Zoom Q2n lens hood/cap?
Postby maxed » Sun May 17, 2020 5:23 pm
Do anyone with a Zoom Q2n Handy Cam know of substitute lens hoods and caps? The Zoom ones are expensive for a couple of bits of cheap plastic that fall off and get lost... Thanks, Max
maxed
Re: Zoom Q2n lens hood/cap?
Postby allebaug » Mon May 18, 2020 6:08 pm
The design of their proprietary hood plus the extreme wide angle field of view of the lens (160 degrees) suggests you will not find a third-party product. There are no threads or a defined mount around the lens where you could install filters or a standard screw-on lens hood or a cap.
At least Zoom has provided a hood and cap. (A low volume product might also be their expectation.)
allebaug
Postby maxed » Tue May 19, 2020 4:32 pm
Thanks for that allebaug - Max
maxed
Postby ColonelForbin » Mon Jun 07, 2021 1:42 pm
Super glue. In particular, for the Q2n lens hood; because it doesn't stay on at all.
I've had to reglue ours a couple times, and they eventually break and get lost. But superglue postpones that...
They re-designed it, and included with the Q2n4k, where it twists and locks on.
ColonelForbin
