Audacity Replacements
Postby Chambo » Thu Feb 06, 2020 10:58 am
Not sure if this is the right place fo0r this, but I often get solid advice.
I tend to use Audacity to work with small Audio files, but with the most recent upgrade of the Mac OS it won't even load.
Are there any other half decent pieces of software that people can recommend. Don't even mind on off payments - it's part of my workflow when I'm recording and 'editing'.
Chambo
Re: Audacity Replacements
Postby Sam Spoons » Thu Feb 06, 2020 11:09 am
Reaper is inexpensive, Cakewalk is currently free. Both are far more sophisticated than Audacity and capable of the highest quality results. My preference is for Reaper simply because it's what I started to use when I returned to using computers for recording (after many years using hardware recording systems) ten or more years ago.
Postby Chambo » Thu Feb 06, 2020 11:12 am
I'll have a look at Reaper again, I end to go back and forth between Ableton and Audacity.
I suppose you get used to small tools which do a small job on editing quickly.
Chambo
Postby Wonks » Thu Feb 06, 2020 11:31 am
Audacity doesn't currently support Catalina. I presume it will do at some point.
Postby ConcertinaChap » Thu Feb 06, 2020 11:36 am
Can I recommend DSP-Quattro? Superb piece of software, relatively inexpensive at $99 for what it does and a very responsive developer.
ConcertinaChap
Postby Vox Gnus » Thu Feb 06, 2020 1:28 pm
I'll second the recommendation for DSP-Quattro. Excellent software, and the support has been superb for many years.
Now I just need him to port it to Linux... :geek:
Vox Gnus
Postby blinddrew » Thu Feb 06, 2020 5:53 pm
A second vote for investigating Reaper and Cakewalk - both very capable bits of software and reasonably priced / free.
Postby jimjazzdad » Thu Feb 06, 2020 7:13 pm
I'd investigate getting a PC. Its only a matter of time before a future Mac OS update renders all the suggestions here inoperative.
:headbang:
jimjazzdad
Halifax, NS, CANADA
Postby Sam Spoons » Thu Feb 06, 2020 8:03 pm
Just like a future Windoze update then :blush:
Postby Humble Bee » Thu Feb 06, 2020 9:54 pm
There’s nothing wrong with GarageBand if you’re on a mac. And it’s free...
And I guess Audacity will catch up soon enough.
Humble Bee
Postby mrdavedog » Thu Feb 06, 2020 10:19 pm
The latest Audacity 2.3.3, works fine with Catalina. Sounds like you might have an older build that's 32-bit rather than 64-bit
mrdavedog
Postby Hugh Robjohns » Thu Feb 06, 2020 10:34 pm
Audacity wrote:We’re pleased to announce release of Audacity 2.3.3 which replaces all previous versions for Windows, macOS and Linux.
Catalina?
Audacity still does not support macOS Catalina properly, but can be used with a workaround. This is because we have not caught up with Apple’s requirements for ‘notarization’ yet. We are working on this for the next release.
Details of the workaround here:
https://forum.audacityteam.org/viewtopic.php?f=47&t=107162
Postby Zukan » Fri Feb 07, 2020 9:51 am
I fear this applies to many companies. Cataline has not been well thought out or implemented.
Zukan
