A Call For Any Help Akai DPS24 Not Booting/Working
Re: A Call For Any Help Akai DPS24 Not Booting/Working
Postby picardjb » Sun Mar 08, 2020 10:44 am
Ok, am posting here again as instructed. I'll follow asap with a pm hopefully. Thanks for your help, Sam.
best, john
picardjb
Postby picardjb » Sun Mar 08, 2020 11:52 am
Hi. I now seem to finally be able to reply to PMs but when I tried to do so instead of confirmation on send I got a message to the effect that "The requested users to be added do not exist.". So am not sure whether my message actually transmitted. Any insight appreciated. Thanks for your patience. John
picardjb
Postby zenguitar » Sun Mar 08, 2020 12:24 pm
The PM system generates a PM to the person you selected. Below that recipient is a box to add additional recipients. Below that is a box for your actual message text.
It sounds like you are attempting to write your message in the additional recipients box. How do I know this? Because it's such an easy mistake to make, so easy that I've done the same thing in the past. And so have many others.
Have another go and you should be fine :)
Yogi Berra
Postby blinddrew » Sun Mar 08, 2020 1:02 pm
zenguitar wrote:It sounds like you are attempting to write your message in the additional recipients box. How do I know this? Because it's such an easy mistake to make, so easy that I've done the same thing in the past.
This ^^^
Especially the last bit... ;)
Postby picardjb » Sun Mar 08, 2020 10:44 pm
I seem to finally have figured it out duh. Thanks guys for the gentle guidance. My self-esteem is only slightly bruised :-)
john
picardjb
Postby zedisded » Mon Jun 29, 2020 10:34 am
picardjb wrote:I seem to finally have figured it out duh. Thanks guys for the gentle guidance. My self-esteem is only slightly bruised :-)
john
I would also be interested if this has not gone yet?
zedisded
