Help Moog Model D & EHX Little Big Muff
Re: Help Moog Model D & EHX Little Big Muff
Postby Hugh Robjohns » Tue Feb 11, 2020 5:58 pm
BUT IT DOESN'T PROVIDE GALVANIC ISOLATION TO CURE GROUND-LOOPS!
...which is the most likely cause of the unwanted mains hums in the OPS situation. The DTI box (or Cleanbox 2) do provide the necessary galvanic isolation.
The Cleanbox Pro is great for shifting signal levels between semi-pro/instrument levels and professional levels, as well as converting between unbalanced and balanced signal paths (in both directions)... So it's great for connecting a battery-powered pedal into the insert point of a pro console or interface.
But the input and output grounds are all connected together, so it's no use at all in curing ground-loops problems if the system has some!
Postby The Elf » Tue Feb 11, 2020 6:03 pm
Hugh Robjohns wrote:BUT IT DOESN'T PROVIDE GALVANIC ISOLATION TO CURE GROUND-LOOPS!
Ouch! Fair enough! :beamup:
Postby Hugh Robjohns » Tue Feb 11, 2020 6:12 pm
Sorry for shouting! :oops: I just didn't want anyone to rush out and buy the wrong box for the wrong purposes!
Postby Eddy Deegan » Tue Feb 11, 2020 6:24 pm
trash116 wrote:Once again, thanks all - really amazed at the support and friendliness - think i will stick around on this forum going forward...
Do! The SOS forums are a great place to hang out, get info, make friends and share random stuff. Hugh is a superb source of info (as are many other folks here also) and newcomers are always most welcome.
I popped by once to find something out about something. That was in 2004 ... :D
Some of my works.
Postby Hugh Robjohns » Tue Feb 11, 2020 6:53 pm
... and we just can't get rid of him now... :silent: :lol:
Postby trash116 » Tue Feb 11, 2020 7:34 pm
@the elf - many thanks i will look into that one too.
Thank you
trash116
Postby Eddy Deegan » Tue Feb 11, 2020 7:38 pm
Hugh Robjohns wrote:... and we just can't get rid of him now... :silent: :lol:
To be fair I'm only staying until I ...
a) remember
b) get an answer to
... whatever it was I was looking for in the first place :tongue:
Some of my works.
Postby Hugh Robjohns » Tue Feb 11, 2020 7:43 pm
:bouncy:
Postby The Elf » Tue Feb 11, 2020 9:43 pm
a) remember
b) get an answer to
I can’t find your first questions, but the answers I gave were:
1: Yes, but ensure it is well lubricated first.
2: Only if the bass player has been powdered for fleas in the last three months.
3: Mine definitely did, but I don’t use it as much as I used to.
4: I would have it looked at by a specialist.
Hope that jogs your memory.
Sent from my iPhone using Tapatalk
Postby Eddy Deegan » Tue Feb 11, 2020 10:22 pm
:clap: :thumbup:
Some of my works.
Postby Arpangel » Wed Feb 12, 2020 10:51 am
Another one of my probably unnecessary and pointless posts, but, I’d plug directly into the Muff, IME pedals, of any type, always respond better when they are connected directly to the instrument in question, they just seem to have more balls, and you can really play them.
Any attempt to go through an interface first or use a send of some sort always sounds very very weedy, IMO.
