Midi cable length / reliability & latency
PostPosted: Sun Feb 23, 2020 1:50 pm
by AMusicPlayerPlus
If 6m(IN)+ 6m(OUT) midi cables are safe not to face latency and to be reliable solution?
Re: Midi cable length / reliability & latency
PostPosted: Sun Feb 23, 2020 2:05 pm
by Eddy Deegan
Yes, that should be fine. I've used 10m cables in the past with no problems.
PostPosted: Sun Feb 23, 2020 2:17 pm
by James Perrett
Cable length has little to do with latency as MIDI signals travel close to (but not quite at) the speed of light in cables. The limiting factors are going to be the capacitance and inductance of the cable together with the quality of drivers and receivers at each end. With most MIDI devices you would be looking at cable lengths of a few tens of metres before you would notice any issues.
PostPosted: Mon Feb 24, 2020 12:12 am
by Martin Walker
When I'm after MIDI technical info I tend to rely on my bookmark for Hinton Instruments' 'Professional MIDI Guide':
http://www.hinton-instruments.co.uk/ref ... /index.htm
This states (on its second page) that 'Cables shall have a maximum length of fifty feet (15 metres) '
It also contains loads of info on MIDI delays on its page 5:
http://www.hinton-instruments.co.uk/ref ... i/pg05.htm
I also spent a long time exploring MIDI latency myself for various SOS features some years back:
https://www.soundonsound.com/techniques ... ncy-part-1
https://www.soundonsound.com/techniques ... ncy-part-2
https://www.soundonsound.com/techniques ... g-problems
Hope these links prove useful!
