Audio Issues with Samson Meteor Mic since firmware update
Postby Nazaradine » Tue Feb 25, 2020 12:44 pm
Hey Guys,
First time poster and I hope you can help me out with an issue I am having.
I am an audiobook narrator that uses a Samson Meteor mic, the latest Audacity build and Windows 10. I have a new desktop machine with a Sound Blaster Z soundcard and my drivers are up to date.
I read somewhere about Samson's sound deck software and thought the real-time noise reduction that comes with it sounded pretty cool, so I installed this. This brought to my attention that my Samson mic wasn't registering as a Samson mic and just as generic microphone in Windows/Audacity, and this led me to implement a firmware fix - and now Windows recognises it as a Samson mic. This has brought problems.
There's now a persistent crackle on my recordings that wasn't there before the firmware fix and some of the audio is breaking up really badly. I looked into this and most of the information seemed to suggest that this was as a result of the mic being overloaded and to turn down the input volume, but this is where is gets weird (to my mind, anyway) - I used to have my recording volume set at around 2 before the firmware fix, but the crackling is much worse at low volumes. If I turn the recording volume up to around 8, the crackling is much reduced, but not entirely.
Any ideas? I would much prefer to record at low volumes and then normalize to reduce background noise, etc. If it's a case of uninstalling the firmware and just using it as a generic mic again that's ok, but I do not know how to do this.
Thank you in advance!
Nazaradine
Re: Audio Issues with Samson Meteor Mic since firmware update
Postby Hugh Robjohns » Tue Feb 25, 2020 1:02 pm
I suspect the crackling you hear is not overloading, but samples being lost in the interface connection. A louder signal will tend to mask that kind of data loss more effectively.
Which would imply your firmware 'fix' has actually messed up the USB connection in some way.
I would get in touch with Samson to confirm the correct firmware for your specific mic, and a way to install it.
Postby Nazaradine » Tue Feb 25, 2020 1:38 pm
Hugh Robjohns wrote:I suspect the crackling you hear is not overloading, but samples being lost in the interface connection. A louder signal will tend to mask that kind of data loss more effectively.
Thanks Hugh - yes, that makes sense. The firmware 'fix' is new - it was published on 20th Jan 2020 - and it does't look like there is anything more recent. So I guess if I unistall the mic from device manager it will revert to the previous generic windows mic setting?
Nazaradine
Postby Wonks » Tue Feb 25, 2020 1:58 pm
Which firmware fix? Samson seems to only provide one that's for re-installing the original firmware if the mic has lost it.
https://samsontech.zendesk.com/hc/en-us ... or-Windows
Postby Nazaradine » Tue Feb 25, 2020 2:00 pm
Wonks wrote:Which firmware fix? Samson seems to only provide one that's for re-installing the original firmware if the mic has lost it.
Hi there - thank you for the response. Yes, that's the one. Since my original post I have uninstalled the drivers via device manager and reinstalled them but this hasn't fixed the issue.
Nazaradine
Postby The Elf » Tue Feb 25, 2020 2:21 pm
Check your buffer size. Too small and you will get crackles.
Postby Nazaradine » Tue Feb 25, 2020 2:35 pm
The Elf wrote:Check your buffer size. Too small and you will get crackles.
Hi there and thank you - I have no idea how to do this! Would you mind explaining (obviously bearing in mind my setup) and what the ideal setting is please?
Thank you!
EDIT - also note that i have never changed this, so unless the firmware update means that this value will have changed/needs to be changed I am not sure why this would suddenly become an issue - but that's why I am here :D
Nazaradine
Postby The Elf » Tue Feb 25, 2020 3:30 pm
I've tried looking for the information on Samson's web site, but I can't see a thing. Maybe it's something that's fixed and can't be accessed.
In which case... as you were, Sorry.
Postby Nazaradine » Tue Feb 25, 2020 4:02 pm
No worries! You can change the buffer settings in Audacity. It's currently set as the default (100ms)
Nazaradine
Postby The Elf » Tue Feb 25, 2020 4:19 pm
Try doubling that and see what happens - then double it again. See if the crackles stop.
