
Most versatile of the lot is the HT-Dual and that also has a speaker emulated second output ideal for recording or feeding a PA. Designed for guitar of course but the tone controls have vast range. TMB plus a sweep notch filter.
Got a good review in the mag.
PostPosted: Fri Dec 13, 2019 1:10 pm
by Dan LB
Elektron Analog Heat?
https://youtu.be/PQXPARuCXZg
There’s a MKii version now too.
PostPosted: Fri Dec 13, 2019 2:05 pm
by Arpangel
I'm not after a "hovering on the edge" type of sound, just a "nice" valve processor, it's getting that balance, or getting something with a fine degree of control, I just want my Micron to sound like an Oberhiem through a Fender Dual Showman, come on chaps, is that really too much to ask?
PostPosted: Fri Dec 13, 2019 2:12 pm
by The Elf
Arpangel wrote:I just want my Micron to sound like an Oberhiem through a Fender Dual Showman, come on chaps, is that really too much to ask?
Yeeeeeeeeeaaaaah...
Have you considered a new synth?! :wink: :lol:
PostPosted: Fri Dec 13, 2019 2:20 pm
by Arpangel
Yeeeeeeeeeaaaaah...
Yeeeeeaaahhhhh????? Oh, OK then!
:D :D
I loved my Micron, got loads of good sounds for it, but lately it sounds so damn thin, for some reason.
by blinddrew
And an amp perhaps? ;)
PostPosted: Fri Dec 13, 2019 2:23 pm
by Arpangel
blinddrew wrote:And an amp perhaps? ;)
I've got a Roland Guitar Cube, I'll put it through that with a bit of drive, it's got a recording output, I'll try that.
PostPosted: Fri Dec 13, 2019 2:26 pm
by The Elf
Whatever the question now is, the answer is "Novation Peak".
My work here is done! :D :beamup:
PostPosted: Fri Dec 13, 2019 2:40 pm
by Arpangel
The Elf wrote:Whatever the question now is, the answer is "Novation Peak".
I've just passed the Peak, I'm on my way to the Summit...
