What are the best professional monitor headphones?
Page 1 of 2
PostPosted: Thu May 21, 2020 12:42 pm
by Synthman4
My budget is anything up to £200. What is the best one on the market at this price range?
Re: What are the best professional monitor headphones?
PostPosted: Thu May 21, 2020 12:59 pm
Is this for tracking or mixing? You won't go far wrong with Sennheser HD25s for tracking and either AKG K701/702 (I have HD25s and K701s) or Sennheiser HD 650 for mixing. Buy right and you could just about get both the HD25 and K701s for your budget.
PostPosted: Thu May 21, 2020 1:13 pm
by CS70
"Professional" is anything with which a skilled person can do the job and doesn't break after one month. :) DT990/880Pro, AKG701/702, HD650 (and surely some more I forget). You can do excellent mixes with these and they last for years.
The "best" headphones I have heard so far have been the Audeze LCD-X. I'm waiting for a pair and will put them thru their paces for mixing within a couple weeks or so.
PostPosted: Thu May 21, 2020 2:01 pm
by James Perrett
It may also be worth saying that the best sounding headphones aren't necessarily the best for studio use. Ruggedness, reliability and the availability of spares are also important in professional headphones. That's why you'll still see so many pictures of people wearing DT100's in studios - they're not necessarily the best sounding headphones but they stand up well to studio life.
PostPosted: Thu May 21, 2020 2:29 pm
by Andyh 56
Scan.co.uk Are selling refurbished Akg 702's for a knats wotsit under £73. I bought some a couple of weeks ago . So far have been absolutely brilliant. :thumbup:
PostPosted: Thu May 21, 2020 6:59 pm
by harky
Dont be tempted by Aiaiai TMA 1s
Avoid.
PostPosted: Thu May 21, 2020 8:14 pm
by MOF
Their own DT150 and DT250 headphones sound so much better and just as rugged and parts replaceable.
by innerchord
harky wrote:Dont be tempted by Aiaiai TMA 1s
Avoid.
Is that really a brand, or the sound you utter when you actually hear them for the first time? :lol:
PostPosted: Thu May 21, 2020 8:20 pm
by MOF
Is this for tracking or mixing? You won't go far wrong with.......Sennheiser HD 650 for mixing
You won’t get these at £200 new.
PostPosted: Fri May 22, 2020 11:12 am
by Synthman4
Sam Spoons wrote:Is this for tracking or mixing? You won't go far wrong with Sennheser HD25s for tracking and either AKG K701/702 (I have HD25s and K701s) or Sennheiser HD 650 for mixing. Buy right and you could just about get both the HD25 and K701s for your budget.
Well for messing around with eq's and getting the right sound AND for overall mixing
PostPosted: Fri May 22, 2020 11:14 am
by Synthman4
What is the difference between tracking and mixing?
PostPosted: Fri May 22, 2020 11:18 am
Tracking headphones need to be closed back to prevent the cue mix getting into the microphone. Mixing headphones need to be as accurate and detailed as possible, open back headphones usually sound better than closed so are favourite mixing but sound leakage from the open back makes them impractical for tracking.
I have Senn HD-25s for tracking and AKG K701s for mixing.
PostPosted: Fri May 22, 2020 11:20 am
by desmond
Synthman4 wrote:What is the difference between tracking and mixing?
For recording, you generally need closed headphones that don't leak sound into instrument microphones, and to help the performer only hear the music rather than the sound going on in the room. These are often quite uncomfortable for long periods as they often clamp down hard on your head.
For mixing, generally open-type headphones have a more accurate sound, but as they leak sound, they are less suitable for recording with. They are often lighter and more comfortable to wear for longer periods.
Hence the use of the two types in studios. You want mixing-type headphones, so a semi-open or open design is better for you.
PostPosted: Fri May 22, 2020 11:29 am
by John Willett
For tracking it is vital that sound from the headphones cannot get out and leak back into the microphone and colour the sound.
So these need to be closed back - the better the seal the better.
They do not need to be the highest quality as they only need to make sure the vocalist sings in time and in tune.
On the other hand, headphones for mixing need to be much better quality - open back is better for mixing as they give a more "out of head" sound and enable you to hear the mix much better - though I do sometimes swap for good closed back if I need to hone in on some detail in the mix - then swap to open back and carry on.
So, get some cheap and cheerful headphones (or earbuds) for tracking and some good open back headphones for mixing - the Sennheiser HD 600 are good for this. :thumbup:
PostPosted: Fri May 22, 2020 9:52 pm
by MOF
But not available new for £200.
