Help me choose between 2 audio devices
Re: Help me choose between 2 audio devices
Postby CS70 » Mon Mar 30, 2020 6:07 pm
Yeah, on the other side there's the form factor - a mixer takes up more space than an interface and - all considered - most of the facilities it offer are redundant in a DAW studio setting. And something that can be said about a mixer is that it has more mechanical parts that can break or degrade - faders and pots.
If you plan a mixed use - live setting or location recording - it's definitely an option. If you exclusively work in the DAW, I'd rather check for an audio interface with onboard DSP.
Postby Dniss » Mon Mar 30, 2020 7:33 pm
Those are great points. It's strictly for recording my synths. I don't plan on recording anything else really.
Cheers!
Den
Dniss
Postby Dniss » Mon Mar 30, 2020 7:36 pm
I just found out about the Berhinger XR18. I don't want to abuse your time but anyone knows if it sounds as good as Focusrite 18i20? It has more inputs.
Thanks!
Den
Dniss
Postby blinddrew » Mon Mar 30, 2020 8:25 pm
I'd say it's a different tool for a different job - unless you need 18 simultaneous inputs, or are looking a future live use, I'd be sticking to the f'rite or the presonus that Sam suggested.
The Behringer is fundamentally a live mixer.
Postby Dniss » Mon Mar 30, 2020 8:29 pm
Great!!
Thanks for your help guys.
Den
Dniss
Postby Sam Spoons » Mon Mar 30, 2020 10:54 pm
I have an XR12 (and a couple of X32s, the Compact is my main studio mixer/interface). Nowt wrong with them as an audio interface but they are not optimised for that job.
Postby Dniss » Tue Mar 31, 2020 12:28 am
Hi Sam!
They're more for live recordings, like miking a drum, I suppose. Its a nice package though, with the DAW integration.
Cheers!
Den
Dniss
Postby The Elf » Tue Mar 31, 2020 8:12 am
If you can live with on-screen control then the XR18 is a really good piece of kit. I can recommend it without hesitation.
Postby Sam Spoons » Tue Mar 31, 2020 11:22 am
Yup, just what I was going to suggest, the XR12 works fine for a home studio interface but can only record two inputs at a time so not much use for serious live recording. The XR18 has the advantage that you can mix there live sound at the same time as recording a multitrack of the gig which an audio interface won't do.
Postby Dniss » Thu Apr 23, 2020 4:03 am
Got the Focusrite 18i20, very very happy with the results.
Thanks for the suggestion.
Den
Dniss
Postby blinddrew » Thu Apr 23, 2020 7:35 pm
Thanks for coming back and wrapping up the thread. :thumbup:
