One compressor, What is it doing!>!
Postby DC-Choppah » Wed Jan 15, 2020 3:37 am
I recently was playing a jazz organ patch into my Yamaha mixing board and the sound would sometimes get into an ugly pulsating distortion.
I looked around and eventually found that the channel on the Yamaha mixer had the one- knob compressor knob at about 50%. Ooops, I never use that. I use this board for recording only. I love it actually, but I don't use this on-board compressor.
So when I turned the one-knob compressor down to zero the sound was fine - no distortion. I could play the Leslie organ as hard as I want and it sounded fine - no pulsating distortion.
So now I keep the one-knob compression at zero. But what the heck is this thing doing? Why does it kick in with my organ and then sound fine at 0. That is really no help at all.
Is mine broke? Or if this the way it works?
DC-Choppah
Re: One compressor, What is it doing!>!
Postby Zukan » Wed Jan 15, 2020 9:46 am
DC, clarity dude. Are you talking about the Waves One Knob or something entirely different?
Zukan
Postby Hugh Robjohns » Wed Jan 15, 2020 11:34 am
DC-Choppah wrote:So now I keep the one-knob compression at zero. But what the heck is this thing doing? Why does it kick in with my organ and then sound fine at 0. That is really no help at all.
It sounds fine at zero because that's effectively switched off!
Real distortion when using a compressor is usually because the attack time is too fast, resulting in transient distortion. This is not uncommon if the compressor is designed primarily as a protective limiter, and when the sound source has a very clean harmonic makeup (eg, flute, organ tones, voice etc) which reveals that transient distortion quite clearly.
However, the pulsating effect you describe suggests a problem with the release time instead (or as well).
A Leslie'd organ will inherently have a modulating amplitude. If the compressor has a fast release (recovery) time (or faster than the Leslie's modulation, anyway) -- and protective compressors of the one-knob sort built into mixing consoles often do -- it will be trying to chase that modulation, and the whole thing will start bouncing around manically in the way you describe.
The same problem can affect efforts to compress bass guitars, where a fast-release compressor tries to track the actual waveform envelope of the low frequency bass notes.
HTH
Postby Hugh Robjohns » Wed Jan 15, 2020 11:36 am
Zukan wrote:DC, clarity dude. Are you talking about the Waves One Knob or something entirely different?
DC-Choppah wrote:...the channel on the Yamaha mixer had the one- knob compressor knob at about 50%"
It's a simple one-knob channel compressor on the mixing console, Eddie...
Postby CS70 » Wed Jan 15, 2020 12:07 pm
Er.. it compresses? :) and it does it with a fixed attack and release time, which probably aren’t good for the attack/body/decay of your leslie sound.
By turning the knob you probably lower the threshold (or increase the input to a fixed threshold, which has the same result). Beyond a certain level, the compressor will try to change the sound too fast in either release or attack, resulting in distortion.. the pulsating is likely due to the timing of your leslie with respect to the timing of the attack/release of the compressor.
Postby Zukan » Wed Jan 15, 2020 12:54 pm
Thanks Hugh. Clarifies it for me.
Zukan
Postby DC-Choppah » Thu Jan 16, 2020 6:19 am
Hugh Robjohns wrote:A Leslie'd organ will inherently have a modulating amplitude. If the compressor has a fast release (recovery) time (or faster than the Leslie's modulation, anyway) -- and protective compressors of the one-knob sort built into mixing consoles often do -- it will be trying to chase that modulation, and the whole thing will start bouncing around manically in the way you describe.
HTH
It's an ugly distortion on the jazz B3 organ with Leslie that this one knob compressor generates. Not musical at all. I tried other sources and they just compress normally. So if I put in straight guitar into the mixer and am not hitting it very hard, then bring up the one-knob compressor, it just starts to sound compressed - but not distorted.
Meanwhile the jazz B3 at the same level distorts as soon as you kick in some one-knob compression. I'm talking Jimmy Smith style jazz organ. It just hates the one-knob!
Spread the word!
DC-Choppah
Postby Wonks » Thu Jan 16, 2020 9:04 am
There will be a difference between signal level and average signal power. It sounds like the compressor is working on RMS, rather than peak, level detection, and the RMS value of an organ signal will be much greater than that of a guitar. So the compressor will be working a lot harder on the organ than the guitar signal, despite similar peak values.
Postby Hugh Robjohns » Thu Jan 16, 2020 11:37 am
There could be a number of different reasons, and without hearing and using it, it's impossible to say for sure from the remote silence of a forum... ;-)
Wonks makes a very good point about the side-chain level sensing system, and depending on the voicing the organ may well have a much smaller crest factor than a guitar or voice (ie, RMS level much closer to peak level). So the compressor may be trying to introduce more gain-reduction for the same control setting and running out of headroom internally.
It could also be that there is a very strong bass content in the organ sound which is either fooling the compressor into too much compression, or it's trying to track the LF waveform because its release time is too fast.
Or it could be too fast an attack time, as already mentioned.
Or a general gain structure problem in the signal path through the console.
Or a combination of any of the above.
