How to calibrate levels on the Focusrite ISA 2
Re: How to calibrate levels on the Focusrite ISA 2
Postby Hugh Robjohns » Wed Jan 15, 2020 11:09 am
Postby ef37a » Wed Jan 15, 2020 11:16 am
Hugh Robjohns wrote:https://customer.focusrite.com/sites/customer/files/focusrite/downloads/27309/clarett-4pre-user-guide-en.pdf
Page 17
Yes, got that Hugh but it states "Max input +26dBu" Where is the specc for the fixed inputs at +10dBu?
Postby Hugh Robjohns » Wed Jan 15, 2020 11:51 am
Sorry Dave... that's all I could find.
Postby ef37a » Wed Jan 15, 2020 3:39 pm
Hugh Robjohns wrote:Sorry Dave... that's all I could find.
So, unless the correct figures can be found we could be doing Focusrite a grave injustice?
+10dBu seems a very poor headroom figure for even a sub £100 interface.
Was there a typo about or a misread number? Thinking on, much of this confusion would be saved if mnfctrs always gave us "XdBu in produces Y dB fs."
Dave
Postby Hugh Robjohns » Wed Jan 15, 2020 4:16 pm
I've no idea where the idea of a +10dBu max line input came from. It seems very odd to me.
All the hardware facilities and other input and output specs appear identical between the USB and TB models, so I'd have expected the rear panel line inputs to have the same, entirely reasonable, +18dBu max input level.
Postby armans » Thu Jan 16, 2020 9:37 am
ef37a wrote:Can someone post a link to the Claret 4 TBs specifications please?
I'll be jiggered if I can find it!
It was replaced by the new usb one. I have the manual at home but even there it does not state the max input for the back inputs. Focusrite only put the max input specs for the front inputs into the manual. I wonder why, maybe because they prefer not to show it.
armans
Postby armans » Thu Jan 16, 2020 4:40 pm
From focusrite:
If you have the Clarett 4Pre USB then you are correct, the maximum input is +18dBu, but if you have the Clarett 4Pre this is +10dBu.
armans
Postby armans » Thu Jan 16, 2020 4:42 pm
Maybe they left it out on purpose?
armans
Postby armans » Thu Jan 16, 2020 4:50 pm
Hugh Robjohns wrote:I've no idea where the idea of a +10dBu max line input came from. It seems very odd to me.
I purchased 2 X -15db in-line attenuators. I received them today and was able to calibrate the meters using the back inputs but I must say I am rather dissapointed at how useful the meters will be anyway. What you said about different meters showing different things must be the reason. When I use a steady tone the meters show one thing but when I actually play my guitar and record, the meters in my DAW show much higher peak levels than what the ISA 2 shows me. I think my DAW shows peak values while the Focusrite shows average levels because the meter is always much lower than what I am recording
armans
Postby Hugh Robjohns » Thu Jan 16, 2020 5:11 pm
armans wrote:When I use a steady tone the meters show one thing but when I actually play my guitar and record, the meters in my DAW show much higher peak levels than what the ISA 2 shows me.
Welcome to the world of 'standards'... :crazy: We all love standards in the audio industry. That's why we have so many of them... all different...
A meter is just an indicator, and with experience you get to learn how to interpret what different meters are indicating.
So you just need to learn what an acceptable peak level is on the ISA meter and reference to that.
...and remember that working with a generous headroom margin always makes life much easier when recording as you don't need to worry about peak levels when you know nothing you do will cause an overload. In that situation, the meter is really just confirming the signal is present and correct.
Postby armans » Fri Jan 17, 2020 7:03 am
Well said thanks for all your help. I just have one last question regarding this. Lets say, I never used in-line attenuators and just used less gain on my ISA 2 so I could go into the back if my Clarett interface. I would obviously use 14db or so less gain going into my interface. Would there be any problem doing this? I mean I was doing it all along until I realised something was not right with the meters but does it afffect the sound in some way?
armans
Postby Hugh Robjohns » Fri Jan 17, 2020 10:19 am
armans wrote:Lets say, I never used in-line attenuators and just used less gain on my ISA 2 so I could go into the back if my Clarett interface. I would obviously use 14db or so less gain going into my interface. Would there be any problem doing this? I mean I was doing it all along until I realised something was not right with the meters but does it afffect the sound in some way?
It would mean running the ISA2 preamp with less gain and a lower average level and therefore, in theory at least, with a reduced signal-to-noise performance.
In practice, though, I doubt you'd actually notice any real difference because we're only talking about 8dB or so.
Postby armans » Fri Jan 17, 2020 4:19 pm
ISA max output 24db
Clarett 4 max input 10db
Isnt that a 14db difference?
armans
Postby Hugh Robjohns » Fri Jan 17, 2020 4:25 pm
You and your numbers... ;)
I was thinking of the +18dBu max input capability of the USB version of your interface, as opposed to the +10dBu max of the TB version you have. That's 8dB by my reckoning...
