Will M-Audio ever support midisport in Catalina?
Re: Will M-Audio ever support midisport in Catalina?
Postby jimjazzdad » Mon May 18, 2020 11:30 am
Do you happen to know if the old Delta systems work on Windows 10? I have a couple of those I've not used in years. They should go to a new home if they're still useful.
The Delta PCI cards certainly run on W7 and, reportedly, on W8.1. I have been loathe to upgrade my (offline) studio PC from 7 to 10, but I am still using 8 channels of Delta in that machine. As Trevor says, "impossible to kill and been around for ever" and he indicates that he has one running on W10.
jimjazzdad
Halifax, NS, CANADA
Postby innerchord » Mon May 18, 2020 11:30 pm
jimjazzdad wrote:I have been loathe to upgrade my (offline) studio PC from 7 to 10, but I am still using 8 channels of Delta in that machine.
Thanks for that. I might get around to trying them in W10 before I sell them. It might increase their value!
I also don't use W10 in my studio... 8-)
There is no reason to if your PC does everything you need, as I'm sure you know. I 'upgraded' to W8.1, actually! :lol:
innerchord
Postby Old and Unwise » Tue May 19, 2020 1:13 pm
HI All,
many thanks for all your comments and replies. I have had to relinquish my deep rooted faith in M-Audio - I have bitten the bullet and gone for the ESI M4U eX - hopefully this is modern enough to be supported for a while. Class compliant and launched last year, if that doesn't work I'm packing it all in!!
Incidentally - My M-Audio Oxygen 25 mk 4 is allegedly class compliant, and on M-Audio's list of items that will work with Catalina. I used to use the controllers on it to access my Soft synths in Logic. This functionality has now disappeared. Does anyone know what's going on there? I was a little despondent to discover that 'new feature'.
Old and Unwise
Russ
Postby desmond » Tue May 19, 2020 2:06 pm
Old and Unwise wrote:Incidentally - My M-Audio Oxygen 25 mk 4 is allegedly class compliant, and on M-Audio's list of items that will work with Catalina. I used to use the controllers on it to access my Soft synths in Logic. This functionality has now disappeared. Does anyone know what's going on there? I was a little despondent to discover that 'new feature'.
You'll need to be more specific about what you were doing and how, and what isn't working now.
There has been no significant change in Logic's controller handling or support for a while that would affect this...
Postby Old and Unwise » Tue May 19, 2020 6:02 pm
Hi Desmond,
Whilst I don't use it over-much, when I used the Oxygen 25 before Catalina, it seemed that some of the synth controls (the principal ones, I imagined) were mapped automatically to the rotary pot controllers C1 to C8 - not always for every synth, but for most. Now - nothing. I can't be absolute about the when's and what's of this as I don't use soft synths massively, but when I needed to previously (say in a project to write a song requiring certain sounds), I could twiddle and modify sounds - that functionality has gone now. Whether its one of the Logic changes, or due to Catalina, or indeed something else, I don't know. But I was certainly fed up when I went back to utilise this useful feature only to find it to be gone. If I could get it back I would be one happy bunny.
(NB - The pads on the keyboard (1-8) still trigger sounds that seem to automatically configure depending on what soft synth you have in Logic. The octave shift keys and the pitch and mod wheels C15 and C16 continue to function as before. I never used the transport keys C11-14 so I don't know whether these have stopped working now, or never actually worked anyway.)
Old and Unwise
Russ
Postby desmond » Tue May 19, 2020 6:17 pm
Old and Unwise wrote:Whilst I don't use it over-much, when I used the Oxygen 25 before Catalina, it seemed that some of the synth controls (the principal ones, I imagined) were mapped automatically to the rotary pot controllers C1 to C8 - not always for every synth, but for most. Now - nothing.
Perhaps you mean the automatic mapping of Smart Controls for some supported controllers..?
https://support.apple.com/en-gb/guide/l ... 5020b0/mac
Postby Old and Unwise » Wed May 20, 2020 5:08 pm
Hi Desmond. We are on the same page now eh :). Thanks for your post.
I have tried uninstalling the device, deleting it out of lists in the controllers section, rebooting, replugging...I don't get the message to automatically configure.
If there is some kind of sequence I need to follow, I haven't found it yet.
Sadly I don't have the time to just play with it until it works either. If there's some simple advice you can offer which will magically sort it, brilliant. If not, don't worry, I'll have to figure it out on a needs must basis.