Postby Tim Gillett » Thu Jan 16, 2020 11:57 am
A band I've played in has one of these Yamaha mixers with the one knob compressors on each channel strip, or at least some of them. From memory, increasing compression also added some make up gain. Its usefulness is limited obviously but in a live band situation it helped me smooth a ragged vocal out somewhat.
Tim Gillett
Postby James Perrett » Thu Jan 16, 2020 3:28 pm
DC-Choppah wrote:It's an ugly distortion on the jazz B3 organ with Leslie that this one knob compressor generates. Not musical at all. I tried other sources and they just compress normally.
It sounds like you are using an organ sound without many overtones. Any non-linearity in the signal chain is going to be far more apparent on that sound compared to most other sounds which have overtones or harmonics going up to a few kHz. A compressor is non linear when its gain changes so, if the gain changes are fairly rapid, you'll hear that as distortion.
It is often interesting to feed pure sine waves into various bits of kit and hear what comes out - some things aren't as clean as you think they are.
Postby DC-Choppah » Sat Jan 18, 2020 8:53 pm
One-knob at zero
https://drive.google.com/open?id=1DObWB ... hQhXwWYGPs
One knob at 5 (12 0-clock)
https://drive.google.com/open?id=17T8uA ... DibToyWCV4
This is recorded with my Tascam handheld recorder listening to the Adam studio monitors in the project studio. This is all-analog monitoring with the keyboard DI into the Yamaha mixing board.
Nothing is clipping in the chain. The levels on the Yamaha mixer are set using its simple procedure where you push the PFL button and set the levels of the track.
The distortion comes from the one-knob compressor itself - like a fuzz box sound effect.
If you set the knob higher than 5, the fuzz gets much louder quickly.
DC-Choppah
Postby Eddy Deegan » Mon Jan 20, 2020 1:28 pm
If you reduce the volume of the organ (at source, on the organ itself) with the compressor knob at 50%, and make up the gain on your monitoring does the distortion remain the same or does it reduce as the input signal from the organ gets lower?
Some of my works.
Postby Hugh Robjohns » Mon Jan 20, 2020 2:28 pm
DC-Choppah wrote:One knob at 5 (12 0-clock)...
That sounds to me like too fast an attack time on the compressor, but it could also be an internal gain structure thing. Do you have any idea how much gain reduction it's actually applying at that setting?
Postby DC-Choppah » Mon Jan 20, 2020 2:35 pm
Eddy Deegan wrote:If you reduce the volume of the organ (at source, on the organ itself) with the compressor knob at 50%, and make up the gain on your monitoring does the distortion remain the same or does it reduce as the input signal from the organ gets lower?
The distortion reduces.
You have to hit it pretty low, and use a lot of make up gain. Seems like the threshold of the one-knob is pretty low. You have to keep the one-knob from doing anything. As soon as it kicks it it distorts.
DC-Choppah
Postby DC-Choppah » Mon Jan 20, 2020 2:44 pm
No can't tell. It's one-knob, and no GR meter.
I really have no idea what this on-knob is doing, or if there is some standard way they work?
The mixer is Yamaha MG16XU: https://usa.yamaha.com/products/proaudi ... index.html
Don't get me wrong, I love the mixer for recording. I love all of the routing stuff, and it sounds great and clean.
But the one-knob hates my jazz organ!
DC-Choppah
Postby Wonks » Mon Jan 20, 2020 3:08 pm
It doesn't need compressing, so don't use the knob.
Postby CS70 » Mon Jan 20, 2020 3:20 pm
DC-Choppah wrote:I really have no idea what this on-knob is doing, or if there is some standard way they work?
Yes, to a point: turning the knob you decrease threshold and increase ratio with, attack and release time and makeup gain maybe changing as well according to a predefined curve. I've used these mixer myself live, including that knob :)
From the spec, for the MG 16:
Threshold: +22 dBu to -8 dBu,
Ratio: 1:1 to 4:1,
Output level: 0 dB to 7 dB
Attack time: approx. 25 msec,
Release time: approx. 300 msec
Turning the knob will change some, or all, these parameters between the minimum range towards the maximum. When it's all on the left, the ratio will surely be 1:1, when it's all on the right it's likely 4:1. Likely it will also reduce the threshold and increase the makeup gain (according to some curve) How the attack and release are changing (if they change at all), it's hard to say without testing.
But your ears are test enough - if you don't like it, don't use it :)
Postby DC-Choppah » Thu Jan 23, 2020 12:06 am
Right.
Ok, then I won't use it on anything 'cause I can't trust it to not distort.
I fear that this 'feature' may have cost me a gig. Just saying. I wish it did not exist.
Keep it at zero. No need for its existence. Not helping. Didn't ask for it.
Who can modify my board to make that knob just go away then ?!?
DC-Choppah
Postby CS70 » Thu Jan 23, 2020 9:06 am
DC-Choppah wrote:I fear that this 'feature' may have cost me a gig. Just saying. I wish it did not exist.
Haha yeah there's something with knobs that kinda forces you to turn them even if you have no clue what they do. Even more with compressors. So a one-knob compressor's gotta be irresistible! :D
Gaffer tape! Or superglue.