And if you ever did get +24dBu out of your ISA you've really been caught out badly ... HEADROOM, remember? :D
Postby armans » Wed Jan 22, 2020 8:55 am
Hugh Robjohns wrote:You and your numbers... ;)
Sorry to come back to you again but there is still a problem with my ISA meters.
I tried a white noise test and then the problem became evident. This is precisely what I did.
I sent a -14dbfs white noise test tone out of output1 of the CLarett and into the ISA 2 line input.
I set the ISA 2 gain on the ISA 2 to 0 and sent it back into the Clarett using input 5 going through a -15db pad (the pad is advertised as being 15db but not sure it it)
I looked in my DAW and the tone coming in was 4db hotter than the output in my DAW and showed a level of -10dbfs
I then tweaked the meter on the back of the ISA 2 and even in the most anti-clockwise position only the -18dbfs light lit up. I was at least 8db short to make the calibration happen.
So can you please help me make sense of these results?
armans
Postby Hugh Robjohns » Wed Jan 22, 2020 11:09 am
armans wrote:Sorry to come back to you again but there is still a problem with my ISA meters.
No... in this case the problem is with your lack of understanding of metering as a whole...
You CANNOT use any type of noise to 'calibrate' an audio meter, or to check levels. Noise is a random signal which is constantly changing in level over time, and specifically the peak level is constantly changing with respect to its RMS level. So different types of meter will always provide completely different readings.
You can only check and calibrate audio meters using steady-state sine tones -- 1kHz is normal, but 400Hz is easier on the ear!
Postby armans » Wed Jan 22, 2020 4:17 pm
Hugh Robjohns wrote:No... in this case the problem is with your lack of understanding of metering as a whole...
That too :headbang: ! but how much could the noise signal "fluctuate"? I see it isn't steady in my DAW but it hardly varies more than a db or so. So how can the results be so different? Even when I go straight out of my Clarett output 1 straight into output 5 with the noise, there is a 5-6 db difference in the level compared to when I am using a sine tone.
Hugh Robjohns wrote:You can only check and calibrate audio meters using steady-state sine tones-- 1kHz is normal, but 400Hz is easier on the ear!
Ok good to know, thanks!
armans
Postby ef37a » Wed Jan 22, 2020 4:27 pm
armans wrote:
Hugh Robjohns wrote:No... in this case the problem is with your lack of understanding of metering as a wholes...
Mind Hugh! For the craic I once connected a £1000 ac mVoltmeter, a Fluke true rms meter and a 30 quid Maplin DMM to a white noise generator. They all gave different readings by around 3dB iirc!
Postby Hugh Robjohns » Wed Jan 22, 2020 6:12 pm
armans wrote:...how much could the noise signal "fluctuate"? I see it isn't steady in my DAW but it hardly varies more than a db or so. So how can the results be so different?
If you really want to know, buy and read this book:
https://www.soundonsound.com/reviews/audio-metering-measurements-standards-practice-second-edition Image
Yep. Sounds about right. It's partly to do with the Crest Factors of different signals, and partly the different meters' integration times and general ballistics -- the latter because unlike a steady tone, a noise signal is inherently changing its amplitude continuously.
The Crest Factor is the difference between a signal's true peak amplitude and its RMS value. The Crest factor for a sine wave is fixed an steady at 3dB, but it can be very much higher and variable for a noise signal... or a music signal for that matter.
So if one meter is trying to indicate something akin to peak values, and the other is trying to show something like the RMS values, you will inevitably have a substantial difference in readings.
And similarly, if one meter has a very fast response (short integration time) -- like a peak-reading meter -- but the other has a slower response -- typical of an RMS meter -- you will also get very different readings as one will react well to instantaneous level changes in the noise (or music) signal, and the other won't even see them and will only react to longer term amplitude changes ....
Postby armans » Wed Jan 22, 2020 6:45 pm
Hugh Robjohns wrote:And similarly, if one meter has a very fast response (short integration time) -- like a peak-reading meter -- but the other has a slower response -- typical of an RMS meter -- you will also get very different readings as one will react well to instantaneous level changes in the noise (or music) signal, and the other won't even see them and will only react to longer term amplitude changes ....
Ok thank you for clarifying but I still have to say that there is something not quite right about this. As another test, I played a pad on a VST instrument and once again, the pad showed a hotter return level in my DAW than what the ISA showed on its meter so as it stands, the meter is of no use to me at all! It is about 5 - 8db off and at focusrite they assured me that peak RMS values have nothing to do with it. They confirmed that what the meter shows on the ISA is what should be in my DAW. They are busy helping me but they only reply once a week so it is a tedious process. I will of course let you all know how it is going but for now I stand firm that the ISA meter does not work correctly. If there is such a difference in level between the sine tone and white noise / pad instrument then it would be more accurate to calibrate to those levels than to the sine tone because that way when I play and record something the level will be more like those levels and not like the sine tone, do you follow?
armans
