Can a squealing/feedbacking guitar pedal harm an audio interface?
Re: Can a squealing/feedbacking guitar pedal harm an audio interface?
Postby garrettendi » Sun May 17, 2020 2:15 pm
Well when I wired up the battery cable for the HM300 to check it works without blowing my entire pedalboard, I hooked it up to the amp and it still hummed. So I guess you are right, that does answer my question.
Having said that, I don’t want to faff about with a battery clip every time I use the board, so an isolated PSU is still desired for me.
But at least I know now I don’t need to rush to Thommans site immediately!
garrettendi
"I mean, Led Zeppelin didn't write tunes that everyone liked. They left that to the Bee Gees"Wayne Campbell (Wayne's World)
Postby garrettendi » Mon Nov 23, 2020 10:01 am
Ok follow up on this, the battery clip doesn't stop the Behringer HM300 pedal from squealing.
I tried it last night feeding into my Biyang Metal End amp sim pedal. The squeal was pretty bad, and the Biyang is powered by a PSU but the HM300 is powered by a battery clip so there's definitely no grounding issue.
You're supposed to have all the dials on a HM300 dimed, but am I right in thinking all I can do now is simply turn the level dial down?
garrettendi
Postby garrettendi » Mon Nov 23, 2020 11:22 am
New clarification: I've just seen a YouTube demo with the same squeal, so its normal for the gain and probably nothing to do with the PSU or the battery, as I suspected.
I guess I'll just have to turn the Level knob down! :thumbdown:
garrettendi
Postby blinddrew » Mon Nov 23, 2020 6:08 pm
garrettendi wrote:I guess I'll just have to turn the Level knob down! :thumbdown:
spoken like a true guitarist! :D
Postby garrettendi » Mon Nov 23, 2020 6:09 pm
Every guitarist knows that louder = better.
And I'm already fully Deaf so what have I got to lose?
garrettendi
Postby blinddrew » Mon Nov 23, 2020 6:41 pm
garrettendi wrote:Every guitarist knows that louder = better.
Your friends and family?
Postby RichardT » Mon Nov 23, 2020 9:55 pm
garrettendi wrote:Yep I will get a better PSU eventually for sure. But for now it's not an option sadly, due to funds.
Will my plans for the setting of level at least protect my headphones and ear? I'll also put a noise gate on the Reaper channel.
I’d be tempted to put a limiter on the input channel with zero gain.
RichardT
Postby garrettendi » Tue Nov 24, 2020 3:10 pm
Worked on wiring the HM300 back to the PSU during my lunch break and I confirm turning the Level down to about 10 o'clock gets rid of the squeal and still sounds "killer" as the young people say.
I almost broke my Boss TU-3 in the process though. Impressive.
garrettendi
