Golden Age Project Pre 73 MKII
Postby brucie » Wed May 20, 2020 8:03 pm
Hi everyone,
Hope you are all safe and well. A quick question...has anyone found or used a replacement adapter for one of these units? I know I need a 24V AC adapter, but wonder if anyone has any recommendations, primarily as the ones on Amazon look a bit nasty and could be very noisy.
Thanks!!
Neil
brucie
Neil S. Bruce - http://www.spencerbruce.com
Re: Golden Age Project Pre 73 MKII
Postby Mixedup » Wed May 20, 2020 8:54 pm
Contact their distributor in your country. I'm sure they can supply one... if not try Golden Age directly.
Mixedup
Postby brucie » Thu May 21, 2020 8:27 am
Thanks I'll see what they say.
Cheers
brucie
Postby Mixedup » Thu May 21, 2020 9:08 am
I'm sure Bo at Golden Age could sort you out if the distributor doesn't carry spares. But the stock they carry would have two-pin EU plugs, so you'd need an adapter... the ones that hold the EU plug inside work best for this sort of thing: like this one
Mixedup
Postby brucie » Thu May 21, 2020 4:57 pm
Thanks again so much. I contacted the distributor and they suggested the Golden Age Project PSAC Power Supply Unit (which is a tad pricey at £85) in these lockdown times. I will give the main office an email and see what they say. I think your solution might be the best in the interim.
Neil
brucie
Postby Mixedup » Thu May 21, 2020 5:08 pm
Yeah, I have the PSAC but it's overkill if you have only one unit. Which obviously means you need to add another pre and two compressors :mrgreen:
Mixedup
Postby Trevor Johnson » Thu May 21, 2020 6:52 pm
Cheap 24v AC adapters are switch mode, whereas the Golden Age PSAC uses a 'traditional transformer' with four separate windings, hence the cost.
If funds allow, I would buy the manufacturer's own PSU, which may prove more cost effective, i.e. not fry your pre, than one of dubious quality.
Trevor Johnson
Postby brucie » Fri May 22, 2020 7:48 am
Ah of course, the "you have 3 other outlets that you must fill" ploy :)
Think I might have to get a few more jobs in and the get the PSAC (With the additional Pres and comps of course)!
Thanks for your help!
brucie