Cheers
Old and Unwise
Russ
Postby Old and Unwise » Fri May 22, 2020 6:08 am
Found this - resets the thing so the keyboard is recognised as a first time connection :
“You can delete your user preferences and see if this will solve your problem.
Before deleting user preferences, note any specific preference settings that you’ve made, and save any custom key commands you've created. Deleting preferences removes any custom preference settings and custom key commands.
To delete the user preferences, do the following:
Quit Logic Pro X.
In the Finder, choose Go > Go to Folder.
Enter ~/Library/Preferences, then click Go.
Remove the "com.apple.logic10.plist" file from the Preferences folder.
If you upgraded from an earlier version of Logic Pro, also remove the "com.apple.logic.pro" file.
Restart your Mac.
After deleting preferences, open your project and try to reproduce the issue that you were experiencing. If the issue no longer occurs, open Logic Pro X preferences, reapply your custom settings, and import your custom key commands.”
https://discussions.apple.com/thread/250438384
I think this is reasonably common knowledge amongst the enlightened, I’ve seen people posting about preferences folders before. I hope this helps someone else though.
Old and Unwise
Russ
Postby TvRMoogMusic » Wed Nov 04, 2020 11:19 pm
I have a Midisport Uno which is not supported according to the M-audio website.
I downloaded drivers from Roland (UM-ONE MK2 DRIVER VER.1.0.3 FOR MACOS 10.15) and now it works perfect in OSX Catalina 10.15.7.
https://www.roland.com/global/products/um-one_mk2/downloads/
Perhaps this solution also works for you?
TvRMoogMusic
Postby Liber8 » Sat Jan 09, 2021 8:09 am
TLDR: CAUTION with the Roland driver! I installed it and it crashed my laptop.
Appreciating this thread -- I've been trying to figure out why my older Midisport is not working after not having used it in a few years...then I borrowed an Uno, and that still didn't work. Now I know why!
Hopefully the suggestion to install the Roland driver works for some folks, but also be warned: I tried that route last night and ended up with an unbootable laptop. I was able to get it running again by reinstalling Catalina from Recovery Mode, but not until I spent a number of frustrating hours yesterday and today trying to back up my recent stuff using the command line (Terminal) from Recovery just in case I lost everything and had to revert to a Time Machine backup that's a few weeks old. Would rather have just spent the money on a new interface rather than waste all that time...and still have to buy a new interface.
Moral of the story: if you try the Roland driver, be sure to do a full backup of your Mac right before.
TvRMoogMusic wrote:I have a Midisport Uno which is not supported according to the M-audio website.
Liber8
Postby leighsmith » Wed Jan 13, 2021 3:03 am
I've now released an open source driver https://sourceforge.net/projects/midisport-macos/files/ for the MIDISPORT boxes that run as 64 bit drivers on MacOS 10.14 (Mojave) and 10.15 (Catalina). Hope this helps folks create.
leighsmith
Postby Liber8 » Mon Jan 18, 2021 6:09 pm
Thanks so much for this driver!!! It brought my Midiman back to life. And did not kill my OS! (Though I did do a full backup before trying this time :D.) Not amazing that you're having to do the software work that M-Audio refuses to do...but thank you!!
leighsmith wrote:I've now released an open source driver https://sourceforge.net/projects/midisport-macos/files/ for the MIDISPORT boxes that run as 64 bit drivers on MacOS 10.14 (Mojave) and 10.15 (Catalina). Hope this helps folks create.
Liber8
Postby Tomás Mulcahy » Mon Jan 18, 2021 8:30 pm
Old and Unwise wrote:Hi all,
I’m a little bewildered by the loss of functionality of the humble M-Audio midisport 2x2 in Catalina.
Long shot, but try uninstalling the driver? I just set up new machine with a clean install of Mojave, I did not install the driver and my M-Audio MIDISport 4x4 works just fine. Which I did not expect.
Tomás Mulcahy
Postby Matt Houghton » Tue Jan 19, 2021 2:13 pm
Disclaimer: I've not yet tried this, so can't be sure how legit it is, but...
There appears to be an open source MIDISport driver on Github that supports the 1x1, 2x2, 4x4 and 8x8 on Mojave and Catalina. If anyone tried it and meets with success (or not!), please report back here!
Matt Houghton
SOS Reviews Editor
Postby Tomás Mulcahy » Tue Jan 19, 2021 9:20 pm
Wow, great find. Claims that they wrote the original driver. Scary Terminal stuff, but I will try it if I go to Catalina.
Edit: And I think now I actually did install the M Audio driver on my Mojave machine :lol:
Tomás Mulcahy
